    RepRapFirmware 3.6.0-alpha.2 for Duet main boards available
    Beta Firmware
    14
    83
    6.6k
      dc42 administrators @edsped
      @edsped I see connection errors too. Do your connections errors go away if you put the PanelDue on the Setup page so that it stops polling the 6HC?
      edspedundefined 3 Replies Last reply Reply Quote 0
      • edspedundefined
        edsped @dc42
        @dc42 I'm working through it now. Some of my issues appear to be related to running the Jubilee on an IOT network... I've had ongoing connection issues with the paneldue and leave it disconnected unless I have issues with the web interface. I'll follow up once I get my network in order and run a few tests.
        • edspedundefined
          edsped @dc42
          @dc42 Still getting connection errors. Paneldue is disconnected FWIW.
          • edspedundefined
            edsped @dc42
            @dc42 Did a fair amount of reworking of my network and I'm 45 minutes into a print without a disconnect... I believe my issue was more networking than the alpha firmware. Next try, running DWC and the Paneldue together.
            • DonStaufferundefined
              DonStauffer @dc42
              @dc42 Thanks for the information.
              • balajiramaniundefined
                balajiramani
                Hi am seeing a new error today. A few minutes into a print, the printer stopped with the following error:
                Error: Movement halted because a step timing error occurred (code 3). Please reset the controller.
                Here is the output of M122 after that:
                8/18/2024, 5:05:27 PM   M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-alpha.4 (2024-08-13 15:11:39) running on Duet WiFi 1.0 or 1.01
                Board ID: 08DAM-999TL-MQ4SD-6JTDL-3SS6N-968BX
                Used output buffers: 12 of 26 (21 max)
                Static ram: 23368
                Dynamic ram: 66976 of which 12 recycled
                Never used RAM 16440, free system stack 112 words
                Tasks: NETWORK(2,nWait 6,15.9%,195) HEAT(3,nWait 5,0.1%,328) Move(4,invalid,1.1%,272) MAIN(1,running,82.9%,744) IDLE(0,ready,0.0%,29), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 01:00:54 ago, cause: power up
                Last software reset at 2024-08-09 19:04, reason: User, Gcodes spinning, available RAM 13844, slot 2
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 38.2, current 46.3, max 49.1
                Supply voltage: min 23.5, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/1184/1096, gc cycles 1
                Events: 0 queued, 0 completed
                Date/time: 2024-08-18 17:05:26
                Slowest loop: 226.73ms; fastest: 0.13ms
                === Storage ===
                Free file entries: 8
                SD card longest read time 6.2ms, write time 4.3ms, max retries 0
                Segments created 470, maxWait 2498505ms, bed comp in use: none, height map offset 0.000, hiccups added 1 (0.03ms), max steps late 0, ebfmin 0.00, ebfmax 0.00, mcet 0.085
                Pos req/act/dcf: 68507.00/68479/0.99 65547.00/65566/-0.81 65391.00/65409/-0.99
                no step interrupt scheduled
                Driver 0: standstill, SG min 0
                Driver 1: standstill, SG min 0
                Driver 2: standstill, SG min 0
                Driver 3: standstill, SG min 0
                Driver 4: standstill, SG min n/a
                Driver 5:
                Driver 6:
                Driver 7:
                Driver 8:
                Driver 9:
                Driver 10:
                Driver 11:
                === DDARing 0 ===
                Scheduled moves 69133, completed 69131, LaErrors 0, Underruns [0, 0, 0]
                Heater 0 is on, I-accum = 0.0
                Heater 1 is on, I-accum = 0.2
                Movement locks held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is doing "G1 X-13.401 Y-8.549" in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Q0 segments left 1
                Code queue 0 is empty
                === Network ===
                Slowest loop: 208.96ms; fastest: 0.00ms
                Responder states: HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                === WiFi ===
                Interface state: active
                Module is connected to access point
                Failed messages: pending 0, notrdy 0, noresp 0
                Firmware version 2.1.0
                MAC address 5c:cf:7f:2c:25:00
                Module reset reason: Turned on by main processor, Vcc 3.40, flash size 4194304, free heap 40988
                WiFi IP address 192.168.1.61
                Signal strength -36dBm, channel 6, mode 802.11n, reconnections 0
                Clock register 00002002
                  dc42 administrators @balajiramani
                  @balajiramani please share the GCode file that provoked that message and your config.g file.
