    Sovol SV08 Multiple Motion System Upgrade.
    My Duet controlled machine
    8
    255
    30.2k
    • dwuk3dundefined
      dwuk3d @o_lampe
      @o_lampe yes - probably need to properly align belts in next stage.
      I'm also thinking of trying the probe at some different angles to see whether the alignments of the two gantries are the same with the probe at different places on the bed.
      I quite like the look of the new BambuLab H2D special alignment print bed - using camera's on the print head to read tiny qr codes at pre determined places.
      • dwuk3dundefined
        dwuk3d
        Made a start on IDEX motor and pulley mount (above side gantry supports) - will hold the idler at the back from the top took and introduce a tensioning system.
        Zip Ties just temporary until I have the new top of gantry belt coupling.
        Will have a mirror of the motor mount and idler on the other side.
        The new motors at the front on each side will take over the Y axis movement - with the existing X & Y used for one print head each on the rear gantry.
        Also tidied up extruders a bit and created top cover for 1LC boards.
        • dwuk3dundefined
          dwuk3d
          starting to think about my occasionally moving bed phase.
          My original idea for an occasionally moving bed was to allow for the printing of longer thin objects.
          But my experience of even printing fairly small object is that the area where both print heads can access without hitting each other is quite restricted - so I think even the current size 350x350 bed moving maybe only 150mm would give some quite big benefits with very little overhang outside of the main printer body.
          I think though that I want to go to 350 x 500 or even 350 x 550 - so that when parked the bed still fits nicely within the main printer size - but also allows for ships like the one shown (at 1:500 scale model) to be printed in one go.
          Another interesting concept when thinking about ships - is the bow - which overhangs - that doesn't need a build plate under it - so would be an interesting concept having a print going completely beyond the build surface.
          o_lampeundefined 1 Reply Last reply Reply Quote 1
          • o_lampeundefined
            o_lampe @dwuk3d
            @dwuk3d In the end we'll see a conveyor belt bed with dozends of tools heads zipping around simultaneously... 😳
            But seriously: you could do the same split_the object_trick in a big scale manner.
            • Build two independent printers with 4 heads each
            • place them above the looong conveyor belt with a certain gap
            • print parts 1 + 3
            • move the belt and print part 2 + 4
            • move back and repeat
            dwuk3dundefined 1 Reply Last reply Reply Quote 0
            • dwuk3dundefined
              dwuk3d
              My response to Advantages and disadvantages of Dual Gantry over IDEX and Tool changers as asked by @MostlyMessingAbout
              Advantages of Dual Gantry over IDEX
              1. Additional degree of freedom in Y Axis - allows for parallel printing of different shaped parts or whole objects (if independent Z hopping also available). - up to doubling print speeds.
              2. Allows Parallel priming and wiping during tool changes - which can push tool change times from >10 seconds down to <1 second
              3. Only having one head on each gantry means faster speeds possible in the Y direction in particular - which can be an issue with IDEX
              4. When used in combination with IDEX can allow up to 4 toolheads which can all print in parallel for some parts of large prints. - which could increase print speeds by over 50% more.
              5. Print head can access the whole X axis
              Disadvantages of Dual Gantry over IDEX
              1. Increased complexity of belt routing
              2. Slicers don’t currently support parallel printing - so post processing of GCODE required
              3. Print heads cannot individually access the whole Y axis
              4. The front gantry and print head can block the view of the rear gantry.
              Advantages of Dual Gantry over Tool changing
              1. Parallel printing - up to doubling print speeds.
              2. Allows Parallel priming and wiping during gantry or tool changes - which can push tool change times from >17 seconds down to <1 second
              3. When used in combination with IDEX can allow up to 4 toolheads which can all print in parallel for some parts of large prints. - which could increase print speeds by over 50% more.
              4. When used in combination with tool changing would allow extremely fast tool changes if the tool changes occur between the two gantries
              5. Less equipment sitting around not being used 90% of the time.
              Disadvantages of Dual Gantry over Tool changing
              2. More motors if using a Nozzle changer tool changer
              3. Slicers don’t currently support parallel printing - so post processing of GCODE required
              4. Print heads cannot individually access the whole Y axis
              5. The front gantry and print head can block the view of the rear gantry.
              In response to question from @JavierHernandez-bj5hz asking where the Quad head design will be CoreXYUVAB
              The current 2 head dual gantry implementation is already CoreXYUV, with AB added on for independent Z lifting.
              When I move to 4 head IDEX I will be changing the kinematics of each Gantry over from CoreXY to Dual Markforged - So I guess it will be something like Double , Dual Markforged, Might be Better to call it Quad Markforged I suppose/
              In terms of AXIS it will have Z0, X1,Z1,Y,X2,Z2, U1,Z3,V,U2,Z4.
              Which in RRF will be XYZUVABCDEF.
