    Voron 2.4 duet 5 mini pauses every 12 seconds when printing
    2.7k
    • cdoeundefined
      cdoe @Phaedrux
      @Phaedrux Thanks for helping me figure this out..
      There's no commonality i can figure out, tbh. It's also visible (in form of blobs) in vase mode as well - which from what i understand shouldn't have any pauses or layer changes at all?
      Issue occurs even when heightmap/bed compensation is disabled.
      I'm trying to "port" my profile to cura to see if this is a slicer issue.
      resamundefined 1 Reply Last reply Reply Quote 0
      • resamundefined
        resam @cdoe
        @cdoe are you running with an SBC / Raspberry Pi?
        I recall similar issues with my printer when there was a lot of tiny moves due to high-fidelity / super smooth geometry that resulted in SPI data transfer queue issues.
        I was able to work-around the issue by tweaking the SPI and transfer queue sizes in the DSF config.
        cdoeundefined 1 Reply Last reply Reply Quote 0
        • cdoeundefined
          cdoe @resam
          @resam I don't - setup is running in standalone mode. But that gave me an idea. I think next step would be to check if there's an issue with toolboard - maybe some sort of issue with canbus throughput?
          Reslicing with cura didn't help though - still having this periodic pauses 😞
          • infiniteloopundefined
            infiniteloop @cdoe
            @cdoe Do you use a daemon.g file? If so, what’s its content?
            cdoeundefined 2 Replies Last reply Reply Quote 1
            • cdoeundefined
              cdoe @infiniteloop
              @infiniteloop
              I do:
              ;#################### Electronics Bay Fan ###########################
              if move.axes[0].homed || move.axes[1].homed || move.axes[2].homed         ; check whether X, Y or Z drivers are active
                M106 P2 S0.85 H-1                                                       ; fan 2 runs at 80%
                M106 P3 S0.85 H-1                                                       ; fan 3 runs at 80%
              else
                M106 P2 S0                                                              ; if not, turn off the electronics bay fan 2
                M106 P3 S0                                                              ; if not, turn off the electronics bay fan 3
              ; heater 0 - bed
              ; heater 1 - hotend
              if heat.heaters[1].current > global.hotSenseTemp
                M98 P"/macros/led/indicator_hot"
              elif heat.heaters[1].current > global.warmSenseTemp
                M98 P"/macros/led/indicator_warm"
              else
                M98 P"/macros/led/indicator_cold"
              • cdoeundefined
                cdoe @infiniteloop
                @infiniteloop thank you - the issue is with daemon.g
                in particular with calling macros which change led colour
                Here's indicator_warm content:
                ; Set led on stealthburner to warm colour
                M150 E0 R222 U201 B95 P96 S1 F0
                T3P3Tonyundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                  T3P3Tony administrators @cdoe
                  @cdoe
                  try enclosing the whole daemon.g code in a while loop with a reasonable pause between each execution, so that the daemon is not reopening the file every ~10 seconds.
                  https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#daemong
                  e.g.:
                  while true
                    else
                    ; heater 0 - bed
                    ; heater 1 - hotend
                    else
                    G4 S5 ; wait 5 seconds before looping
                  • cdoeundefined
                    cdoe @T3P3Tony
                    @T3P3Tony Thanks for the tip.Will try this out.
                    I think this can be marked as solved (not sure how to do that).
                      infiniteloop @cdoe
                      @cdoe
                      @T3P3Tony already told you how to avoid the time to permanently reopen the daemon.g file. The same is true for calling the colour-change macros. As these are simple one-liners, you might want to incorporate these M150 calls into daemon.g directly.
                        T3P3Tony administrators @infiniteloop
                        @infiniteloop yeah good point
                        • T3P3Tonyundefined T3P3Tony marked this topic as a question
                        • T3P3Tonyundefined T3P3Tony has marked this topic as solved
                        • cdoeundefined
                          cdoe
                          After updating my daemon.g to
                          while true
                            else
                            ; Toolhead led based on temp
                            ; unfortunately seems like this will pause move
                            ; heater 0 - bed
                            ; heater 1 - hotend
                              M150 E0 R222 U95 B188 P96 S1 F0
                            else
                              M150 E0 R96 U223 B223 P96 S1 F0
                          I'm still observing a slight pause (now every ~5 seconds).
