    Duet3MB6HC with Duet3 scanning Z probe
    Using Duet Controllers
    1.1k
      jay_s_uk @R006
      @R006 said in Duet3MB6HC with Duet3 scanning Z probe:
      configure like this?
      M558 K1 P11 C"120.i2c.ldc1612" F36000 T36000
      M308 A"SZP coil" S10 Y"thermistor" P"120.temp0"
      G31 K1 Z2 Y-17
      M558.2 K1 S15 R101133
      M557 X-140:140 Y-90:80 S10
      But I have only one Z probe for leveling, so I do not need to use the K parameter, right?
      Correct.
      I've only used one to scan the bed. You may be able to set it up for auto levelling
      R006undefined 1 Reply Last reply Reply Quote 1
      • R006undefined
        R006 @jay_s_uk
        @jay_s_uk
        okay.
        this is my bed.g. it's correct or i have to change it?
        ; P 1
        G30 P0 X150 Y150 Z-9999
        ; P 2
        G30 P1 X150 Y450 Z-9999
        ; P 3
        G30 P2 X450 Y450 Z-9999
        ; P 4
        G30 P3 X450 Y150 Z-9999 S4
        auto-levelling done with scan probe? or i have to use bl-touch for that?
          jay_s_uk @R006
          @R006 looks fine to me
          • R006undefined
            R006 @R006
            @jay_s_uk
            How does auto-levelling work with this? Do I have to use a BLTouch for auto-levelling?
              droftarts administrators @R006
              @R006 Like all inductive probes, the SZP coil reading changes with temperature, so you need another probe to set the Z offset each time, unless you are always using it at the exact same temperature.
              I think you have used the gcode from the SZP wiki page to configure your probe, but you need to calibrate it for you specific machine, see https://docs.duet3d.com/User_manual/Tuning/scanning_z_probe_calibration#calibration
              Once the Z offset is set, and the SZP is calibrated, you should be able to use it for auto-levelling. Use G30 with the K parameter to tell it what probe to use, in your case K1, eg
              G30 K1 P0 X150 Y150 Z-9999 ; P1
              G30 K1 P1 X150 Y450 Z-9999 ; P2
              G30 K1 P2 X450 Y450 Z-9999 ; P3
              G30 K1 P3 X450 Y150 Z-9999 S4 ; P4
              R006undefined 1 Reply Last reply Reply Quote 0
              • R006undefined
                R006 @droftarts
                @droftarts
                okay, thanks.
                I am having trouble selecting the input port for the scan probe in the RRF configuration tool.
                I am only using a scanning Z probe for auto-levelling and mesh bed compensation, but I am confused about how to configure it. (it's possible with scan Z probe?)
                Could you please explain how to set this up and provide example files for bed.g and config.g?
                and which input pin i have to used from Duet3 EXP1XD?
                  The SZP is CAN connected, so it should have a CAN address. If your CAN wiring is correct, and you haven't changed the CAN address on the SZP, it should be 120. You can check in DWC if it is showing up, in Settings > Machine-Specific, or look under 'boards' in the Object Model plugin.
                  The example I gave above is the bed.g file, using the second probe. You already have it set up in config.g. However...
                  This makes me think you haven't understood how to wire the SZP. Please post a picture of your wiring to the SZP.
                  You need to connect:
                  • the CAN wires from the CAN OUT of the EXP1XD to the SZP. This will be an RJ11 connector from the 1XD, wired to the 4-pin JST PA connector on the SZP. Make sure you connect CAN_L from the 1XD to CAN_L on the SZP, and CAN_H from the 1XD to CAN_H on the SZP
                  • the power wires, which require 5V and GND. You could connect these from IO0, IO1 or IO2 on the 1XD, to the 4-pin JST PA connector on the SZP.
                  Lastly, CAN termination. Assuming you have the termination jumpers on the last 1XD on the CAN bus, then:
                  • if then CAN wire to the SZP is LESS than 1m, you should be able to connect the SZP as a 'stub', and leave the CAN termination jumpers on the 1XD.
                  • if the CAN wire between the 1XD and SZP is MORE than 1m, you will need to remove the CAN termination jumpers from the 1XD, and solder the CAN termination jumper on the back of the SZP, see https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#terminating-resistor
                  • R006undefined
                    R006 @droftarts
                    @droftarts
                    Thank you for the explanation.
                    Please check the code below.
