    2 NEW DUET 2 WIFI's W/EXTERNAL ANTENNA WILL NOT CONNECT
    983
    • GBusy24undefined
      GBusy24 @Phaedrux
      @Phaedrux Understood and thanks.
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
      GBusy24undefined 1 Reply Last reply Reply Quote 0
      • GBusy24undefined
        GBusy24 @GBusy24
        @Phaedrux, I've moved over to the second new board and inserted the SD card from the old board just for a fresh start. Here's the YAT terminal stuff to show what I've done. At this point, I've got myself confused. Look this over and let me know what you think. Thanks.Phaedrux File.txt I will add that the getting started article confuses me as far as the M552 commands. In step 4, it says to send M552 S1 to stop the wifi and then later after explaining setting the network with M587, it says send M552 S1 to connect the wifi. The green wifi light never flashes or stays lit.
        • GBusy24undefined
          GBusy24 @GBusy24
          @Phaedrux Here's the config.g from the old SD card that I inserted to the new board. Thought you'd want to see it too.config.g
          • GBusy24undefined
            GBusy24 @GBusy24
            @Phaedrux 111.txt
              Did you follow this section to add your SSID and password to get connected again?
              https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-5-connect-duet-to-network
              • GBusy24undefined
                GBusy24 @Phaedrux
                @Phaedrux yes
                GBusy24undefined 1 Reply Last reply Reply Quote 1
                • GBusy24undefined
                  GBusy24 @GBusy24
                  @Phaedrux one of my posts to you last night seems to be deleted or at least it's grayed out and I don't know if you saw it so I'm going to reshare the link I had in the post. Here it is...M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2024-09-18 11:25:32
                  ok
                  M587
                  Remembered networks:
                  Gregs WIFI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                  TNCAPF318D9 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
                  ok
                  M552 S0
                  ok
                  M552 S1
                  ok
                  Error: WiFi module reported: no known networks found
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.3 (2024-09-18 11:25:32) running on Duet WiFi 1.02 or later
                  Board ID: 0JD6M-99APT-NU4SN-6J9F4-3SD6K-14PTL
                  Used output buffers: 1 of 26 (1 max)
                  Static ram: 23376
                  Dynamic ram: 72792 of which 0 recycled
                  Never used RAM 17308, free system stack 194 words
                  Tasks: NETWORK(1,ready,7.0%,339) HEAT(3,nWait 5,0.0%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,92.9%,501) IDLE(0,ready,0.1%,29), total 100.0%
                  Owned mutexes: USB(MAIN)
                  Last reset 00:20:56 ago, cause: power up
                  Last software reset details not available
                  Error status: 0x00
                  MCU temperature: min 25.7, current 30.8, max 31.9
                  Supply voltage: min 0.2, current 1.4, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                  Events: 0 queued, 0 completed
                  Driver 0: ok, SG min n/a
                  Driver 1: ok, SG min n/a
                  Driver 2: ok, SG min n/a
                  Driver 3: ok, SG min n/a
                  Driver 4: ok, SG min n/a
                  Driver 5:
                  Driver 6:
                  Driver 7:
                  Driver 8:
                  Driver 9:
                  Driver 10:
                  Driver 11:
                  Slowest loop: 99.91ms; fastest: 0.14ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                  no step interrupt scheduled
                  Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                  === DDARing 0 ===
                  Movement locks held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is ready with "M122" in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Q0 segments left 0
                  Code queue 0 is empty
                  === Network ===
                  Slowest loop: 0.73ms; fastest: 0.00ms
                  Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 0 of 8
                  === WiFi ===
                  Interface state: changingMode
                  Module is idle
                  Failed messages: pending 0, notrdy 0, noresp 0
                  Failed to get WiFi status
                  ok
                  Error: failed to retrieve WiFi status message: bad reply format version
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                    jay_s_uk @GBusy24
                    @GBusy24 can you post a photo of the board?
                    • GBusy24undefined
                      GBusy24 @jay_s_uk
                      @jay_s_uk unfortunately, I'm at work right now
                      • GBusy24undefined
                        GBusy24 @GBusy24
                        @jay_s_uk may I ask what you would be looking for on the board and maybe I can help her memory. It is one of the newer boards with the external Wi-Fi antenna
                          jay_s_uk @GBusy24
                          @GBusy24 just checking that everything looks ok. as the wifi module appears to be working, the antenna is either not connected correctly or is not functioning.
                          I've seen cases of antennas not working correctly
                          • GBusy24undefined
                            GBusy24 @jay_s_uk
                            @jay_s_uk I'm really confident that the antenna is connected correctly but I will mention that it is not mounted it is just laying near the board
                              jay_s_uk @GBusy24
                              @GBusy24 just laying around is fine. In that case, I would suggest changing the antenna
                              • GBusy24undefined
                                GBusy24 @jay_s_uk
                                @jay_s_uk okay, but who will sell me just the antenna? I have two because I have two new boards. Maybe I should try the other antenna off of The Other Board
                                • GBusy24undefined
                                  GBusy24 @GBusy24
                                  @jay_s_uk I will say that when working with the other board the green light on the Wi-Fi module would blink constantly where I get nothing out of this current board I'm working with
                                    jay_s_uk @GBusy24
                                    @GBusy24 yea, try the other one.
                                    you can get antennas off amazon easily enough. search for a U.FL Antenna for wifi
                                    GBusy24undefined 2 Replies Last reply Reply Quote 0
                                    • GBusy24undefined
                                      GBusy24 @jay_s_uk
                                      @jay_s_uk okay thanks
                                      • GBusy24undefined
                                        GBusy24 @jay_s_uk
                                        @jay_s_uk I've now switched out the antennas, but still in same condition. No connection. Scratching my head. Here's a pic of the board. Is it a mistake to wire everything up before connecting? I know I've done this before successfully.20250415_191452.jpg
                                        • GBusy24undefined
                                          GBusy24 @GBusy24
                                          @jay_s_uk I set my network ...........it remembers it and M587 confirms. I send M552 S1 and get 'No known networks found".
                                          M587 S"Greg's WIFI" P"**********"
                                          M587
                                          ok
                                          M552 S1
                                          ok
                                            Just to confirm the situation.... Is this correct?
                                            • you have two old Duet 2 wifi boards that worked with the wifi network in question previously.
                                            • you have two new Duet 2 wifi boards with external antenna that both show No known networks found?
                                            The network in question is a 2.4Ghz network?
                                            Can you test in access point mode to remove your network from the equation?
                                            https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
