    3.5.0-rc.1 Brakes not engaging
    Beta Firmware
    1.4k
    • p8blrundefined
      p8blr @T3P3Tony
      @T3P3Tony
      (1) 6XD
      (5) 3HC
      (2) 1XD
      raspberry pi 5 in sbc mode
      Z motors and brakes on 6XD (out3-6)
      p8blrundefined 1 Reply Last reply Reply Quote 0
      • p8blrundefined
        p8blr @p8blr
        @timschneider I tried that file but it seems to have messed everything up. Now what do I do?
        @dc42 When will this issue be fixed? I've also noticed that remapping drives do different axes messes up the brake control as well. Only a reboot will fix.
        timschneiderundefined 1 Reply Last reply Reply Quote 0
        • timschneiderundefined
          timschneider @p8blr
          @p8blr
          hi maybe you try the 3.5.3 rc-1 the fix is included
          https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3-rc.1
          https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-353-rc1-changes-since-352
          M17 did not energise the motor brake solenoid (issue 1023)
          p8blrundefined 1 Reply Last reply Reply Quote 1
          • p8blrundefined
            p8blr @timschneider
            @timschneider I just setup a new image again and M997 S2 F"unstable" doesn't work, sudo apt update, sudo apt upgrade doesn't update the firmware, neither does M997 B0. How do I do this? I don't see any documentation of the sort.
            • p8blrundefined
              p8blr @p8blr
              @dc42 M997 S2 V"3.5.3-rc.1" gives "could not find reprapfirmware package....." on a brand new image. Why is this happening?
              jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @p8blr
                have you switched from the stable to the unstable package feed?
                • p8blrundefined
                  p8blr @jay_s_uk
                  @jay_s_uk Isn't that what M997 S2 F"unstable" does?
                  @dc42 I ditched the Raspberry Pi for the moment, and connected via usb and used a SD card and YAT to update to the 3.5.3-RC-1, that worked fine. All board up to date, but after I connected my raspberry pi, and uploaded my original config file, now I get the same errors I had after updating in my last post. SPI connection reset, lost connection to duet. Keep in mind the printer was working fine with the same config file for ages up until the upgrade and there have been no hardware changes. Also in SBC mode my can bus lights don't blink right.
                  jay_s_ukundefined timschneiderundefined 2 Replies Last reply Reply Quote 0
                    droftarts administrators @p8blr
                    @p8blr said in 3.5.0-rc.1 Brakes not engaging:
                    I think that should be M997 S2 V"3.5.3.rc.1" I'm wrong, sorry!
                      jay_s_uk @p8blr
                      @p8blr yes, the F should switch you over (not tried it though)
                        timschneider @p8blr
                        @p8blr
                        can you send us the output of
                        M98 P"config.g"
                        maybe there is a bug in the config, as it appears to me, that was created for an older version of RRF. As stated in the config, it was created for Firmware Version 3.5.0 Release Candidate 1, since then there have been a few incompatible changes.
                        • p8blrundefined
                          p8blr @timschneider
                          @timschneider
                          Sure thing:
                          config.g
                          driveSetup.g
                          variables.g
                          Thanks
                            timschneider @p8blr
                            @p8blr thank you for the files, but can you just make a screenshot of the output when you send the command M98 P"config.g" in the console.
                            • p8blrundefined
                              p8blr @timschneider
                              @timschneider
                              I started a new thread more relevant to this specific issue: https://forum.duet3d.com/topic/36442/firmware-update-bricked-printer-spi-connection-has-been-reset
                              • p8blrundefined p8blr referenced this topic
                              • dc42undefined dc42 marked this topic as a regular topic
                                dc42 administrators @p8blr
                                @p8blr thanks for starting a new thread. I will lock this one.
                                • dc42undefined dc42 locked this topic
