    3.5.0-rc.1 Brakes not engaging
    Beta Firmware
    1.4k
      dc42 administrators @timschneider
      @timschneider thanks for the update. I have created https://github.com/Duet3D/RepRapFirmware/issues/1023.
      dc42 created this issue in Duet3D/RepRapFirmware
      closed M17 doesn't re-engage motor brake #1023
        droftarts administrators @Amagatth
        Also @Amagatth, regarding your thread https://forum.duet3d.com/topic/35935/controle-nema-23-brake, see @dc42's post above.
          T3P3Tony administrators @droftarts
          @Amagatth @p8blr which boards are you using, both and mainboards and expansion boards, and which ones have motor brakes connected.
          p8blrundefined 1 Reply Last reply Reply Quote 0
          • Amagatthundefined
            Amagatth @timschneider
            @timschneider thx i try to put your file but i am on 3.5.2 it work ?
            timschneiderundefined 1 Reply Last reply Reply Quote 0
            • timschneiderundefined
              timschneider @Amagatth
              @Amagatth
              yes this is for 3.5.2 and the brake connected to MB6HC
              anyhow, I've applied the patch from @dc42 on RRF to use WriteAnalog and this works.
               src/Platform/Platform.cpp | 4 +++-
               1 file changed, 3 insertions(+), 1 deletion(-)
              diff --git a/src/Platform/Platform.cpp b/src/Platform/Platform.cpp
              index 874b75ac..f3c2f560 100644
              --- a/src/Platform/Platform.cpp
              +++ b/src/Platform/Platform.cpp
              @@ -2732,8 +2732,10 @@ void Platform::EngageBrake(size_t driver) noexcept
               #if SUPPORT_BRAKE_PWM
               	currentBrakePwm[driver] = 0.0;
              -#endif
              +	brakePorts[driver].WriteAnalog(0.0);
              +#else
               	brakePorts[driver].WriteDigital(false);			// turn the brake solenoid off to engage the brake
              +#endif
               void Platform::DisengageBrake(size_t driver) noexcept
              Duet3Firmware_MB6HC.bin
              @p8blr
              this is the file for the 6XD with WriteAnalog(0.0)
              Duet3Firmware_MB6XD.bin
              Amagatthundefined 1 Reply Last reply Reply Quote 1
              • Amagatthundefined
                @timschneider thx for the file i apply it
                Amagatthundefined 1 Reply Last reply Reply Quote 0
                • Amagatthundefined
                  Amagatth @Amagatth
                  @Amagatth it work ! now m18 engage break !
                  • p8blrundefined
                    p8blr @T3P3Tony
                    @T3P3Tony
                    (1) 6XD
                    (5) 3HC
                    (2) 1XD
                    raspberry pi 5 in sbc mode
                    Z motors and brakes on 6XD (out3-6)
                    • p8blrundefined
                      p8blr @p8blr
                      @timschneider I tried that file but it seems to have messed everything up. Now what do I do?
                      @dc42 When will this issue be fixed? I've also noticed that remapping drives do different axes messes up the brake control as well. Only a reboot will fix.
                        timschneider @p8blr
                        @p8blr
                        hi maybe you try the 3.5.3 rc-1 the fix is included
                        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3-rc.1
                        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-353-rc1-changes-since-352
                        M17 did not energise the motor brake solenoid (issue 1023)
                        p8blrundefined 1 Reply Last reply Reply Quote 1
                        • p8blrundefined
                          p8blr @timschneider
                          @timschneider I just setup a new image again and M997 S2 F"unstable" doesn't work, sudo apt update, sudo apt upgrade doesn't update the firmware, neither does M997 B0. How do I do this? I don't see any documentation of the sort.
                          • p8blrundefined
                            p8blr @p8blr
                            @dc42 M997 S2 V"3.5.3-rc.1" gives "could not find reprapfirmware package....." on a brand new image. Why is this happening?
                            jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              jay_s_uk @p8blr
                              have you switched from the stable to the unstable package feed?
                              • p8blrundefined
                                p8blr @jay_s_uk
                                @jay_s_uk Isn't that what M997 S2 F"unstable" does?
                                @dc42 I ditched the Raspberry Pi for the moment, and connected via usb and used a SD card and YAT to update to the 3.5.3-RC-1, that worked fine. All board up to date, but after I connected my raspberry pi, and uploaded my original config file, now I get the same errors I had after updating in my last post. SPI connection reset, lost connection to duet. Keep in mind the printer was working fine with the same config file for ages up until the upgrade and there have been no hardware changes. Also in SBC mode my can bus lights don't blink right.
                                jay_s_ukundefined timschneiderundefined 2 Replies Last reply Reply Quote 0
                                  droftarts administrators @p8blr
                                  @p8blr said in 3.5.0-rc.1 Brakes not engaging:
                                  I think that should be M997 S2 V"3.5.3.rc.1" I'm wrong, sorry!
                                    jay_s_uk @p8blr
                                    @p8blr yes, the F should switch you over (not tried it though)
                                      timschneider @p8blr
                                      @p8blr
                                      can you send us the output of
                                      M98 P"config.g"
                                      maybe there is a bug in the config, as it appears to me, that was created for an older version of RRF. As stated in the config, it was created for Firmware Version 3.5.0 Release Candidate 1, since then there have been a few incompatible changes.
                                      • p8blrundefined
                                        p8blr @timschneider
                                        @timschneider
                                        Sure thing:
                                        config.g
                                        driveSetup.g
                                        variables.g
                                        Thanks
                                          timschneider @p8blr
                                          @p8blr thank you for the files, but can you just make a screenshot of the output when you send the command M98 P"config.g" in the console.
                                          • p8blrundefined
                                            p8blr @timschneider
                                            @timschneider
                                            I started a new thread more relevant to this specific issue: https://forum.duet3d.com/topic/36442/firmware-update-bricked-printer-spi-connection-has-been-reset
                                            • p8blrundefined p8blr referenced this topic
                                            • dc42undefined dc42 marked this topic as a regular topic