              Then just to add to the complication - the next phase after IDEX is 'occasionally moving bed' - which will add a additional larger Y axis movement capability - so will then be
              Z0, X1,Z1,Y,X2,Z2, U1,Z3,V,U2,Z4, Y2
, Which in RRF will be XYZUVABCDEFG
              o_lampeundefined bricobotundefined 2 Replies Last reply Reply Quote 1
              • dwuk3dundefined
                dwuk3d @o_lampe
                @o_lampe If you look at some of my earlier video's you might see something like that.
                Interestingly if I do end up with a fairly long bed - maybe 600 or 700 mm - then I might have to consider getting a 2nd SV08 and bolting it on the front - which as you said could have 4 heads of its own.
                Might get out of hand though.
                I think I will probably stop at 3 heads for a while - so that I can see how beneficial adding the 3rd IDEX head really is in real life situations.
                I would though really think something like an Orangestorm Giga (with the 1m x 1m x 1m). Could really benefit from 3 gantries with 2 or 3 heads on each, or maybe even 4 gantries with 2-4 heads on each.
                There was a good example in this video of printing a coffee table - where the 4 legs could be printed in parallel quite easily.
                • o_lampeundefined
                  o_lampe @dwuk3d
                  @dwuk3d said in Sovol SV08 Multiple Motion System Upgrade.:
                  Just call it Alphabet kinematics , because there aren't many unused letters left 😉
                  • bricobotundefined
                    bricobot @dwuk3d
                    Thanks David, I called it TotalPnP QuadMarkForged. I not design a 3D printer,actually I design desktop SMT (PCBA) machines. And I have some interesting ideas with this.
                    So, would duplicating the Dual Markforged IDEX kinematics be enough?
                    What do you think about using GT2 50T timing pulley instance 20T timing pulley in motors? I have been using it like this in both Y and X for years with Nema17 60mm in cartesian machine and it has worked well for me. You lose a little torque but you gain some speed, and since they are 60mm there is still enough torque to work well.
                    Best regards
                    Javier Hernandez
                    • dwuk3dundefined
                      dwuk3d @bricobot
                      @bricobot not sure about 50t - I guess having two motors on the dual Markforged Y axis does mean there should be plenty of torque - so I could look at increasing speed.
                      What i would like to do is get close to SV08 standard single head speeds - which I think is fairly quick -but then double or triple this with parallel printing.
                      Then make colour changes between 10 and 100x quicker than any non parallel printer.
                      • dwuk3dundefined
                        dwuk3d
                        Rear gantry IDEX all belted and motor'd up - just need wiring and software now - plus rebuilding of 3rd extruder
                        • dwuk3dundefined
                          dwuk3d
                          IDEX on rear gantry moving OK.
                          I've wired up the two extra Y motors as the C Axis - by then used M669's to convert that over to be the V axis
                          To move the V axis - you need to move the two new motors, plus also the two existing U + V motors.
                          I thought it was going to be tricky - but seems to be working surprisingly well.
                          Will have to do something about independently homing the two new V axis motors - to make sure that the gantry is properly at 90 degrees.
                          But overall quite happy so far - just need to build the 3rd extruder now and add few end stops - before working on the homing macro's + alignment etc.
                          ; Smart Drivers
                          M569 P0.0 S1 D2 ; driver 0.0 goes forwards (Z axis)
                          M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Z axis)
                          M569 P0.2 S0 D2 ; driver 0.2 goes backwards (Z axis)
                          M569 P0.3 S1 D2 ; driver 0.3 goes forwards (X axis)
                          M569 P0.4 S0 D2 ; driver 0.4 goes backwards (Y axis)
                          M569 P1.3 S1 D2 ; driver 0.5 goes backwards (Z axis) - changed to 1.3 forwards
                          ;M569 P1.0 S0 D3 V2000 ; driver 1.0 goes backwards (U axis)
                          ;M569 P1.1 S0 D3 V2000 ; driver 1.1 goes backwards (V axis)
                          M569 P1.0 S0 D2; driver 1.0 goes backwards (U axis)
                          M569 P1.1 S0 D2 ; driver 1.1 goes backwards (V axis)
                          M569 P1.4 S0 D2 ; Z-hopper 2
                          M569 P0.5 S1 D2 ; Z-hopper 1
                          M569 P1.5 S0 D2 ; VH Axis Left
                          M569 P1.6 S1 D2 ; VH Axis Right
                          M569 P121.0 S0 D2 ; driver 121.0 goes backwards (extruder 0)
                          M569 P122.0 S0 D2 ; driver 122.0 goes backwards (extruder 1)
                          ; Motor Idle Current Reduction
                          M906 I30 ; set motor current idle factor
                          M84 S30 ; set motor current idle timeout
                          ; Axes
                          M584 X0.3 Y0.4 Z0.1:0.2:0.0:1.3 U1.0 V1.1 A1.4 B0.5 C1.5:1.6; set axis mapping
                          M350 X16 Y16 Z16 U16 V16 A16 B16 C16 I1 ; configure microstepping with interpolation
                          M906 X800 Y800 Z800 U800 V800 A750 B150 C800 ; set axis driver currents
                          ; A - 1.8 degree, 0.7mm pitch - 200*16/0.7 = 4571
                          ; A - 1.8 degree, 1mm pitch - 200*16 = 3200
                          M92 X80 Y80 Z533.33 U80 V80 A3200 B629 C80  ; configure steps per mm
