    Cannot connect to Wifi
    303
    • Timothee Leblondundefined
      Timothee Leblond @Phaedrux
      @Phaedrux Thanks for your answer.
      From what I understand, the network might be 5Ghz... do you know if using a raspberry PI connected to the mainboard could allow the connection to 5Ghz networks?
      Thanks for your help,
      Tim
        Yes you could use SBC mode with a Pi. The Pi has greatly expanded network options and would take over for the Duet in that regard.
        Timothee Leblondundefined 1 Reply Last reply Reply Quote 0
          @Phaedrux
          Thank you for your help. I'll add a Raspberry then.
            droftarts administrators @Timothee Leblond
            @Timothee-Leblond Most routers have the option to broadcast a 2.4GHz SSID as well as 5GHz. Check the router manual.
              Timothee Leblond @droftarts
              @droftarts
              I sadly cannot access the routers.. But I then have questions concerning SBC set up.
              I already have the motherboard configured and access to DWC through the local network but want to add the raspberry PI.
              Do you know if adding the SBC will replace my files like config.g and so on? I do not want to lose the files I edited already.
              Thank you!
                @Timothee-Leblond You have to remove the SD card from the Duet, so no, it won't replace them. You will need to copy them on to the RPi; you can do this after you connect to DWC on the RPi. You'll need to remove the networking parts of config.g for use on the RPi.
                  @droftarts
                  For now I've been following the SBC setup guide here until step 4.
                  I thus have 2 SD cards, one in the Duet and one in the RPi for now. What you mean is that I'll have to remove the one in the Duet and copy the files in the RPi card and erase the one that had been created by the Raspberry imager?
                  Thank you!
                    @Timothee-Leblond No, the one created by the imager stays in the RPi. It will also hold the config files for the Duet in SBC mode. To get the Duet into SBC mode, no SD card should be inserted into that. So you can keep the old SD card from the Duet as a backup.
                      @droftarts
                      So then can I copy my initial files on the RPi 's card? Like config.g, homeall, macro file, etc?
                      Or should I start from scratch again?
                      Also, should my panelDue stay on the Duet or should I connect it to the RPi?
                      Thanks!
                        @Timothee-Leblond said in Cannot connect to Wifi:
                        You can use your existing config files, very little change is needed. As I said earlier, you will need to copy them on to the RPi; you can do this after you connect to DWC on the RPi. You'll need to remove the networking parts of config.g for use on the RPi.
                        PanelDue stays connected to the Duet.
                          @droftarts
                          Ok, so I plugged the SBC to the Duet following your advice.
                          It seems like it does not connect to Wifi still. It says "connecting" on the top right corner of my PanelDue. When looking for "duet3.local" in my browser, it keeps loading infinitely.
                          I'm trying to follow the troubleshooting steps but I cannot connect it at all to the router.
                          Do you know if the MAC adress is different from the Duet's? Do you think this could be the problem? I'm pretty sure I've configured the wpa_supplicant.conf correctly.
                          Thank you for your precious help!
                            Phaedrux Moderator @Timothee Leblond
                            Yes, most certainly. So if you need to provide the network admin the MAC address of the Pi, you'll need to find it on the Pi.
                            https://pimylifeup.com/raspberry-pi-mac-address/
                            The mDNS name duet3.local may or may not work on that network. You may need to use the IP address directly.
                              @Phaedrux said in Cannot connect to Wifi:
                              Thanks for your help! However it seems that guide provide help to retrieve the MAC address when it's connected to a network, which is not my case. Any idea how I can get the MAC without Wifi or Ethernet?
                              Thanks again,
                              T3P3Tonyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                T3P3Tony administrators @Timothee Leblond
                                @Timothee-Leblond are you sure ip link show only works with interfaces that are connected?
                                  @Timothee-Leblond See https://raspberrytips.com/mac-address-on-raspberry-pi/
                                  Send ifconfig in a Raspberry Pi Terminal window.
                                    @droftarts
                                    Good morning,
                                    Sorry It took it more time than expected.
                                    Here is where I am now. I got the wifi running on the Raspberry Pi after registering the MAC address to my IT department. Once I plug in the Raspberry PI into the Duet3, I can see both communicating.
                                    But I still can't connect to the DWC through Wifi using my Macbook. I tried both using duet3.local and using the IP of the RPi but nothing is working.
                                    I also tried following this configuration guide on Raspberry's website but I'm getting an error when trying to configure Wi-Fi SSID and passphrase.
                                    Would you have any ideas to solve this?
                                    Thank you,
                                    Timothee
                                      @Timothee-Leblond If the RPi can connect to the network/internet, I'd guess that there is something stopping incoming connections to the RPi, possibly blocked at the router. Check with your IT department.
                                      Another way to test would be to set the RPi in access point mode, which you can also do with the Mini 5+ in standalone mode. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
                                      Then your PC can connect directly to the WiFi network that creates.
                                      troydemingundefined 1 Reply Last reply Reply Quote 0
                                      • troydemingundefined
                                        troydeming @droftarts
