    Spirograph emulator with Duet2
    CNC
    4.9k
    • o_lampeundefined
      o_lampe
      I'm still pondering how to build the frame. It should not be much bigger than the glass plate and still reach (almost) everywhere.
      The best kinematic option we already have is the delta: I could turn around the delta effector to show upwards and the three towers would act as table-feet.
      I just have to find round glass plates and build a sandwich. (bottom plate could be dibond as @mrehorstdmd suggested)
      <edit> looking for glass tables I stumbled across this round infinity table
      How cool would that be in combination with a sandtable?! 😱
      • mrehorstdmdundefined
        mrehorstdmd @o_lampe
        @o_lampe AFAIK, the Duet firmware doesn't have any provision for random number generation. I use macros, painstakingly composed, to play sequences of patterns. I'm thinking of writing a spreadsheet or maybe Perl script to create macro files by randomly selecting from a list of pattern files and a list of erase files.
        Infinity tables only work when you can see the mirror at the bottom of the table. In a sand table, it's going to be covered by the sand, unless you limit the sand drawings to an area at the center of the table.
        dc42undefined o_lampeundefined 2 Replies Last reply Reply Quote 1
          dc42 administrators @mrehorstdmd
          @mrehorstdmd see the 'random' function at https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#functions.
          mrehorstdmdundefined 1 Reply Last reply Reply Quote 2
          • o_lampeundefined
            o_lampe @mrehorstdmd
            @mrehorstdmd Good point. I thought the miracle behind the infinity trick is the semi-transparent top-mirror, but with sand at the bottom it won't work.
            Glad I didn't order it 🙂
            • o_lampeundefined
              o_lampe
              Here's a rough sketch of a SlimDelta which works upside down.
              Motors and extrusion are mounted inline, which will free up the print-area.
              I hope I can get away with NEMA14 motors (0.4Nm) because the effector + magnet weight is so low.
              Long rods and narrow triangle will give me the biggest print area, accuracy is not important here. The magnet will drag the ball along, even with a few millimeters gap between.
                mrehorstdmd @dc42
                @dc42 The controller has no RTC, so what seeds the random function? If I set up a macro to randomly select and run gcode files from a list, will it give me a different file/sequence each time the controller is powered up, or will it give me the same pseudo random sequence of files each time? Thanks!
                  @o_lampe I don't know that you gain much drawing area using a delta mechanism. I don't think you can draw any further than the towers, so you'll still have a wide, undrawn perimeter like what you get with a corexy or other rectangular mechanism. A lot of people make SCARA mechanism sand tables. With those the magnet is on the end of an arm that can reach very close to the edges of the table. The mechanism is located at the center of the table, so there's plenty of room for people's legs/feet if they are sitting around the table.
                  See: https://robdobson.com/2018/08/a-new-sandbot/
                    @mrehorstdmd said in Spirograph emulator with Duet2:
                    The 'random' function uses the hardware true random number generator if the MCU has one (which is currently the case for all Duet 3 main boards). If it doesn't have one then the generator is seeded by the system tick counter the first time it is called.
                      mrehorstdmd @dc42
                      @dc42 Will it work with the Duet2 Wifi board? I typically set up the controller to run a macro containing a sequence of patterns to run at power up. That way I don't need to have a UI or even to connect to the machine.
                      I am not familiar with the way tick counter works. If I use the random function to select files to run instead of a macro that contains a specific sequence, will it give me the same sequence each time I power up the board, or is there some variability in the power up timing that will result in a different seed when I use the random function after each power up? Thanks!
                      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • o_lampeundefined
                        @mrehorstdmd I guess, the homing sequence is never the same, depending on the starting points of the axis'. When you call random afterwards, the seed will be different.
                          @mrehorstdmd the MCU in Duet 2 doesn't have a true random number generator so it will use the system tick counter as the seed. The tick counter increments at 120MHz once the processor clock has been set up. So even a small change in the timing of e.g. reading config.g from the SD card or homing the axes would change the seed. Let me know if you don't find it to be random, in which case I could look at using the CPU temperature to contribute to the seed too.
