    G30 during G28 issue
    My Duet controlled machine
    879
      dc42 administrators @Leonard03
      @Leonard03 said in G30 during G28 issue:
      @dc42 Found when! Tried now old binaries that I have saved.
      This particular issue occurred between 3.6.0-beta.2+4 (2024-12-01 18:14:39) and 3.6.0-beta.2+5 (2025-01-04 14:18:24).
      In +4 version the X axis homes in the same location regardless of the G30. In the +5 version.. well.. is the present topic. I also have the .map files for them if they help you in any way 🙂
      Thanks for pinning this down to that version increment. I will review the commit history and work out the cause. It may be specific to Duet 2.
        @Leonard03 are you able to reproduce this issue other than in the homing file?
        For example: suppose you home the printer, then send G1 X150 Y150. Ignore any error that this point. Then send G30 zero or more times; then send G1 X160 Y160. Does the head position at this point (relative to where the head was after the G1 X150 Y150) depend on how many times you sent G30?
        PS - one more test please: if you temporarily set the probe X and Y offsets to 0 in your G31 command, does the issue still occur?
        PPS - created https://github.com/Duet3D/RepRapFirmware/issues/1116
        dc42 created this issue in Duet3D/RepRapFirmware
        closed G30 changing X coordinate #1116
        Leonard03undefined 1 Reply Last reply Reply Quote 0
        • Leonard03undefined
          Leonard03
          @dc42 said in G30 during G28 issue:
          I'm glad I can help 🙂
          @fcwilt @davidjryan Sorry for the delay.. Thank you guys for your help. I managed to modify my configuration, cleaned up some macros, renamed some others to make them easy to follow so now I can use the command M98 P"config.g" and you both were right. Is way better now, thank you again ^_^
          So far, no. Is only related to homing, with or without a probe.
          I will use every time the individual homing files, do some G30s at some points (I think they will change) and report back. I will use the macro above to keep track of the coordinates
            Leonard03
            So, using my actual probe offsets, G28 X Y Z. Using the endstops, the X carriage is homed with the endstop blade pressed.
            G1 X50 Y50
            User X position is:  50.000
            Machine X position is:  49.993
            User Y position is:  50.000
            Machine Y position is:  50.000
            G30
            User X position is:  49.618
            Machine X position is:  49.618
            G1 X100 Y100
            User X position is:  100.000
            Machine X position is:  99.997
            User Y position is:  100.000
            Machine Y position is:  100.000
            G30
            User X position is:  99.285
            Machine X position is:  99.285
            G1 X150 Y150
            User X position is:  150.000
            Machine X position is:  150.003
            User Y position is:  150.000
            Machine Y position is:  150.000
            G30
            User X position is:  148.940
            Machine X position is:  148.940
            G1 X200 Y200
            User X position is:  200.000
            Machine X position is:  199.995
            User Y position is:  200.000
            Machine Y position is:  200.000
            G30
            User X position is:  198.595
            Machine X position is:  198.595
            Now, if I do G1 X0 Y0 the result is
            User X position is:  4.000
            Machine X position is:  4.000
            User Y position is:  0.00
            Machine Y position is:  0.00
            but the x carriage is far away in the X+ direction
            G92 X0 sets the X at 4. This is the correct offset set in config.
            G1 H4 X-50 here:
            User X position is:  -9.475
            Machine X position is:  -9.475
            So, after 4 G30s at different coordinates, the X0 Y0 is set at 9.475mm from where it should been, right?
              Leonard03
              Now, G31 P500 X-27.4 Y-28.6 Z2.00 from config.g and G31 K0 P500 X-27.4 Y-28.6 Z1.92 in config-override.g, both set to G31 K0 P500 X0 Y0 Z2.00 and restart.
              Homing with individual files:
              User X position is:  4.051
              Machine X position is:  4.051
              User Y position is:  -2.000
              Machine Y position is:  -2.000
              This is the fresh start.
              G1 X50 Y50
              Machine X position is:  50.005
              G30
              User X position is:  49.630
              Machine X position is:  49.630
              G1 X100 Y100
              G30
              G1 X150 Y150
              G30
              G1 X200 Y200
              G30
              Going back to X0 Y0
              and again G1 H4 X-50 the position now is: (but I forget the G92 X0 command.. 😑)
              User X position is:  -6.175
              Machine X position is:  -6.175
              After those tests, opening the config.g lead to a board reset 😵
              this is the M122:
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-rc.3 (2025-04-30 14:41:53) running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DGM-917NK-F2MS4-7JKDG-3S06M-9ZSWD
              Used output buffers: 2 of 26 (22 max)
              Static ram: 24016
              Dynamic ram: 70576 of which 0 recycled
              Never used RAM 25404, free system stack 206 words
              Tasks: NETWORK(1,ready,12.3%,217) HEAT(3,nWait 5,0.1%,330) Move(4,nWait 5,0.0%,359) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,86.8%,733) IDLE(0,ready,0.9%,29), total 100.0%
              Owned mutexes:
              Last reset 00:01:24 ago, cause: software
              Last software reset at 2025-05-14 20:03, reason: StuckInSpinLoop, Platform spinning, available RAM 24852, slot 1
              Software reset code 0x4080 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20002968 Task NETW Freestk 1073741462 ok
              Stack: 00000000 20001414 10000000 e000e000 000000a4 0045e705 0045dd8a 610f0000 0000019e ffffffff 00000000 000f8dd6 00000000 2000045c ffffffff 20002e90 00000001 0045de27 20002a18 2000022c 38f5edae 0045b27b 20001088 004056a5 a5a5a5a5 a5a5a5a5 2000045c
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 20.8, current 22.2, max 28.1
              Supply voltage: min 1.3, current 1.3, max 4.9, under voltage events: 0, over voltage events: 0, power good: no
              Heap OK, handles allocated/used 99/41, heap memory allocated/used/recyclable 2048/1200/480, gc cycles 0
              Events: 0 queued, 0 completed
              Date/time: 2025-05-14 20:05:05
              Slowest loop: 9.52ms; fastest: 0.14ms
