    Dead SSR or Bed Heater?
    454
      Have you tested your bed output with something like a fan to confirm that it's switching correctly?
      Electriceyeundefined 1 Reply Last reply Reply Quote 0
      • Electriceyeundefined
        Electriceye @Maestro
        @Maestro
        Yeah, I thought about that and remembered the circuit breaker in this room is only 15A so that would probably trip right away and might not even be enough time to see what, if anything happens.
        Since this is a 120 volt mains bed heater, I'm a bit reluctant to push things too far.
        Without cycling or pulsing the AC to the bed I'd be afraid it would just melt it instantly.
        Oh and I HATE electro shock treatments, they just ruin my day. 😦
        Thanks for the suggestion, though!
        • Cheers!
        Maestroundefined 1 Reply Last reply Reply Quote 0
          Electriceye @Phaedrux
          @Phaedrux
          Now that's an idea... now what to hook up? Would a small appliance type fan rated at 120 volt suffice?
          I have a small ULINE desktop fan I wouldn't mind sacrificing to the AC gods if need be.
            I'm suggesting you test the Duet output directly, not the SSR outputs. A DC fan that matches your VIN voltage.
            Though if you're measuring the correct 120v from the SSR output already and it's switching correctly then testing the Duet output is moot.
            I'd be more inclined to suspect the SSR rather than the heater itself.
            What are the specs of the SSR? Do you have another to test with?
            Electriceyeundefined 1 Reply Last reply Reply Quote 1
              @Phaedrux
              Yep. All good points.
              This leads me back to my original post findings, voltages are there...but that little LED indicator light on the SSR has never turned on, that I have seen. That puts us full circle...is it the bed heater or SSR?
              Now I'm thinking you are right...it might just be the SSR.
              I have a new one (different brand) and the bed heater on order already...just have to wait until they arrive. Sigh.
              jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
              • Maestroundefined
                Maestro @Electriceye
                @Electriceye A 1000W heater should not trip a 15amp breaker; it only draws about 8.5 amps. If your heater matches your bed mass appropriately it should not be melting instantly, either. Everything is pointing to the SSR not working.
                But as @Phaedrux notes, you can attach something else to either side of the relay to test function, so long as that something else is rated for the appropriate voltage and won't pull too much current.
                  Well in that case it may be a good idea to test the Duet output with a fan, just to ensure it's working properly.
                  For testing the 120v side you could wire up a light socket, but only if you're absolutely comfortable working with 120v.
                    @Phaedrux
                    24 v DC fan works perfectly connected to the 24 volt side of the SSR, turning on and off as commanded by the Duet output.
                    Light bulb test coming up! This is really getting old, many thanks to all for the input & suggestions!
                    • jumpedwithbothfeetundefined
                      jumpedwithbothfeet @Electriceye
                      @Electriceye looking at your picture the input wires on the SSR from the duet are reversed you may want to try reversing the polarity,
                      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                      Electriceyeundefined 1 Reply Last reply Reply Quote 4
                        Electriceye @jumpedwithbothfeet
                        @jumpedwithbothfeet
                        WINNER WINNER!
                        Fried Chicken dinner! 😁
                        You sir..are correct!
                        The clue I should have guessed was that the LED on the SSR was not illuminating...LEDs are polarity sensitive!
                        The image I was going by (duet3_mini5+_v0.5-v1.02_d1.5_wiring.png) was upside down as viewed on the screen, as opposed to the direction I have it mounted. GREAT CATCH!
                        Board now heats up (quickly I might add) and the LED on the SSR is aglow!
                        jumpedwithbothfeet wins the internets today!
                        Thanks to ALL who had tips, suggestions and input. You people ROCK!
                        • Phaedruxundefined Phaedrux has marked this topic as solved
