    Stratasys uPrint - Retrofit finally Complete!
    My Duet controlled machine
    13
    27
    4.4k
    • Stepping3Dundefined
      Stepping3D
      This is a great project. I have a uPrint which I am contemplating doing similar things to now. The only difference at the moment is I want to add water-cooled hotend and dual extruder, to increase the capabilities somewhat. I am thinking of taking out one of the chamber heaters and using that space to stick the radiator, putting the fan running into the chamber afterwards, still need to do a fair bit of experimentation with that part of it yet.
      If you need any help with the programming of the firmware, I'd be happy to collaborate when I get to that point. I was also wanting to keep the original LCD display and buttons, but I haven't given this enough consideration yet.
      Good work!
      • drphil3dundefined
        drphil3d
        if you want to print high tempature materials you will need a water cooled hotend, just run the water lines to the outside of the chamber, you will definitely need the cooling the printer is very well insulated.
        • LeolaPA2020undefined
          LeolaPA2020 @AJ Quick
          @AJ-Quick Are you using the UPrint printer heads in your project?
            LeolaPA2020
            I'm looking for some part for my Uprint and maybe some of you that are building similar projects might have parts to sell. If so, please let me know.
            • lightface79undefined
              lightface79
              Hi... just doing this rebuild my self here in sweden.
              Going for a watercoold titan aqua system.
              Threw out all the pdb cpu cards and doing complet rebuild/revamp
              Keeping the 12/5v 24 and 120v psus
              The one thing i cant find is if the 120v dv psu needs a power on pin or somthing like that?
              or will it auto turn on when it gets 230v main power.
              Trying to figure out the different pins out from the 120v psu
              Found the 3 mains cables but dont know as of yet with is 120v out + - and what the other pins doo..
              Do u have eany documentation on witch colors is witch 😃
              Best Regards Jan Noord // Sweden
              Electrosolzundefined 1 Reply Last reply Reply Quote 0
              • Electrosolzundefined
                Electrosolz @drphil3d
                @drphil3d Hi. What is the part number of LCD you have used here?
                  T3P3Tony administrators @Electrosolz
                  @Electrosolz its a PanelDue 5i
                  Electrosolzundefined 2 Replies Last reply Reply Quote 0
                    Electrosolz @T3P3Tony
                    @T3P3Tony thanks
                      @T3P3Tony paneldue 5i is not compatible with duet2 board. So the Duet3 board is used here. Am I right?
                        jay_s_uk @Electrosolz
                        @Electrosolz the paneldue 5i is compatible with the duet 2.
                        for a new build/conversion i would stick to the duet 3 family anyway
                        Electrosolzundefined 1 Reply Last reply Reply Quote 1
                          Electrosolz @jay_s_uk
                          @jay_s_uk okay i will look into that
                            Electrosolz @lightface79
                            @lightface79 hi, have you found anything regarding colouring scheme of 120v psu?
