Random Hard Fault resets on Duet 3 Mini WiFi
Started a long print last night and woke up to two messages in the console:
*** Memory difference at line 2228 offset 4: original 392e303d copy 00000168, original changed, copy ok, fix=yes
(the same message occurs twice; potential crash caught?) Printer has been stable otherwise.
Mine had a reset today while I was @work, but the only output in YAT is:
ok<LF> HTTP is enabled on port 80<LF> FTP is enabled on port 21<LF> TELNET is disabled<LF> CAN response timeout: board 121, req type 6054, RID 8<LF> Warning: Heater 1 predicted maximum temperature at full power is 543°C<LF> Log level is : debug<LF> Done!<LF> RepRapFirmware for Duet 3 Mini 5+ is up and running.<LF> WiFi module started<LF> WiFi module is connected to access point IoT, IP address 192.168.30.x<LF> HTTP is enabled on port 80<LF> FTP is enabled on port 21<LF> TELNET is disabled<LF> CAN response timeout: board 121, req type 6054, RID 8<LF> Warning: Heater 1 predicted maximum temperature at full power is 543°C<LF> Log level is : debug<LF> Done!<LF> RepRapFirmware for Duet 3 Mini 5+ is up and running.<LF> WiFi module started<LF> WiFi module is connected to access point IoT, IP address 192.168.30.x<LF>
Printed in one line on YAT, I just split it up for readabilty.
This is the M122 report:
2024-10-25 15:56:08 [debug] === Diagnostics === 2024-10-25 15:56:08 [debug] RepRapFirmware for Duet 3 Mini 5+ version 3.5.3+1dbg (2024-10-20 14:13:46) running on Duet 3 Mini5plus WiFi (standalone mode) 2024-10-25 15:56:08 [debug] Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ 2024-10-25 15:56:08 [debug] Used output buffers: 1 of 40 (39 max) 2024-10-25 15:56:08 [debug] === RTOS === 2024-10-25 15:56:08 [debug] Static ram: 103368 2024-10-25 15:56:08 [debug] Dynamic ram: 123956 of which 0 recycled 2024-10-25 15:56:08 [debug] Never used RAM 11572, free system stack 142 words 2024-10-25 15:56:08 [debug] Tasks: 2024-10-25 15:56:08 [debug] NETWORK(1,ready,18.9%,209) 2024-10-25 15:56:08 [debug] HEAT(3,nWait 6,0.0%,325) 2024-10-25 15:56:08 [debug] Move(4,nWait 6,0.0%,341) 2024-10-25 15:56:08 [debug] CanReceiv(6,nWait 1,0.1%,773) 2024-10-25 15:56:08 [debug] CanSender(5,nWait 7,0.0%,336) 2024-10-25 15:56:08 [debug] CanClock(7,delaying,0.0%,348) 2024-10-25 15:56:08 [debug] TMC(4,nWait 6,0.8%,101) 2024-10-25 15:56:08 [debug] MAIN(1,running,78.5%,665) 2024-10-25 15:56:08 [debug] IDLE(0,ready,0.8%,29) 2024-10-25 15:56:08 [debug] AIN(4,delaying,0.8%,259) 2024-10-25 15:56:08 [debug] , total 100.0% Owned mutexes: 2024-10-25 15:56:08 [debug] WiFi(NETWORK) 2024-10-25 15:56:08 [debug] USB(MAIN) 2024-10-25 15:56:08 [debug] === Platform === 2024-10-25 15:56:08 [debug] Last reset 05:58:26 ago, cause: software 2024-10-25 15:56:08 [debug] Last software reset at 2024-10-25 09:57, reason: HardFault ibus, Gcodes spinning, available RAM 11596, slot 0 2024-10-25 15:56:08 [debug] Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00000100 ICSR 0x00487803 BFAR 0xe000ed38 SP 0x20012038 Task NETW Freestk 494 ok 2024-10-25 15:56:08 [debug] Stack: 2002c620 200324a0 200014e4 00000000 20033689 000304b5 0d0a0d30 61010000 0d0a0d31 00000000 00000000 00000000 200120b8 00000014 000a0ea3 00000102 eeb20050 380aa8c0 080001ad 00000003 00034db1 2002c3b8 2002c3b8 00000001 0002fbf1 20011800 200114f8 2024-10-25 15:56:08 [debug] Error status: 0x00 2024-10-25 15:56:08 [debug] Aux0 errors 0,0,0 2024-10-25 15:56:08 [debug] MCU revision 3, ADC conversions started 16129917, completed 16129915, timed out 0, errs 0 2024-10-25 15:56:08 [debug] MCU temperature: min 35.5, current 35.9, max 38.8 2024-10-25 15:56:08 [debug] Supply voltage: min 3.8, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 2024-10-25 15:56:08 [debug] Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/580/152, gc cycles 4679 2024-10-25 15:56:08 [debug] Events: 1 queued, 1 completed 2024-10-25 15:56:08 [debug] Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 