                    M558 P11 C"41.EXP1XD" F36000 T36000
                    G31 Z2 Y0 X0
                    M558.2 S15 R101133
                    M557 X0:550 Y0:550 S20
                      This is incorrect. The SZP is a completely separate CAN board from the 1XD, so the C parameter should reference the SZP directly, not the 1XD. Your C parameter isn't even a real pin. The SZP should show up in the list of CAN boards in DWC > Settings > Machine-specific. Please show how you have wired it.
                      If you have another probe, eg BLTouch, you need to specify the SZP as another probe with the K parameter. So it should look like the documentation https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#scanning-z-probe ie:
                      • R006undefined
                        R006 @droftarts
                        @droftarts @dc42
                        hey, sorry for the late reply.
                        I have attached an image of the wiring for the SZP with the Duet3 and its configuration.
                        SZP configuration in config.g
                        M558 K0 P11 C"120.i2c.ldc1612" F36000 T36000    ; Configure SZP as probe 1, type 11, on CAN address 120
                        M308 A"SZP coil" S10 Y"thermistor" P"120.temp0" ; Thermistor on SZP coil
                        G31 K0 Z2 Y-17                                  ; Define probe 1 offsets and trigger height
                        M558.1 K0 S1.7.
                        M558.2 K0 S15 R101133                           ; Set drive current and reading offset
                        I am doing the following steps using DWC. Please check this. However, when I run G30 K0 S-1, it gives the following error:
                        G30 K0 S-1
                        Error: M300: Probe already triggered at start of probing move
                        DWC Commands & it's output:
                        G30 K0 S-1
                        M558.1 K0
                        Scanning probe coefficients [-4.805e+0, -3.410e+0, 0.000e+0, 0.000e+0]
                        Scanning probe coefficients [-4.805e+0, -3.410e+0, 0.000e+0, 0.000e+0], reading at trigger height 9050, RMS error 4.143mm
                        M558.2 K0 S-1
                        Calibration successful, sensor drive current is 15, offset is 135750
                        M558.2 K0
                        Sensor drive current is 15, offset is 101133
                        M558
                        Z Probe 0: type 11, input pin 120.i2c.ldc1612, min interval 2ms, dive heights 5.0,5.0mm, probe speeds 36000,36000,36000mm/min, travel speed 36000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
                        I have some questions:
                        1. Is it necessary to connect the BL-Touch the first time to calibrate the Z height?
                        2. I am doing tabletop testing. Is this the correct way to calibrate the SZP, or should it be done on the machine?
                        3. Please check my configuration and wiring of the SZP. Is it correct?
                        4. Could you please explain a simpler way to calibrate it? I have read the documentation, but it is quite difficult to understand.
                          No, but you need to set the Z height somehow. As we say here https://docs.duet3d.com/en/User_manual/Tuning/scanning_z_probe_calibration#calibration
                          Set the Z datum (Z=0), either by homing Z using another probe, or by moving the nozzle to just touch the bed and send G92 Z0.
                          It should be done on the machine. The SZP coil needs to be set at the correct height ie 4-5mm above the bed surface for calibration.
                          There's an extra full stop after the M558.1 line in your config.g. Probably not that important:
                          M558.1 K0 S1.7.
                          I can't tell regarding the wiring. Have you soldered the SZP 5V, GND and CAN wires to the back of the 1XD? Do the CAN synchronisation LEDs flash in time? Does the SZP show up in the list of boards in DWC, and are the firmware versions the same? Do you get a response if you send M122 B120?
                          I can't see the coil. Is it under the SZP board? If so, most likely it is picking up the SZP board, and is too close, which is why you get the 'already triggered' message.
                          It's going to be impossible to calibrate it fully in a bench set up. It needs to be mounted to a machine. See the mounting instructions here: https://docs.duet3d.com/en/User_manual/Tuning/scanning_z_probe_calibration#mounting
                          You might just be able to do the M558.2 calibration (drive level and reading offset) on a bench setup, if you can hold the coil securely 4mm above a surface that mimics the bed (it must be metallic). But the M558.1 calibration (height vs reading) will be impossible unless you have it set up on a Z stage for accurate movement. And, most likely, both of these calibrations will change once you put it on the machine.
                          If there's a specific part you are struggling with, please let me know.
                          R006undefined 2 Replies Last reply Reply Quote 0
                          • R006undefined
                            R006 @droftarts
                            Thank you @droftarts
                            M558.1 K0 S1.7.
