    RRF to Duet3 6HC
    241
    • agz90undefined
      agz90
      Problem installation firmware to Duet3 6HC v 1.02
      agz90undefined 1 Reply Last reply Reply Quote 0
      • agz90undefined
        agz90 @agz90
        @agz90 said in RRF to Duet3 6HC:
        Hello, I have a problem installing the rap rap on the board. I load the latest rap rap with Bossa, it saves it, but when I check it, it gives me an error and the board doesn't start.
          How are you checking it?
          What error does it report?
          Are you following these steps to flash the firmware?
          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
          • agz90undefined
            agz90 @Phaedrux
            @Phaedrux said in RRF to Duet3 6HC:
            Yes, I followed all the steps exactly as described. Checked with Bossa verify. My problem is that I thought I could install Clipper on the board, apparently I deleted the boot file and now it doesn't work. I don't know how to restore the rep rap on the board.
            • agz90undefined
              agz90 @agz90
              @agz90 ![alt text](изображение_2025-03-07_000643135.png image url)
              • agz90undefined
                agz90 @agz90
                @agz90 install firmware 3.6.0 Release Candidate 1
                  Make sure your bossa check boxes match this
                  Try this bin file for 3.5.4
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.4/Duet3Firmware_MB6HC.bin
                    dc42 administrators @agz90
                    @agz90 also make sure that you remove the Erase jumper before you command Bossa to flash the firmware.