17785, writes 13, timeouts 0, DMA errors 0, CC errors 0 2024-10-25 15:56:08 [debug] Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 17784, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6f 2024-10-25 15:56:08 [debug] Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 50, reads 17783, writes 13, timeouts 0, DMA errors 0, CC errors 0 2024-10-25 15:56:08 [debug] Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 51, reads 17783, writes 13, timeouts 0, DMA errors 0, CC errors 0 2024-10-25 15:56:08 [debug] Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 17785, writes 13, timeouts 0, DMA errors 0, CC errors 0 2024-10-25 15:56:08 [debug] Driver 5: not present 2024-10-25 15:56:08 [debug] Driver 6: not present 2024-10-25 15:56:08 [debug] Date/time: 2024-10-25 15:56:08 [debug] 2024-10-25 15:56:08 2024-10-25 15:56:08 [debug] Cache data hit count 4294967295 2024-10-25 15:56:08 [debug] Slowest loop: 13.34ms; fastest: 0.16ms 2024-10-25 15:56:08 [debug] === Storage === Free file entries: 18 2024-10-25 15:56:08 [debug] SD card 0 detected, interface speed: 22.5MBytes/sec 2024-10-25 15:56:08 [debug] SD card longest read time 8.0ms, write time 4.4ms, max retries 0 2024-10-25 15:56:08 [debug] === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 2024-10-25 15:56:08 [debug] no step interrupt scheduled 2024-10-25 15:56:08 [debug] Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 2024-10-25 15:56:08 [debug] === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 2024-10-25 15:56:08 [debug] === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 2024-10-25 15:56:08 [debug] === Heat === 2024-10-25 15:56:08 [debug] Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 2024-10-25 15:56:08 [debug] Heater 1 is on, I-accum = 0.0 2024-10-25 15:56:08 [debug] === GCodes === 2024-10-25 15:56:08 [debug] Movement locks held by null, null 2024-10-25 15:56:08 [debug] HTTP is idle in state(s) 0 2024-10-25 15:56:08 [debug] Telnet is idle in state(s) 0 2024-10-25 15:56:08 [debug] File is idle in state(s) 0 2024-10-25 15:56:08 [debug] USB is ready with "m122" in state(s) 0 2024-10-25 15:56:08 [debug] Aux is idle in state(s) 0 2024-10-25 15:56:08 [debug] Trigger is idle in state(s) 0 2024-10-25 15:56:08 [debug] Queue is idle in state(s) 0 2024-10-25 15:56:08 [debug] LCD is idle in state(s) 0 2024-10-25 15:56:08 [debug] SBC is idle in state(s) 0 2024-10-25 15:56:08 [debug] Daemon is doing "G4 P250" in state(s) 0 0, running macro 2024-10-25 15:56:08 [debug] Aux2 is idle in state(s) 0 2024-10-25 15:56:08 [debug] Autopause is idle in state(s) 0 2024-10-25 15:56:08 [debug] File2 is idle in state(s) 0 2024-10-25 15:56:08 [debug] Queue2 is idle in state(s) 0 2024-10-25 15:56:08 [debug] Q0 segments left 0, axes/extruders owned 0x0000803 2024-10-25 15:56:08 [debug] Code queue 0 is empty 2024-10-25 15:56:08 [debug] Q1 segments left 0, axes/extruders owned 0x0000000 2024-10-25 15:56:08 [debug] Code queue 1 is empty 2024-10-25 15:56:08 [debug] === Filament sensors === check 0 clear 0 2024-10-25 15:56:08 [debug] Extruder 0 sensor: no filament 2024-10-25 15:56:08 [debug] === CAN === 2024-10-25 15:56:08 [debug] Messages queued 193567, received 440879, lost 0, errs 383, boc 0 2024-10-25 15:56:08 [debug] Longest wait 2ms for reply type 6053, peak Tx sync delay 10353, free buffers 26 (min 25), ts 107533/107532/0 2024-10-25 15:56:08 [debug] Tx timeouts 0,0,0,0,0,0 2024-10-25 15:56:08 [debug] === Network === 2024-10-25 15:56:08 [debug] Slowest loop: 13.86ms; fastest: 0.00ms 2024-10-25 15:56:08 [debug] Responder states: 2024-10-25 15:56:08 [debug] MQTT(0) 2024-10-25 15:56:08 [debug] HTTP(2) 2024-10-25 15:56:08 [debug] HTTP(0) 2024-10-25 15:56:08 [debug] HTTP(0) 2024-10-25 15:56:08 [debug] HTTP(0) 2024-10-25 15:56:08 [debug] FTP(0) 2024-10-25 15:56:08 [debug] Telnet(0) 2024-10-25 15:56:08 [debug] HTTP sessions: 6 of 8 2024-10-25 15:56:08 [debug] === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 2024-10-25 15:56:08 [debug] Firmware version 2.1.0 2024-10-25 15:56:08 [debug] MAC address c4:5b:be:ce:91:93 2024-10-25 15:56:08 [debug] Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39616 2024-10-25 15:56:08 [debug] WiFi IP address 192.168.30.x 2024-10-25 15:56:08 [debug] Signal strength -51dBm, channel 6, mode 802.11n, reconnections 0 2024-10-25 15:56:08 [debug] Clock register 00002001 2024-10-25 15:56:08 [debug] Socket states: 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] 0 2024-10-25 15:56:08 [debug] ok