                          mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                            mrehorstdmd @dc42
                            @dc42 Thanks! I will try it out and see if I can get it working.
                            • o_lampeundefined
                              @mrehorstdmd A SCARA arm in the center would be nice, but I don't know if RRF supports the 360° working area? @dc42 @JoergS5 ?
                              The design is 7 years old, I wonder if there are improved designs available, a counterweight would be nice IMHO.
                                mrehorstdmd @dc42
                                @dc42 I'm having some trouble figuring out how to randomly select a file from the /gcodes/ folder. Do I have to put the files names in that folder in an array, or is there a way to declare the contents of the /gcodes/ folder as an array? I currently have about 200 gcode files stored in the /gcodes/ folder, and I add more files to it as I generate them.
                                I typically run a macro at the end of the config.g file, like this:
                                M98 P"/macros/macro01"
                                And that macro file looks like this (though much longer):
                                ; file name: macro01
                                M98 P"/gcodes/wipe_03.gcode"
                                M98 P"/gcodes/file_04.gcode"
                                G04 S60
                                M98 P"/gcodes/wipe_01.gcode"
                                M98 P"/gcodes/file_02.gcode"
                                G04 S60
                                M98 P"/gcodes/wipe_02.gcode"
                                M98 P"/gcodes/file_06.gcode"
                                Should macro01 file look like this:
                                var myfile = {"file_01", "file_02", "file_03", "file_04", "file_05", "file_06"}
                                M98 P"/gcodes/^myfile[random 6]^.gcode"
                                G04 S60
                                It seems like I'll quickly run out of line length if I try to put all 200 file names in the variable declaration.
                                Another idea- rename all the files in the gcodes folder with simple numeric names:
                                1.gcode, 2.gcode.... 212.gcode
                                Then in the macro file, select a random pattern file like this:
                                M98 P"/gcodes/^{random(212)}^.gcode"
                                Sorry if this stuff is too basic. I've been away from programming for a looooong time.
                                • o_lampeundefined
                                  Basically, that's what I'd try too.
                                  But I'd check, if the file (still) exists before I call M98. Unless you only put files in the gcode directory after you tested it. It would be a PITA to e.g. rename files 123-212 , just because file 122 turned out to be problematic or ugly or boring.
                                  Alternatively you could edit the unwanted file and only leave the end code. The worst that can happen is running two wipe-file in a row.
                                    @o_lampe Thanks. All the files are tested, so not an issue. I'll be able to access the machine this afternoon and will try out the random selection. I'm not too sure about the syntax. I've been testing the syntax via the console on my 3D printer and it doesn't look promising. If I enter M98 p"{random(55)}^.gcode" it returns {random(55)}^.gcode not found. It isn't converting the expression to a random number, or even treating it as an expression, just a string of characters. I've tried a few variations on the syntax and none have worked so far.
                                    When I run echo random(416) on the console, it returns a random number (sometimes 3 digits), so I know random is working the way it should. Maybe I need to set a variable to a random value, and use that variable in the M98 command.
                                    Renaming the files is pretty easy- I used Bulk Rename Utility. It takes just a couple seconds to set it up.
                                    ironhydroxideundefined 1 Reply Last reply Reply Quote 0
                                    • ironhydroxideundefined
                                      ironhydroxide @mrehorstdmd
                                      you need to complete the quotation, then append the value, then continue the quotation.
                                      M98 P""" <-gives you M98 "
                                      ^{random(55)} appends the result of the random 55
                                      ^".gcode""" appends the string .gcode"
                                      Leaves you with
                                      M98 P"randomnumber.gcode"
                                      I was wrong,
                                      After some testing it seems here's the syntax.
                                      M98 P{random(55)}^".gcode"
                                        dc42 administrators @ironhydroxide
                                        @ironhydroxide the correct syntax is:
                                        M98 P{random(55)^".gcode"}
                                        ironhydroxideundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 1
                                          ironhydroxide @dc42
                                          @dc42 Thanks for that correction.