                  balajiramaniundefined 1 Reply Last reply Reply Quote 0
                    balajiramani @dc42
                    @dc42 Here is the gcode - Uno_CNC_Back_0.2mm_PLA_BigDelta_28m.gcode
                    Here is config.g
                    ; Setup some global variables
                    global power_fail_retract = 2   ;  Retract 2mm when power fails
                    ; Communication and general
                    M550 P"BigDelta"				        ; Machine name and Netbios name (can be anything you like)
                    M551 Preprap                        	; Machine password (used for FTP)
                    M552 S1					                ; Enable WiFi. Disabled for setup and testing. Enable once set up on your network.
                    ; Enable telnet
                    M586 S1 P2
                    ; Debugging
                    M111 S0                                 ; Debug off
                    M929 P"eventlog.txt" S1                 ; Start logging to file eventlog.txt
                    M555 P2                           	    ; Set output to look like Marlin
                    G21                                 	; Work in millimetres
                    G90                                	    ; Send absolute coordinates...
                    M83                                 	; ...but relative extruder moves
                    ; Axis and motor configuration
                    M569 P0 S0				; Drive 0 goes backwards
                    M569 P1 S0				; Drive 1 goes backwards
                    M569 P2 S0				; Drive 2 goes backwards
                    M569 P3 S0				; Drive 3 goes backwards
                    ; Assign extruder drive
                    M584 E3
                    ; Set homing switch config
                    M574 X2 S1 P"!xstop"        ; Set homing switch configuration on S1 = high-end, active-low
                    M574 Y2 S1 P"!ystop"        ; Set homing switch configuration on S1 = high-end, active-low
                    M574 Z2 S1 P"!zstop"        ; Set homing switch configuration on S1 = high-end, active-low
                    ; Set it as a linear delta
                    M669 K3
                    ; Setup paneldue 5i
                    M575 P1 S1 B57600
                    M665 R215.062 L395.317:395.475:395.433 B160 H374.050		; set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0 Y0 Z0				; put your endstop adjustments here, or let auto calibration find them
                    M350 X16 Y16 Z16 E16 I1    	; Set 16x microstepping with interpolation
                    M92 X200 Y200 Z200			; Set axis steps/mm
                    M906 X1400 Y1400 Z1400 E1400 I60	; Set motor currents (mA) and increase idle current to 60%
                    M84 S60                             ; Set idle timeout
                    M201 X12000 Y12000 Z2000 E10000     ; Accelerations (mm/s^2)
                    M203 X30000 Y30000 Z5000 E3600		; Maximum speeds (mm/min)
                    ;M566 X900 Y900 Z300 E1200 P1		; Maximum instant speed changes mm/minute
                    ;M566 X300 Y300 Z300 E450 P1        ; Maximum instant speed changes mm/minute
                    M566 X600 Y600 Z300 E900 P1		    ; Maximum instant speed changes mm/minute
                    M204 P9000 T9000                    ; Set acceleration for print and travel moves
                    ; Configure Input shaping
                    M593 P"zvdd" F45
                    ; Thermistors
                    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700 H30 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
                    M308 S1 P"e0_temp" Y"thermistor" T100000 B3950 R4700 H30 L0	; 100K NTC
                    ;M308 S1 P"e0_temp" Y"thermistor" T100000 B4658 C6.5338987554e-08 ; 104-NT Aliexpress thermistor
                    M950 H0 C"bed_heat" T0      ; Set up H0 as the bed heater using T0 as the sensor
                    M950 H1 C"e0_heat" T1       ; Set up H1 as the extruder heater using T1 as the sensor
                    M140 H0                     ; Map H0 as the bed heater
                    ; Set temperature excursion warnings
                    M570 H0 P20
                    M570 H1 P20
                    M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
                    M308 S4	Y"drivers"  A"Drivers"  ; configure sensor 4 as temperature warning and overheat flags on the TMC2660 on Duet
                    M912 P0 S-3.5               ; Calibrate MCU temp
                    ; Fan definitions
                    M950 F0 C"fan0"
                    M950 F1 C"fan1"
                    M950 F2 C"fan2"
                    ; Thermostatic fan on 1 for cooling the hotend
                    M106 P1 T50 H1
                    ; Thermostatic fan on 2 for cooling the board
                    M106 P2 H3:4 L.3 X1 B0.3 T35:70 ; set fan 2 value
                    ; Tool definitions
                    M563 P0 D0 H1                       	; Define tool 0
                    G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
                    ;M92 E1392								; Based on https://www.thingiverse.com/thing:1359717; 2023/01/06
                    M92 E1077.1646                          ; This is the new value for the hobb-goblin extruder.  03/07/2023
                    ;M92 E319.2005                           ; Set extruder steps per mm.  This is for the MK8 gear
                    ; Z probe and compensation definition
                    M558 P8 C"^!zprobe.in" R0.4 H4 F1200 T6000 A5 S0.01	; Z probe is a piezo sensor
                    G31 X0 Y0 Z-0.08 P100			; Set the zprobe height and threshold
                    M557 R150 S20				; Probe within a radius of 150mm and mesh spacing of 20
                    M376 H5                     ; Taper off bed compensation after 5mm
                    ; Configure power failure and resume
                    M911 S21.0 R23.0 P"G91 M83 G1 Z3 E{-global.power_fail_retract} F1000" ; Relative movement and extrusion.  Move head up and retract 2mm filament.