@omtek yes, potential crash caught twice.
Three more messages overnight and this morning. They occurred after the printer was cooling down. Looks like another two potential crashes caught and averted. Still no resets to speak of.
*** Memory difference at line 2228 offset 52: original 20036658 copy 0d0a0d73, original ok, copy changed, fix=no
Still haven't had one single event on 3.5.3-debug other than that one without any output. So I'm moving back over to 3.6.0-debug again so that I can get some prints done.
With nothing happening in well over 72hours I doubt anything will tbh. -
After switching from the Maestro to the Mini 5 WiFi, my printer occasionally stopped or crashed without any apparent reason. I found this thread and installed the 3.6.0-debug firmware from dc42. Since then, I’ve completed over ten prints, including some taller than 150mm and others over 4 hours long, with no crashes. My printer is a CoreXY setup with dual Z-axis and a single extruder.
@jovo0911 thanks. I've established that this issue does not cause the same type of reset in 3.6.0 beta1 that it does in 3.5.x and 3.4.x. What I don't know is whether it causes any other issues in 3.6.0 beta1. I've also developed a workaround for the issue in 3.5.3.
Should I go back to 3.4.6 and wait? (The Maestro ran fine with that version.) I started with 3.5.0 on the Mini 5 and initially thought the board might have a hardware issue.
But now the printer is running smoothly with the 3.6.0-debug firmware. -
@jovo0911 the issue discussed in this thread is unique to the Duet 3 Mini WiFi.
@dc42 Here is some feedback from my side. For about a week I tried 3.6.0-beta1-2 on a Duet3Mini5 where everything was connected directly to the board. Good news: WiFi and printer ran without error. Observations:
YAP connects, but no data is displayed in YAP. M115 does not return anything.
The old home sequence doesn't work without change
; ========================================================================================================= ; home y axis ; ========================================================================================================= ; M400 ; wait for current moves to finish G1 H2 Y0.5 F1000 ; energise motors to ensure they are not stalled M400 ; wait for current moves to finish G1 H1 Y5 F1000 ; move slowly away G1 H1 Y-260 F1800 ; move quickly to x axis endstop and stop there (first pass) G1 H2 Y5 F1000 ; go back a few mm G1 H1 Y-10 F1800 ; move slowly to x axis endstop once more (second pass)
G28
Error: G1: Homing move abandoned because driver 3 is moving too slowly for stall detectionIt had to be changed to
; ========================================================================================================= ; home y axis ; ========================================================================================================= ; M400 ; wait for current moves to finish G1 H2 Y0.5 F2000 ; energise motors to ensure they are not stalled M400 ; wait for current moves to finish G1 H1 Y5 F2000 ; move slowly away G1 H1 Y-260 F1800 ; move quickly to x axis endstop and stop there (first pass) G1 H2 Y5 F2000 ; go back a few mm G1 H1 Y-10 F1800 ; move slowly to x axis endstop once more (second pass) ;
@dc42 Today I tried 3.6.0-beta1-2 on a Dual extruder where the extruders have a can board. So far, this works as well.
