Unsolved Problem on new installation / upgrade
Hello. I have a duet3, with SBC raspi 3B+, and a 7 inches touchscree. Always used this setup.
Becauase I was having problems wiuth the sd card. I decided to flashed a brand new one. The problems Im facing:1.- Installing this seems to work , but then my touchscreen becomes useless since the re is no GUI: https://pkg.duet3d.com/DuetPi-lite.zip
2.- This version: https://pkg.duet3d.com/DuetPi.zip it doesnt boot. I downloaded and flashed at least 5 times, always same result. The system never boots
3.- I tried this one: http://pkg.duet3d.com/DuetPi-arm64.zip it boots and everything is ok but the DWC version is 3.5.1, the board firmware is 3.5.2 and DSF is 3.5.2
If I loggin in SSH and execute as instructed the commands:
sudo apt update
sudo apt upgradeI get that everything is updated (there was un updated performen on the GUI the first boot)
Question is: should I be using the 64 bits version on a raspi 3 B+?
32 bit image is checked (corrupted or something?)
How to properly update DWC? -
one for @chrishamm
@Tinchus If you have the official RPi 7'' display, you need to change config.txt to add support for the touchscreen. That's changed between Debian Buster and Bookworm and it isn't specific to DuetPi. See https://www.waveshare.com/wiki/7inch_DSI_LCD Please check if that makes a difference.
It's up to you if you want to use the 32- or 64-bit build. 64 bit may perform a bit better but it may require slightly more RAM.
I'm going to build new images with 3.5.3 when that is out, which should happen within the next few days.
@chrishamm Question: I installed DuetPi-arm64.zip and can't seem to login or logon. Has the user or password changed?
@guywinslow said in Problem on new installation / upgrade:
Did you use the Raspberry Pi Imager?
Best to create a new thread if you're still having issues.
@Phaedrux This issue happened also to me. I did used the pi imager. During the config process it asked to create an user. I did it. Later that user nor the default pi user were recognized
Perhaps @chrishamm can confirm if the pi imager user setup should be working?
