Roto Toolboard, no extruder motor motion?
@Phaedrux Entering that command to the console at the web interface produces no output.
07/01/2025, 22:13:36 M98 P"config.g" 07/01/2025, 22:12:21 M98 P"config.g" 07/01/2025, 20:53:30 Connection established
Do you experience the same issue on 3.5.4 stable release?
@Phaedrux I haven't run this configuration with 3.5.4. With the previous setup, upgrading to 3.5.4 broke the setup and the board firmware became corrupt and had to recover with a usb cable. So I upgraded to the latest beta on the board and sbc and all has been working well.
I presume it's not a simple task to downgrade both boards and all the sbc packages to a previous version?
@bug2k22 you should be able to run the following
M997 S2 F"stable-3.5" M997 S2
and that should downgrade you to 3.5.4
@jay_s_uk Does that downgrade the boards and all sbc (pi5) packages too?
@bug2k22 yes, it should do
If it only downgrades DSF/DWC you can then issueM997
andM997 B20
to flash the firmware to the mainboard and toolboard -
@jay_s_uk The second M997 S2 command did flash up a notice saying it was upgrading, but nothing seems to have changed, restarting the board shows the 3.6.0-beta.2 firmware on all boards and the sbc packages are still on 3.6.0-beta.2.
If I ssh in to the pi, I see that the duet3d.list is now showing "deb https://pkg.duet3d.com/ stable-3.5 armv7" so it is on the stable channel but nothing downgrades. -
@bug2k22 try running
M997 S2 V"3.5.4"
@jay_s_uk Thanks, that did complete the downgrade on all boards and the pi.
Duet 3 MB6HC MB6HC 3.5.4 Duet 3 Expansion TOOL1RR TOOL1RR 3.5.4 Duet Software Framework DSF 3.5.4 Duet Web Control DWC 3.5.4
This has not changed the behaviour, still no movement on the extruder motor.
I have just double checked the cable from the toolboard to the motor and connectivity is fine on all pins. -
@bug2k22 in that case i'll leave you back with @Phaedrux or @droftarts
@bug2k22 Can you try moving your M906 (set motor current) to after the M584, for both the XYZ axes and E? See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m906-set-motor-currents
Order dependency
This command must be later in config.g than any M584 command.Ian
@droftarts Thanks Ian, it's now working!
I didn't look at M906 as it seems to work with the extruder connected directly to the 6HC even with it early in the config. Something to remember for future installs.
@bug2k22 It would have been reverting the currents to the defaults, I think. I'm not sure what the Roto default is, may be 400mA, as it usually expects a Roto extruder, which uses a lower current motor, so might just not had enough current to turn yours.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
