    Scara manual control
    636
      droftarts administrators @Fuzionline
      @Fuzionline said in Scara manual control:
      No.Only stop when reach the 150 distal angle(420mm of X0 Y0 approximate).
      I think that's the default. From 'Serial SCARA' tab of M669 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m669-set-kinematics-type-and-kinematics-parameters
      Rnnn (optional, RRF 2.03 and later only) Minimum permitted printing radius from the proximal axis. If not specified, it will be calculated to be slightly larger than the distance between nozzle and proximal axis when the distal axis is homed.
      So it does look like R is being ignored. I'll report it to @dc42 and see what he says.
      Fuzionlineundefined 1 Reply Last reply Reply Quote 0
      • Fuzionlineundefined
        Fuzionline @droftarts
        @droftarts
        tks for your help
          @Fuzionline I've raised this as an issue on Github: https://github.com/Duet3D/RepRapFirmware/issues/1045
          droftarts created this issue in Duet3D/RepRapFirmware
          open [Bug]: Scara kinematics ignoring M669 R parameter in RRF 3.5.2 #1045
            @droftarts
            Tks
              Fuzionline @Fuzionline
              @Fuzionline
              hello
              Do you have news
              tks
                T3P3Tony administrators @Fuzionline
                @Fuzionline did you test this with 3.6beta2 to see if its resolved or not?
                  Fuzionline
                  I updated to version 3.6.0 Release Candidate 1, but the M571 command doesn't work. I reverted to Release 3.5.4, and it's working. Thank you.
                  I have a Duet 2 wifi.
                  Fuzionlineundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    @Fuzionline
                    I haven't had the opportunity to test 3.6 beta 2 yet to see if it resolved the issue with M669 R.
                      dc42 administrators @Fuzionline
                      Confirmed, M571 doesn't work in 3.6.0-rc.1 and 3.6 beta versions. It will be fixed in rc2.
                        Fuzionline @dc42
                        Hello
                        Now with the rc2 it´s ok .
                        Another doubt
                        When I run a simulation and there is a movement that cannot be executed, the system correctly reports the error and shows the exact line in the G-code where the issue occurs — so far, so good.
                        However, sometimes the simulation finishes without detecting any errors, but when I start the actual print, I get errors in the console like:
                        Error: G1: intermediate position outside machine limits
                        These messages appear either in blue or red, but the printer keeps running without stopping.
                        Tks
                          @Fuzionline the reason for this is that when simulating on a Scara or other machine with nonlinear kinematics, RRF doesn't segment the moves and simulate the segments, but instead simulates the entire move. We tried simulating individual segments but found it was too slow. Unfortunately there are some situations in which out-of-bounds errors are only detected at the segment level; for example, if a move has reachable start and end coordinates but would bring the head too close to the proximal axis on the way between them.