                                          Tested with my system and it seemed to work the other way (though likely can cause problems when getting more complex)
                                            mrehorstdmd @dc42
                                            @dc42 I have drawing files in /gcodes/draw/ and wipe files in /gcodes/wipe/ folders. All files are renamed with numeric names and gcode extension, like "16.gcode".
                                            I have tried about 50 variations on:
                                            M98 P{/gcodes/draw/random(214)^".gcode"}
                                            and get various error messages, mostly about expecting a string at one column or another.
                                            How do I specify the folder to find the target files? Is this syntax documented somewhere?
                                            Thanks!
                                            m98 P"/gcodes/draw/^{random(22)}^.gcode"
                                            Warning: Macro file /gcodes/draw/^{random(22)}^.gcode not found
                                            ok
                                            M98 P"/gcodes/draw/{random(55)^".gcode"}
                                            Warning: Macro file /gcodes/draw/{random(55)^ not found
                                            Error: Bad command: gcode"}
                                            ok
                                            M98 P{/gcodes/draw/{andom(55)^".gcode"}
                                            Error:  at column 7: M98: expected an expression
                                            ok
                                            M98 P{/gcodes/draw/{random(55)^".gcode"}
                                            ok
                                            M98 P{/gcodes/draw/random(55)^".gcode"}
                                            ok
                                            M98 P "/gcodes/draw/{random(55)^".gcode"}
                                            Error:  at column 6: M98: expected a string expression
                                            ok
                                            M98 P "/gcodes/draw/{random(55)^.gcode"}
                                            ok
                                            M98 P {/gcodes/draw/random(55)^.gcode"}
                                            ok
                                            Warning: Macro file 39.gcode not found
                                            ok
                                            M98 P /gcodes/draw/{random(55)^".gcode"}
                                            Error: Bad command: gcodes/draw/{random(55)^".gcode"}
                                            ok
                                            M98 P "/gcodes/draw/{random(55)^".gcode"}"
                                            Error: Bad command: gcode"}"
                                            ok
                                            ok
                                            ok
                                            ok
                                            ok
                                            M98 P "/gcodes/draw/"^{random(55)^".gcode"}"
                                            ok
                                            M98 P /gcodes/draw/^{random(55)^".gcode"}
                                            Error: Bad command: gcodes/draw/^{random(55)^".gcode"}
                                            ok
                                            M98 P {/gcodes/draw/random(55)^".gcode"}
                                            ok
                                            M98 P {0:/gcodes/draw/random(55)^".gcode"}
                                            ok
                                            M98 P "0:/gcodes/draw/"^{random(55)^".gcode"}
                                            ok
                                            M98 P "0:/gcodes/draw/"{random(55)^".gcode"}
                                            ok
                                            M98 P"0:/gcodes/draw/"{random(55)^".gcode"}
                                            Warning: Macro file 0:/gcodes/draw/ not found
                                            ok
                                            M98 P{0:/gcodes/draw/random(55)^".gcode"}
                                            Error:  at column 8: M98: expected '}'
                                            ok
                                            M98 P"{0:/gcodes/draw/random(55)"^".gcode"}
                                            Warning: Macro file {0:/gcodes/draw/random(55) not found
                                            ok
                                            M98 P"0:/gcodes/draw/{random(55)"^".gcode"}
                                            Warning: Macro file 0:/gcodes/draw/{random(55) not found
                                            ok
                                            M98 P"0:/gcodes/draw/{random(55)}"^".gcode"}
                                            Warning: Macro file 0:/gcodes/draw/{random(55)} not found
                                            ok
                                            ok
                                            M98 P"0:/gcodes/draw/"{random(55)}"^".gcode"
                                            ok
                                            M98 P"0:/gcodes/draw/"^{random(55)}"^".gcode"
                                            ok
                                            M98 P"0:/gcodes/draw/"^{random(55)}^".gcode"
                                            ok
                                            M98 P"0:/gcodes/draw/"^{random(55)^".gcode"}
                                            ok
                                            M98 P"0:/gcodes/draw/"^"{random(55)^".gcode"}
                                            ok
                                            M98 P"0:/gcodes/draw/^"{random(55)^".gcode"}
                                            Warning: Macro file 0:/gcodes/draw/^ not found
                                            ok
