    2 NEW DUET 2 WIFI's W/EXTERNAL ANTENNA WILL NOT CONNECT
    978
    • GBusy24undefined
      GBusy24 @jay_s_uk
      @jay_s_uk okay thanks
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
      GBusy24undefined 1 Reply Last reply Reply Quote 0
      • GBusy24undefined
        GBusy24 @jay_s_uk
        @jay_s_uk I've now switched out the antennas, but still in same condition. No connection. Scratching my head. Here's a pic of the board. Is it a mistake to wire everything up before connecting? I know I've done this before successfully.20250415_191452.jpg
        • GBusy24undefined
          GBusy24 @GBusy24
          @jay_s_uk I set my network ...........it remembers it and M587 confirms. I send M552 S1 and get 'No known networks found".
          M587 S"Greg's WIFI" P"**********"
          M587
          Remembered networks:
          Gregs WIFI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
          TNCAPF318D9 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
          ok
          M552 S1
          ok
          Error: WiFi module reported: no known networks found
            Just to confirm the situation.... Is this correct?
            • you have two old Duet 2 wifi boards that worked with the wifi network in question previously.
            • you have two new Duet 2 wifi boards with external antenna that both show No known networks found?
            The network in question is a 2.4Ghz network?
            Can you test in access point mode to remove your network from the equation?
            https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
            • GBusy24undefined
              GBusy24 @Phaedrux
              @Phaedrux The answer is yes to all 3 of your questions. It's morning here and I'll try that when I get home from work.
                droftarts administrators @GBusy24
                @GBusy24 Does your WiFi network name actually have an apostrophe in it? You're sending:
                But the remembered network has no apostrophe:
                If you need an apostrophe, put two apostrophes in, because it's used to signify a lower case letter in the M587 command. As it says in the M587 notes:
                Use two single quote characters to represent one actual single quote character in the password or in the SSID. For example, if your SSID is "Pete's network" then enter "Pete''s network".
                If that doesn't work, you can get the Duet to scan for networks, which will also check if the WiFi is working. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m5871-start-network-scan
                From the YAT terminal, send:
                M587.1
                Wait for a few moments (30 seconds should be fine), then send:
                M587.2
                This should show any WiFi networks it has found.
                GBusy24undefined 1 Reply Last reply Reply Quote 1
                • GBusy24undefined
                  GBusy24 @droftarts
                  @droftarts Aha! Good to know. Thanks,
                  • GBusy24undefined
                    GBusy24 @GBusy24
                    @Phaedrux, @droftarts,
                    I've got Access Point setup with the special characters corrected and it's giving me my access point. At this stage, shouldn't I be able to just type that IP into my browser. I'm still missing something. Right? Thanks
                    • GBusy24undefined
                      GBusy24 @GBusy24
                      @Phaedrux, @droftarts, @jay_s_uk, Thanks for everyone's help. I'm connected!
                      • GBusy24undefined
                        GBusy24 @GBusy24
                        I've got the solid green light for the wifi module showing and at this point I assumed I could pull up DWC Thru my browser and my static IP, but that's not working for me. So I disconnect USB power and turn main power on and still, no luck. Please advise.
                          @GBusy24 Do you have the Duet setup up as an access point (ie you connect phone/tablet/laptop directly to the Duet WiFi, not using your normal network) or have you managed to connect the Duet to your normal router (ie Duet is connected to "Greg's WIFI")? I would recommend just connecting as normal as I think the problem has been the apostrophe in the WiFi SSID name. Setting up the Duet as an access point requires some configuration of the device you are trying to connect to the Duet, so there are more places faults can occur. Perhaps post the commands you are sending in YAT, and the response. What device are you using to try and connect to the Duet?
                          When you connect to the IP address, do you get any message in the browser? To show DWC, the SD card needs to be in the Duet, and there needs to be a version of the DWC files in the /www folder on the Duet. The version of DWC should match the firmware version. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#sd-card-structure
                          • GBusy24undefined
                            GBusy24 @droftarts
                            @droftarts Setup as access point.Terminal Snippet.txt
                            • GBusy24undefined
                              GBusy24 @GBusy24
                              @droftarts I sent a 587 command after that.
                              • GBusy24undefined
                                GBusy24 @GBusy24
                                @droftarts M587 S"Greg''s WIFI" P"**********" I192.168.0.62
                                  @GBusy24 I think you have set up your Duet with the same SSID name as your existing network. This isn't a good idea. With access point mode, you are setting up a completely separate WiFi network on the Duet, for other devices to connect to (you have to change WiFi network on your phone/tablet/laptop); it doesn't link to your existing WiFi network. As I said, please go back to using the normal mode, and connect the Duet to your existing WiFi network, as I think the initial problem was the use of the apostrophe.
                                  Send the following commands from YAT, and post the responses you get:
                                  M587 ; lists stored WiFi networks
                                  If "Greg's WIFI" (with an apostrophe) is on the list, send
                                  M552 S0 ; Set WiFi to idle mode
                                  M552 S1 ; turn on WiFi in client mode
                                  If "Greg's WIFI" (with an apostrophe) is NOT on the list, send
                                  M588 S"*" ; deletes all saved SSIDs
                                  This should set up the WiFi correctly, and connect the Duet to your normal network.
                                  • GBusy24undefined
                                    GBusy24 @droftarts
                                    @droftarts Thanks, I'll do this when I get home from work.
                                    • GBusy24undefined
                                      GBusy24 @GBusy24
                                      @droftarts Greg''s WIFI was listed, but W/O the apostrophe and I went ahead and ran the commands you said anyway just in case, You can see the 'No network found' result, so I sent the second group of commands you mentioned and my wifi light on the board goes off and I can't connect in normal mode. Head scratching time. Please advise.Terminal Snippet.txt
                                      • GBusy24undefined
                                        GBusy24 @GBusy24
                                        @droftarts Finally thought to do this that you told me to do a couple of days ago, so I thought I'd let you see it too.Network Scan.txt
                                        • GBusy24undefined
                                          GBusy24 @GBusy24
                                          @droftarts The only time I've been able to get the wifi module green to turn on is when I set up the access point mode
                                          • GBusy24undefined
                                            GBusy24 @GBusy24
                                            @droftarts I finally solved it. I'm connected and I just pulled up DWC. Thanks
                                            Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
