    My Second build (in progress)
    My Duet controlled machine
    3.3k
    • Dad003undefined
      Dad003 @mrehorstdmd
      @mrehorstdmd yea i understand that , but still after looking at that price , most of my component are readily available on amazon , other than the 2 side plates that need to be water jet cut for the final version it cost a fraction of that worm gear setup .
      • mrehorstdmdundefined
        mrehorstdmd @Dad003
        @Dad003 I thought you were trying to simplify the design. Never mind.
        Dad003undefined 1 Reply Last reply Reply Quote 0
        • Dad003undefined
          Dad003 @mrehorstdmd
          @mrehorstdmd kinda but I want to keep cost down as well . From my early calcul this will be an expansive build about 3000 to 5000 $ at least . Depending of material to enclose the full printer.
          mrehorstdmdundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            mrehorstdmd @Dad003
            This post is deleted!
            • Dad003undefined
              Dad003
              Z axis assembled, i have more aluminum extrusion on the way so i should be able to fully assemble the frames . still have many part to prints , to test
              IMG_20240825_002244130.jpg IMG_20240825_002259059.jpg ,
              • Dad003undefined
                Dad003
                frame 1/2 assembled .
                IMG_20240825_164124459.jpg IMG_20240825_164135690.jpg IMG_20240825_164115181.jpg
                • Dad003undefined
                  Dad003
                  main frame of the beast is mostly done , i need to add a bar or 2 in one spot and that will be it for that .
                  IMG_20240826_214406473.jpg IMG_20240826_214353814.jpg IMG_20240826_214418960.jpg
                  • Dad003undefined
                    Dad003
                    IMG_20240830_071051157.jpg IMG_20240830_071039737.jpg IMG_20240830_071051157.jpg
                    250mm print bed it is , it will use a silicon heater from keenovo with a voron cutout. Need to reprint gantry , did some change to make it smaller lighter .
                    • Dad003undefined
                      Dad003
                      i Went with the LDO , super power HT for my build , they have nice spec for a quick machine and 180C temp max and since they will sit outside the heated chamber we should have a good margin. pick up the 55mm shaft version as well so i could add an extra bearing to support the end .
                      IMG_20240909_215057957.jpg IMG_20240909_224905446.jpg IMG_20240909_224944366.jpg
                      • Dad003undefined
                        Dad003
                        slowly been working on it , here a little update , ive been slowly ordering part, thinking and designing more things .
                        IMG_20241031_202912877.jpg IMG_20241031_202620263.jpg IMG_20241031_202632510.jpg
                        • Dad003undefined
                          Dad003
                          well him still slowly building this , still have to buy a duet 3 and an expansion board , but currently in canada there is no duet 3 6hc in stock anywhere , and i have to buy silicon heater for heated bed and heated chamber . anything else is already here , 12v psu for all the fan and water pump , 24volt for the expansion board and hotend , and 48v for the main mobo for xy axis. i need to print myself some riser for the din rail so they sit higher a bit so they are easier to wire .
                          IMG_20241226_182234719.jpg IMG_20241224_153822832.jpg IMG_20241224_214630934.jpg
                          • Dad003undefined
                            Dad003
                            well i think i got my layout all done now , had to go with some smaller cable tray for the top since i was a bit space restricted but it should be enough . fun part to come is to wire everything which is gonna be interesting lol , main duet will be on the right and expansion board on the left . both will have a 120mm fan to cool off the mobo . on top of the 3x120 sucking air for the radiator .
                            • Dad003undefined
                              Dad003
                              well here another little update , duet 3 6hc has been ordered , only things left is the expansion board and a few minor things to buy to get this baby online for some test .
                              hot end assembly minus water cooled loop and a few things. ended up going for a klicky for probe . it is sitting at the front of the air duct close of the nozzle .
                              • Dad003undefined
                                Dad003
                                started to work on some of my wiring a bit mostly for the hotend so far ,
                                • Dad003undefined
                                  Dad003
                                  Well my duet 3 6hc 1.02 finally arrived now waiting for the expansion board to show up and i will be able to finalize the wiring and fire this things up soon and do some test , my original plan was to run a single water cooled loop to the extruder and hotend but the tubing couldn't make the bend , so decided to use a Y splitter in the back that come from a bigger tube for the loop and split in 2 . than split back in 1 .
                                  T3P3Tonyundefined cosmowaveundefined 2 Replies Last reply Reply Quote 0
                                    T3P3Tony administrators @Dad003
                                    @Dad003 wow that looks like a lot of water. Is that water cooling form an existing design? I found when messing with watercooled hot ends years ago that very little water was actually needed as its such an efficient conductor of heat.
                                    Dad003undefined 1 Reply Last reply Reply Quote 1
                                    • Dad003undefined
                                      Dad003 @T3P3Tony
                                      @T3P3Tony it a Vzbot extruder and hotend , water cooled version , but the rest is just my own idea , like I said I wanted to do a single loop but couldn't have both cooled , the ultimate Goal is to have this things in a 80-100c heated chamber for Polycarbonate , will it stay like this I don't know , I have lots of testing to do .
                                      All pass throw a 360mm rads to cool off . Honestly can't wait to have this monster power on lol
                                      • cosmowaveundefined
                                        cosmowave @Dad003
                                        @Dad003 said in My Second build (in progress):
                                        Eventually, a spring over the tube helps against kinking?
                                        But this works only, when the tube isn't to stiff.
                                        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                                        • Dad003undefined
                                          Dad003 @cosmowave
                                          @cosmowave I didn't think of that .
                                          • Dad003undefined
                                            Dad003
                                            swapped my 3d printed bed base for some basic aluminum parts , they are a bit crude lol i have limited tool at my hand for that but they will be good enough .
                                            IMG_20250207_202859524.jpg IMG_20250207_201045456.jpg IMG_20250207_201552357.jpg
