    RepRapFirmware 3.6.0-alpha.2 for Duet main boards available
    Beta Firmware
    14
    83
    6.7k
    • DonStaufferundefined
      DonStauffer @dc42
      This post is deleted!
      • curieosundefined
        curieos
        Does alpha 4 still work with toolboards running 3.5.2? I'd like to give this a try, but the toolboard on my Micron is a Fly RRF 36 and it doesn't look like team gloomy is releasing 3.6 alpha builds.
        She/Her
        I work at a local 3D printing shop.
        Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
        Notepadundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • Notepadundefined
          Notepad @curieos
          @curieos Looks like a question for @jay_s_uk @gloomyandy
          The real bamboo printer manufacturer
          gloomyandyundefined 1 Reply Last reply Reply Quote 0
            dc42 administrators @curieos
            @curieos said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
            Yes it does.
            • gloomyandyundefined
              gloomyandy @Notepad
              @Notepad I don't think there are any expansion builds publicly available for 3.6 yet. We did make a build of 3.6 for mainboards available here: https://discord.com/channels/711873626080804914/762765744278208512/1263573562090848286
              As DC42 confirmed existing 3.5.2 builds for expansion boards can be used with 3.6.
              • balajiramaniundefined
                balajiramani @balajiramani
                @dc42 checking if there is any update on this issue?
                • oliofundefined
                  oliof @balajiramani
                  @balajiramani multiple issues have been discussed here, it helps if you're specific on which one you are asking about.
                  • curieosundefined
                    curieos
                    I've done a couple prints now on my Micron, and input shaping is looking way better. There's a symptom I didn't realize was due to the old input shaping algorithm; large ringing artifacts on organic supports. My guess is it's due to the high segmentation of those moves, but I could hear the printer make an almost grinding noise. That's all gone now.
                    The main quirk I'm noticing is slow probing. I'm running a klicky PBC and before, when the probe triggered, it would retract near instantly. Now it pauses after triggering for a brief moment. I have it set up to do multiple samples, and it seems like the first sample is always the slowest when retracting, but every sample has a brief pause.
                    Pressure advance also seems kinda weird. I need to rerun the tuning pattern to be sure I'm using the correct value, but it looks like turning it on at all has a very negative effect on surface quality. It's most pronounced on the latest print, but that's still in progress.
                    She/Her
                      @curieos thanks for your feedback. Re the pressure advance, is the extruder driven by the main board, or by a tool or expansion board - and if so, is that board running 3.5 or 3.6 firmware?
                      curieosundefined 1 Reply Last reply Reply Quote 0
                      • curieosundefined
                        curieos @dc42
                        @dc42 It's on the mellowfly toolboard running 3.5.2
                        She/Her
                          @curieos OK, please upgrade to 3.6.0-alpha.4+3. See my next post.
                            dc42 administrators @dc42
                            All those running 3.6.0alpha builds, please see my announcement at https://forum.duet3d.com/topic/36421/reprapfirmware-3-6-0-alpha-4-3-available-for-testing/1 and upgrade to that version. If you find any issues, please continue in that thread. I shall lock this one shortly.
