    6XD I/O >> Issue solved
    5.4k
      droftarts administrators @tecno
      @tecno said in 6XD I/O >> Faulty Driver 5:
      Have changed cables so no cable fault,
      You swapped the cable, external stepper driver and motor from 6XD driver 4, where it was working, to driver 5, where it didn't work? Are axes homed, or position set with G92, before you try to move them? When you send a move command, does the axis value in DWC change? Is any error reported?
      Are all the external stepper drivers the same? What make and model are they? You haven't added any stepper driver timings to your M569 commands, ie T parameter, something like M569 P# S0 T5:5:10:10, which is usually needed for external drivers; see https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external#configuring-the-step-timing
      Also, on your M584 commands, add S0 to the ones with R0, and S1 to the ones with R1 eg:
      M584 X0 R0 S0			; X LIN
      M584 Y1 R0 S0			; Y LIN
      M584 C2 R0 S0			; RECEIVE MATERIAL
      M584 Z3 R1 S1			; NOZZLE 1 OR 2
      M584 A4 R1 S1			; ROTATE NOZZLE 2
      M584 B5 R1 S1		 	; ROTATE NOZZLE 1
      What firmware version are you running?
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @droftarts
        @droftarts
        3.5.1
        No homeing yet M564 H0
        Edit config
        ;***Axis/Drives
        M569 P0 S0 T5:5:10:10 ; X
        M569 P1 S0 T5:5:10:10 ; Y
        M569 P2 S0 T5:5:10:10 ; RECEIVE MATERIAL
        M569 P3 S1 T5:5:10:10 ; NOZZLE 1 OR 2
        M569 P4 S1 T5:5:10:10 ; ROTATE NOZZLE 2
        M569 P5 S1 T5:5:10:10 ; ROTATE NOZZLE 1
        M584 X0 R0 ; X LIN
        M584 Y1 R0 ; Y LIN
        M584 C2 R0 ; RECEIVE MATERIAL
        M584 Z3 R1 ; NOZZLE 1 OR 2
        M584 A4 R1 ; ROTATE NOZZLE 2
        M584 B5 R1 ; ROTATE NOZZLE 1
          @tecno you changed the S0/S1 in M569, I said to add it to M584.
          Please answer these questions:
          • tecnoundefined
            tecno @droftarts
            @droftarts
            Hi Ian,
            Will try to get my Swedinglish on track 🙂
            6DX Chinese driver Chinese motor
            Driver 5 ---------------A-------------------------A NO GO
            Driver 4 ---------------B-------------------------B WORKING OK
            Cable from Driver 4 to Chinese driver A Working OK
            Cable from Driver 5 to Chinese driver B NO GO
            Switching cables same result
            DWC = yes
            No errors
            External drivers are the same as are motors, rotating nozzles No model on these drivers.
            There is a blue LED showing direction, goes on/off changing direction. But not from Driver 5
            • tecnoundefined
              tecno @tecno
              @droftarts
              ;***Outputs
              M950 P0 C"out0" ; Q500 ;#1 Nozzle Vacuum
              M950 P1 C"out1" ; Q500 ;#2 Nozzle Vacuum
              M950 P2 C"out2" ; Q500 ;Drag PIN Actuator
              M950 P3 C"out3" ; Q500 ;ENA Nozzle 1/2 Up
              M950 P4 C"out4" ; Q500 ;Xross cursor
              M950 P5 C"out5" ; Q500 ;LED light
              M950 P6 C"out6" ; Q500 ;Vacuum power
              How can I check ON/OFF on above outputs?
              droftartsundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                @tecno For driver 5 not working:
                I think you have swapped those around cables and drivers to show that driver 5 output on the 6XD isn't working correctly. Can you:
                • check if you are using the enable signal. If you are, disconnect it (most external drivers are enabled by default) and check if it works. If not, check if there is any dip switches on the driver for default enable/disable, and/or set the dip switches the same as the other nozzle driver. Maybe post a picture of any dip switches.
                • If you have a multimeter, check you are getting 5V on the driver 5 5V pin. Then check for continuity between 5V and the enable pin, and direction pin when a command is sent. Using a multimeter to check if step pulses are sent usually doesn't work, as the step pulses are too fat for a multimeter. If you have an oscilloscope, you can check them that way, though.
                • If the above still doesn't work, check the soldering of the driver 5 connector on the 6XD, both sides. It may be a dry solder joint or something bridging or grounding the pins. Post photos if you're not sure.
                Sending 'M43 P0' or 'M280 P0' doesn't report the current PWM setting (@dc42 perhaps it should?) but you can check the current setting in the Object Model. Defined outputs are listed in the Object Model under state > gpOut[#], where # is the GPIO number defined by the M950 command. eg:
                M950 P1 C"exp.heater5" ; tested on Duet 2 WiFi
                M42 P1 S1
                echo state.gpOut[1].pwm
                1.00
                M42 P1 S0.5
                0.50
                M42 P1 S0
                0.00
                So that should let you query them. Or is it that you want to display their status in DWC?
                • tecnoundefined
                  tecno @droftarts
                  @droftarts
                  Hi Ian,
                  @droftarts said in 6XD I/O >> Faulty Driver 5:
                  No I just wanted to know if the outputs work, and OUT 2 is NOT ( 0 and 1 works)
                  Yet another output not working
                  Cheers
                  Bengt
                  • tecnoundefined
                    tecno @tecno
                    @droftarts
                    Top is P1 bottom is P2
                      @tecno Can you post your whole config.g as it currently is, please. Also run M98 P"config.g" from the console and post the response.
                      • tecnoundefined
                        tecno @droftarts
                        M98 P"config.g"
                        config240923.txt
                          @tecno You've set out2 as a fan!
                          M950 F2 C"out2" ;	Q500	;Drag PIN Actuator
                          Changle "F2" to "P2".
                          • tecnoundefined
                            tecno @droftarts
                            @droftarts
                            Corrected
                            ;***Outputs
                              @tecno Did you reset or run config.g before running the macro again?
                              • tecnoundefined
                                tecno @droftarts
                                @droftarts
                                Yes
                                  @tecno Please post the macro.
                                  • tecnoundefined
                                    tecno @droftarts
                                    @droftarts
                                    M42 P2 S1
                                    M42 P2 S0.5
                                    M42 P2 S0
                                      Wrong pin. Use:
                                      echo state.gpOut[2].pwm
                                      • tecnoundefined
                                        tecno @droftarts
                                        @droftarts
                                        2024-09-23 13:52:19 M98 P"0:/macros/TEST"
                                        1.000
                                        0.500
                                        0.000
                                        Still DEAD output
                                          Still DEAD output
                                          How are you measuring that?
                                          • tecnoundefined
                                            tecno @droftarts
                                            @droftarts
                                            Now suddenly the OUT2 works, so go figure what is going on. Cold soldering seems far away but could be.
                                            Been take out plugs and inserted them testing.
                                            Whole day yesterday I did not see the LED light up but OUT1 and OUT0 was working.
                                            So DRIVER5 is still an issue here.