                          if exists(global.vMin) == false
                              global vMin = 120
                              global vMax = 340
                              global yMin = -5
                              global yMax = 210
                          M208 X-5:310 Y-5:210 Z0:300 U3:326 V120:334.7 A0:3 B0:3 C120:334.7; set minimum and maximum axis limits
                          M566 X540 Y540 Z100 U540 V540 A500 B300 C540 ; set maximum instantaneous speed changes (mm/min)
                          M203 X{350*60} Y{350*60} Z{25*60} U{350*60} V{350*60} A1000 B200 C{350*60} ; set maximum speeds (mm/min)
                          M201 X2000 Y2000 Z500 U2000 V2000 A1000 B20  C2000 ; set accelerations (mm/s^2)
                          ; Extruders
                          M584 E121.0:122.0 ; set extruder mapping
                          M350 E16:16 I1 ; configure microstepping with interpolation
                          M906 E800:800 ; set extruder driver currents
                          M92 E492:492 ; configure steps per mm
                          M566 E120:120 ; set maximum instantaneous speed changes (mm/min)
                          M203 E{30*60}:{30*60} ; set maximum speeds (mm/min)
                          M201 E250:250 ; set accelerations (mm/s^2)
                          ; Kinematics
                          ;M669 K8 ; configure CoreXYUV kinematics
                          M669 K1 ; configure CoreXY kinematics
                          ;     X:Y:Z:U: V:A:B:C
                          M669 V0:0:0:1:-1:0:0:1
                          M669 C0:0:0:0:01:0:0:0
                          • o_lampeundefined
                            o_lampe @dwuk3d
                            When CanFD was new to RRF, it was a golden rule NOT to spread drivers from the same axis across different boards, but I guess the timing/lag issues are now under control?
                            • dwuk3dundefined
                              dwuk3d @o_lampe
                              @o_lampe Good spot - I did think that might be an issue - particularly with multiple motion systems - but I haven't noticed any problems so far.
                              I wanted XY & B (the zHopper for X) to be on the same board - and there wasn't room on the 6HC for all 4 Z Axis.
                              I suppose I should really swap everything around and have the rear gantry on the 6HC as U V1 V2 C(u2) A(zhU) D(zHu2)
                              Then the front Gantry and Z on the 7 way Mini5+. X Y Z1 Z2 Z3 Z4 B(zhX)
                              The 6HC and Mini5+ have different size connectors for the motor drivers which adds to the complication.
                              • o_lampeundefined
                                o_lampe @dwuk3d
                                @dwuk3d I'm not sure if this is still an issue anyway.
                                But when you use two motors on the same belt, it might not be a good thing if they don't move super-synchronous. Worst thing would be loosing steps, when the motor who's trying a headstart is too weak to power through.
                                • dwuk3dundefined
                                  dwuk3d
                                  It moves......
                                  Next step - wire up 3rd extruder with 1LC tool board.
                                  Then some more end stops and homing.
                                  • dwuk3dundefined
                                    dwuk3d
                                    Starting on wiring up the 1LC on the last extruder.
                                    Horizontal placement of the board above the extruder is not that neat - but I guess the for left hand extruder the overlap isn't a big issue.
                                    For the other two extruders I made up adaptors - to make the upgrade reversible - I think for this one I will take a different approach - and cut and replace the connectors on any cables that are long enough - as likely to have two spare extruders once I do the INDX upgrade even if I end up trying a Klipper version later.
                                    • dwuk3dundefined
                                      dwuk3d @dwuk3d
                                      @dwuk3d All wired up
                                      • dwuk3dundefined
                                        dwuk3d
                                        Updated my CAD for INDX a bit based on latest pictures, plus created a Voron Zero version.
                                        1B0231A7-B1F5-481A-8386-FCEAD3449398.png 58815C02-0CE3-4734-8CDB-FBF0890AD9B1.png 65FF815E-3CEB-4AFA-8E1B-34207ADA202C.png 0E70E13C-4DF6-4146-ABB2-7E401FD69030.png 3E31B6EA-689E-4633-8407-24BAB982BA2E.png 9E38F91F-1FA7-4F7D-A0D4-A842A64DD5F7.png
                                        • dwuk3dundefined
                                          dwuk3d
                                          Almost ready to start trying homing.
                                          Decided to home the left extruder on the right extruder - mainly so that can use an identical design for two extruders.
                                          So right extruder will need to be homed first on the gantry.
                                          Also doubled up on end stops again - so single optical sensor left extruder for U axis (X) (homing on to other extruder) , D Zhopper, then another single optical sensor for right extruder - C axis (X) and A Zhopper.
                                          Will probably have to rationalise the axis letters at some point.
                                          Used an M4 bolt again for lead screw on left extruder as need to order some more lead screw nema 11s.
                                          • dwuk3dundefined
                                            dwuk3d
                                            Rough scale of Bondtech INDX toolhead overlaid over my current SOVOL toolhead.