                            it's typing mistake.
                            In my setup, I am using only the SZP. When I run G30 K0 S-1, it gives me the error "Probe already triggered at start of probing move."
                            Can I use G30 K0 S-1 to measure the height from the bed to the SZP?
                            I have mounted the SZP 4mm above the bed, and at X0 Y0 Z0, the calibration data is:
                            "Scanning probe coefficients [4.546e-1, -3.829e-4, -8.222e-10, 1.247e-15]"
                            Where should I set this calibration data?
                            @droftarts @dc42 @Phaedrux
                            • R006undefined
                              R006
                              @droftarts, I am waiting for your response.
                              Please check my config.g file:
                              M558 K0 P11 C"100.i2c.ldc1612" F36000 T36000    ; configure SZP as probe 1, type 11, on CAN address 120
                              M308 A"SZP coil" S10 Y"thermistor" P"100.temp0" ; thermistor on SZP coil
                              G31 P500 K0 Z3 Y-17 H10                                 ; define probe 1 offsets and trigger height
                              M558.2 K0 S23 R164530
                              M558.1 K0 S2
                              Let me know if I am doing something wrong.
                              At some points, I get trigger heights like 3.00, -2.55, or -2.99.
                              In DWC, my Z-probe value is not steady; it fluctuates between 0, 9097, and 999999.
                              why does it fluctuate? @droftarts
                              I am using a proximity sensor for homing the Z-axis.
                              • R006undefined
                                R006 @droftarts
                                @droftarts
                                i am waiting for your reply.
                                  @R006 Apologies for the slow reply, I was away for an extended period of time over Christmas and New Year, and have finally caught back up.
                                  If you mean the SZP is 4mm above the bed when the nozzle is touching the bed, this is wrong. Yes, the SZP should be calibrated 4mm above the bed, but the nozzle should not be on the bed. Ideally, the SZP should be 4mm above the bed when the nozzle is 2mm above the bed, ie at Z2, so that it doesn't hit the bed when scanning. See https://docs.duet3d.com/en/User_manual/Tuning/scanning_z_probe_calibration#mounting
                                  We advise NOT setting this, but calibrating each time you do a SZP scan. This is because the SZP coil readings change with temperature. It is possible to set it and add it to config.g; see https://docs.duet3d.com/User_manual/Reference/Gcodes#m5581-calibrate-set-or-report-height-vs-reading-of-scanning-z-probe
                                  When setting, ignore the first parameter reported from the calibration. The 2nd, 3rd and 4th are A, B and C. Your result of "Scanning probe coefficients [4.546e-1, -3.829e-4, -8.222e-10, 1.247e-15]" would become:
                                  M558.1 K1 A-3.829e-4 B-8.222e-10 C1.247e-15
                                  This calibration seems high, and is probably causing the fluctuating readings. I'd guess that you moved up from Z0 to Z2 or Z4, so the SZP is actually 6 or 8mm from the bed when you did the calibration. A typical drive level is around 15 for the 12mm coil. Which coil are you using? Higher or lower drive level settings may cause sporadic 999999 readings. If you get these, try adjusting the Z height you do the M558.2 K1 S-1 calibration at.
                                  • R006undefined
                                    R006 @droftarts
                                    @droftarts thank you for reply.
                                    i am try both coil 12mm and 15mm, but the value is fluctuates between 0, 9097, and 999999.
                                      @R006 What is the bed surface? It needs to be metal on, or near the surface (under a PEI sheet is okay), ie not have glass on top.
                                      Are you setting the M558.2 calibration with the SZP coil around 4mm from the bed?
                                      When you say "the value is fluctuates between 0, 9097, and 999999" are these the only three readings? Or does it give other readings? I'd usually expect to see readings in the range 1500 (Z6) to 15000 (Z0.3). You shouldn't get 0 or 999999 readings.
                                      Random 999999 readings can be caused by:
                                      • Interference on the SZP ribbon cable (from SZP to coil). Makes sure to route the SZP ribbon cable away from the coil, ie make sure it doesn't go over the coil
                                      • Poor ribbon cable contact. Ensure it is FULLY inserted into the tiny connector, at both ends. Try reseating this if you continue to get erratic readings
                                      • Make sure there is no metal in the 30mm ABOVE the coil, or it will pick this up and give false readings
                                      What firmware version are you running on the 6HC and SZP?