                          Looking through Changelog M150 and its interaction with movement are mentioned couple of times. In particular "M150 commands are now queued to sync them with movement commands" (feature in 3.2) - and there were couple of fixes later on around that functionality is it possible that this is causing a pause?
                          Is there a way to check if movement buffer / queue is empty or not when that M150 in my daemon.g is executed?
                            @cdoe try commenting those out in daemon.g for now and see if the pauses go away.
                            • T3P3Tonyundefined T3P3Tony has marked this topic as unsolved
                            • cdoeundefined
                              cdoe @T3P3Tony
                              @T3P3Tony I did and pauses went away, so i strongly suspect it's M150 and movement buffer interaction
                              Just in case, here's how leds are configured (wired on sht36 toolboard):
                              M950 E0 C"124.rgbled" T1
                              gloomyandyundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                              • gloomyandyundefined
                                gloomyandy @cdoe
                                @cdoe As explained here in the M150 documentation:
                                However, when using an output other than the dedicated LED output on Duet 3 boards, in order to meet the precise timing
                                requirement of Neopixel LEDs, RRF waits for all motion to stop and then disables interrupts while sending the LED data.
                                During this time input data from UARTs may be lost, especially if there are a lot of LEDs to update. Therefore you should use the dedicated LED port if available.
                                If the output device is not able to use dma to update the pixel then motion will be paused. I don't think any of the existing toolboards (either Duet3D ones or the boards supported by teamgloomy) are configured to use dma output. I think that in theory the rp2040 based boards should be able to use pio mode (a form of dma i/o) to update the pixels but that is not currently the case. I'll take a look at possibly enabling that capability in 3.6, but I will need to verify that it works ok.
                                For now I suggest that rather than setting the state of the pixels every time through your script loop you modify the code to track the current state of the pixels and only call M150 when things change. That should reduce how often your print needs to pause.
                                cdoeundefined 1 Reply Last reply Reply Quote 1
                                  @cdoe ad @gloomyandy says, it looks like updating the LEDs wile printing is going on is not a good idea. Given that the lights only need to change when its changing from cold->warm->hot then an option could be to check to ensure the state.status was not "printing" and only change them using the deamon.g file when the job is not processing (i.e state.status |="processing") . That does mean that heating commands in start gcode at the beginning of a job file wont change the LEDs however you could get around that bu checking ot to the warm colour when starting to heat and then to the hot colour when heated?
                                  • cdoeundefined
                                    cdoe @gloomyandy
                                    @gloomyandy @T3P3Tony Thanks for ideas and suggestions. Now it makes sense - i'll rework daemon.g to only change colour if needed rather than just blindly doing so
                                    gloomyandyundefined 1 Reply Last reply Reply Quote 1
                                    • Phaedruxundefined Phaedrux has marked this topic as solved
                                      gloomyandy @cdoe
                                      @cdoe A quick update, it looks like this is actually a bug in RRF. The rp2040 expansion boards are actually operating in pio mode, but RRF is losing track of that information. It's only obvious if you have a rp2040 based board or are using a mainboard in expansion mode. Current Duet toolboards do not use dma for the led output so they will generate a pause anyway.
                                      The fix is here: https://github.com/Duet3D/RepRapFirmware/commit/5127e951e9b89b9d213de74b66e0dfc261a8ea40 and should be included in furure releases.
                                      However it is almost certainly a good idea to reduce how often you set the led state if you can.
                                      0 dc42 committed to Duet3D/RepRapFirmware
                                      Fixed clearing of DMA-capable flag in M150 to CAN-connected boards
                                      cdoeundefined 1 Reply Last reply Reply Quote 3
                                      • cdoeundefined
                                        cdoe @gloomyandy
                                        @gloomyandy thanks for the update. Appreciate tracking this one down