                    M208 S1 Z-0.5				; set minimum Z
                    T0					        ; select first hot end
                    M501					    ; Load any config overrides
                      DonStauffer @dc42
                      This post is deleted!
                      • curieosundefined
                        curieos
                        Does alpha 4 still work with toolboards running 3.5.2? I'd like to give this a try, but the toolboard on my Micron is a Fly RRF 36 and it doesn't look like team gloomy is releasing 3.6 alpha builds.
                        She/Her
                        I work at a local 3D printing shop.
                        Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
                        Notepadundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        • Notepadundefined
                          Notepad @curieos
                          @curieos Looks like a question for @jay_s_uk @gloomyandy
                          The real bamboo printer manufacturer
                          gloomyandyundefined 1 Reply Last reply Reply Quote 0
                            dc42 administrators @curieos
                            @curieos said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                            Yes it does.
                            • gloomyandyundefined
                              gloomyandy @Notepad
                              @Notepad I don't think there are any expansion builds publicly available for 3.6 yet. We did make a build of 3.6 for mainboards available here: https://discord.com/channels/711873626080804914/762765744278208512/1263573562090848286
                              As DC42 confirmed existing 3.5.2 builds for expansion boards can be used with 3.6.
                                balajiramani @balajiramani
                                @dc42 checking if there is any update on this issue?
                                • oliofundefined
                                  oliof @balajiramani
                                  @balajiramani multiple issues have been discussed here, it helps if you're specific on which one you are asking about.
                                  • curieosundefined
                                    curieos
                                    I've done a couple prints now on my Micron, and input shaping is looking way better. There's a symptom I didn't realize was due to the old input shaping algorithm; large ringing artifacts on organic supports. My guess is it's due to the high segmentation of those moves, but I could hear the printer make an almost grinding noise. That's all gone now.
                                    The main quirk I'm noticing is slow probing. I'm running a klicky PBC and before, when the probe triggered, it would retract near instantly. Now it pauses after triggering for a brief moment. I have it set up to do multiple samples, and it seems like the first sample is always the slowest when retracting, but every sample has a brief pause.
                                    Pressure advance also seems kinda weird. I need to rerun the tuning pattern to be sure I'm using the correct value, but it looks like turning it on at all has a very negative effect on surface quality. It's most pronounced on the latest print, but that's still in progress.
                                    She/Her
                                      @curieos thanks for your feedback. Re the pressure advance, is the extruder driven by the main board, or by a tool or expansion board - and if so, is that board running 3.5 or 3.6 firmware?
                                      curieosundefined 1 Reply Last reply Reply Quote 0
                                      • curieosundefined
                                        curieos @dc42
                                        @dc42 It's on the mellowfly toolboard running 3.5.2
                                        She/Her
                                          @curieos OK, please upgrade to 3.6.0-alpha.4+3. See my next post.
                                            dc42 administrators @dc42
                                            All those running 3.6.0alpha builds, please see my announcement at https://forum.duet3d.com/topic/36421/reprapfirmware-3-6-0-alpha-4-3-available-for-testing/1 and upgrade to that version. If you find any issues, please continue in that thread. I shall lock this one shortly.
