    6XD I/O >> Issue solved
    5.4k
      droftarts administrators @tecno
      @tecno For driver 5 not working:
      I think you have swapped those around cables and drivers to show that driver 5 output on the 6XD isn't working correctly. Can you:
      • check if you are using the enable signal. If you are, disconnect it (most external drivers are enabled by default) and check if it works. If not, check if there is any dip switches on the driver for default enable/disable, and/or set the dip switches the same as the other nozzle driver. Maybe post a picture of any dip switches.
      • If you have a multimeter, check you are getting 5V on the driver 5 5V pin. Then check for continuity between 5V and the enable pin, and direction pin when a command is sent. Using a multimeter to check if step pulses are sent usually doesn't work, as the step pulses are too fat for a multimeter. If you have an oscilloscope, you can check them that way, though.
      • If the above still doesn't work, check the soldering of the driver 5 connector on the 6XD, both sides. It may be a dry solder joint or something bridging or grounding the pins. Post photos if you're not sure.
      How can I check ON/OFF on above outputs?
      Sending 'M43 P0' or 'M280 P0' doesn't report the current PWM setting (@dc42 perhaps it should?) but you can check the current setting in the Object Model. Defined outputs are listed in the Object Model under state > gpOut[#], where # is the GPIO number defined by the M950 command. eg:
      M950 P1 C"exp.heater5" ; tested on Duet 2 WiFi
      M42 P1 S1
      echo state.gpOut[1].pwm
      1.00
      M42 P1 S0.5
      0.50
      M42 P1 S0
      0.00
      So that should let you query them. Or is it that you want to display their status in DWC?
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @droftarts
        @droftarts
        Hi Ian,
        @droftarts said in 6XD I/O >> Faulty Driver 5:
        No I just wanted to know if the outputs work, and OUT 2 is NOT ( 0 and 1 works)
        Yet another output not working
        Cheers
        Bengt
        • tecnoundefined
          tecno @tecno
          @droftarts
          Top is P1 bottom is P2
            @tecno Can you post your whole config.g as it currently is, please. Also run M98 P"config.g" from the console and post the response.
            • tecnoundefined
              tecno @droftarts
              M98 P"config.g"
              config240923.txt
                @tecno You've set out2 as a fan!
                M950 F2 C"out2" ;	Q500	;Drag PIN Actuator
                Changle "F2" to "P2".
                • tecnoundefined
                  tecno @droftarts
                  @droftarts
                  Corrected
                  ;***Outputs
                  M950 P0 C"out0" ; Q500 ;#1 Nozzle Vacuum
                  M950 P1 C"out1" ; Q500 ;#2 Nozzle Vacuum
                  M950 P2 C"out2" ; Q500 ;Drag PIN Actuator
                  M950 P3 C"out3" ; Q500 ;ENA Nozzle 1/2 Up
                  M950 P4 C"out4" ; Q500 ;Xross cursor
                  M950 P5 C"out5" ; Q500 ;LED light
                  M950 P6 C"out6" ; Q500 ;Vacuum power
                    @tecno Did you reset or run config.g before running the macro again?
                    • tecnoundefined
                      tecno @droftarts
                      @droftarts
                      Yes
                        @tecno Please post the macro.
                        • tecnoundefined
                          tecno @droftarts
                          @droftarts
                          M42 P2 S1
                          M42 P2 S0.5
                          M42 P2 S0
                            @tecno said in 6XD I/O >> Faulty Driver 5:
                            Wrong pin. Use:
                            echo state.gpOut[2].pwm
                            • tecnoundefined
                              tecno @droftarts
                              @droftarts
                              2024-09-23 13:52:19 M98 P"0:/macros/TEST"
                              1.000
                              0.500
                              0.000
                              Still DEAD output
                                Still DEAD output
                                How are you measuring that?
                                • tecnoundefined
                                  tecno @droftarts
                                  @droftarts
                                  Now suddenly the OUT2 works, so go figure what is going on. Cold soldering seems far away but could be.
                                  Been take out plugs and inserted them testing.
                                  Whole day yesterday I did not see the LED light up but OUT1 and OUT0 was working.
                                  So DRIVER5 is still an issue here.
                                  • tecnoundefined
                                    tecno @tecno
                                    @dc42 @droftarts
                                    Driver 5 is still DEAD !! How do you want to solve this?
                                    Cheers
                                    Bengt
                                      @tecno Can you post a good picture of both sides of the board, please. There's so very little to go wrong with these ports, I feel like it's something obvious. Did you check it with a multimeter, like I asked you to?
                                      out2 is still working correctly? Does the LED come on when active?
                                      Also, please send M586 and post the response, to see what network protocols are enabled, because your config doesn't have any set.
                                      • tecnoundefined
                                        tecno @droftarts
                                        @droftarts
                                        Hi Ian,
                                        Re multimeter = no as you can see it is not so accessible in the video. Later on today.
                                        https://photos.app.goo.gl/L56Zn79kaww26Q4U6
                                        out2 is OK
                                        2024-09-25 09:26:27 m586
                                        CORS disabled
                                        HTTP is enabled on port 80
                                        FTP is disabled
                                        TELNET is disabled
                                        Multicast Discovery is disabled
                                        MQTT is disabled
                                        Cheers
                                        Bengt
                                        • tecnoundefined
                                          tecno @tecno
                                          Pictures of 6XD board https://photos.app.goo.gl/6ME2iY7CesXBjeKPA
                                            @tecno Were you able to do any tests with a multimeter? I can't see anything obvious from the pictures.
