    Stratasys uPrint - Retrofit finally Complete!
    My Duet controlled machine
    13
    27
    4.4k
    • drphil3dundefined
      drphil3d
      if you want to print high tempature materials you will need a water cooled hotend, just run the water lines to the outside of the chamber, you will definitely need the cooling the printer is very well insulated.
      • LeolaPA2020undefined
        LeolaPA2020 @AJ Quick
        @AJ-Quick Are you using the UPrint printer heads in your project?
          LeolaPA2020
          I'm looking for some part for my Uprint and maybe some of you that are building similar projects might have parts to sell. If so, please let me know.
          • lightface79undefined
            lightface79
            Hi... just doing this rebuild my self here in sweden.
            Going for a watercoold titan aqua system.
            Threw out all the pdb cpu cards and doing complet rebuild/revamp
            Keeping the 12/5v 24 and 120v psus
            The one thing i cant find is if the 120v dv psu needs a power on pin or somthing like that?
            or will it auto turn on when it gets 230v main power.
            Trying to figure out the different pins out from the 120v psu
            Found the 3 mains cables but dont know as of yet with is 120v out + - and what the other pins doo..
            Do u have eany documentation on witch colors is witch 😃
            Best Regards Jan Noord // Sweden
            Electrosolzundefined 1 Reply Last reply Reply Quote 0
            • Electrosolzundefined
              Electrosolz @drphil3d
              @drphil3d Hi. What is the part number of LCD you have used here?
                T3P3Tony administrators @Electrosolz
                @Electrosolz its a PanelDue 5i
                Electrosolzundefined 2 Replies Last reply Reply Quote 0
                  Electrosolz @T3P3Tony
                  @T3P3Tony thanks
                    @T3P3Tony paneldue 5i is not compatible with duet2 board. So the Duet3 board is used here. Am I right?
                      jay_s_uk @Electrosolz
                      @Electrosolz the paneldue 5i is compatible with the duet 2.
                      for a new build/conversion i would stick to the duet 3 family anyway
                      Electrosolzundefined 1 Reply Last reply Reply Quote 1
                        Electrosolz @jay_s_uk
                        @jay_s_uk okay i will look into that
                          Electrosolz @lightface79
                          @lightface79 hi, have you found anything regarding colouring scheme of 120v psu?