              === Storage ===
              Free file entries: 10
              SD card 0 detected, requested/actual speed: 25.0/20.0MBytes/sec
              SD card longest read time 48.9ms, write time 53.8ms, max retries 0
              Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
              No step interrupt scheduled
              Driver 0: ok, SG min n/a
              Driver 1: ok, SG min n/a
              Driver 2: ok, SG min n/a
              Driver 3: ok, SG min n/a
              Driver 4: ok, SG min n/a
              Driver 5: ok, SG min n/a
              Driver 6: ok, SG min n/a
              Driver 7: ok, SG min n/a
              Driver 8: ok, SG min n/a
              Driver 9: ok, SG min n/a
              Driver 10:
              Driver 11:
              === DDARing 0 ===
              Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
              Segments left 0
              Code queue is empty
              Movement locks held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              === DueX ===
              Read count 3, 2.13 reads/min
              === Network ===
              Slowest loop: 13.67ms; fastest: 0.00ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              === WiFi ===
              Interface state: active
              Module is connected to access point
              Failed messages: pending 0, notrdy 0, noresp 0
              Firmware version 2.2.1
              Module reset reason: Power up, Vcc 3.40, flash size 4194304, free heap 39332
              MAC address b4:e6:2d:52:f5:47
              IP address 192.168.0.107
              Signal strength -34dBm, channel 11, mode 802.11n, reconnections 0
              Clock register 00002002
                Leonard03
                And a thought occurred now: what about the offsets set by M208 S0?
                I reverted my config.g and config-override.g.
                Changing M208 X4 Y-2 Z0 S1 to M208 X0 Y0 Z0 S1 restart, homing with individual files, and G1 X50 Y50
                G30
                G1 X100 Y100
                G30
                G1 X150 Y150
                G30
                G1 X200 Y200
                G30
                User X position is:  197.195
                Machine X position is:  197.195
                G1 X0 Y0, G92 X0 and G1 H4 X-50 the result is X = -14.38
                Looks like the M208 S1 has nothing to do with this issue
                  Leonard03 @dc42
                  First I'll go X120 Y120 without probing the Z.
                  User X position is:  120.000
                  Machine X position is:  119.997
                  User Y position is:  120.000
                  Machine Y position is:  120.000
                  And the results:
                  Probe #1
                  User X position is:  119.147
                  Machine X position is:  119.147
                  Probe #2
                  Probe #3
                  User X position is:  117.447
                  Machine X position is:  117.447
                  Probe #4
                  User X position is:  116.597
                  Machine X position is:  116.597
                  Probe #5
                  User X position is:  115.747
                  Machine X position is:  115.747
                  You're right. Repeating G30 without moving the toolhead, actually is altering the coordinates
                  Repeating the same procedure, this time at X160 Y160 without rehoming
                  User X position is:  160.000
                  Machine X position is:  159.996
                  User Y position is:  160.000
                  Machine Y position is:  159.988
                  And the results:
                  Probe #1
                  User X position is:  158.896
                  Machine X position is:  158.896
                  User Y position is:  159.988
                  Probe #2
                  User X position is:  157.796
                  Machine X position is:  157.796
                  Probe #3
                  User X position is:  156.696
                  Machine X position is:  156.696
                  Probe #4
                  User X position is:  155.596
                  Machine X position is:  155.596
                  Probe #5
                  User X position is:  154.496
                  Machine X position is:  154.496
                  Now,
                  G1 X0 Y0 goes to X4 Y0 (correct offsets)
                  G92 X0 Y0 goes to X4 Y0
                  G1 H4 X-50
                  And the result
                  User X position is:  -24.837
                  Machine X position is:  -24.837
                  Well.. wow.. this is the biggest shift so far 😑
                  • fcwiltundefined
                    fcwilt @Leonard03
                    @Leonard03
                    Just FYI - G92 is not a movement command, it merely sets the current axis position to whatever value present.
                    So G92 X123 Y456 sets the logical X position to 123 and the logical Y position to 456.
                      Leonard03 @fcwilt
                      @fcwilt Yes. In this case I only used G92 to measure the distance between logical and physical positions 😄
                      Hmm.. I did it wrong?
                      I'm referring to G1 H4 command. It was better to measure from let's say X80 to the endstop? 😕
                      • fcwiltundefined
                        fcwilt @Leonard03
                        I'm not sure what you mean by "measure".
                          Leonard03 @fcwilt
                          @fcwilt Since every G30 command alters the X coordinate without physically moving the stepper, after the initial homing, I don't know where the toolhead is.
                          By setting its physical position to X0 Y0, using G92, I can measure the distance between the reported and actual positions relative to endstop.
                          Let's say I move the nozzle to X80 and perform 10 probes at that point; the reported coordinate is no longer X80, regardless of the actual physical position. If I set that position as the zero position and perform a G1 H4 move toward the endstop, the reported X position afterward is the offset amount. I want to obtain that value from a theoretical zero point.
                          Normally, if I move to X80 and return by pressing the endstop blade, the actual and reported coordinates should be close (accounting for endstop accuracy), but currently, they are not. I do this out of curiosity to see "how much."
                          Hope this make sense 😁
                            droftarts administrators @Leonard03
                            M556 S100 X0.69
                            I just noticed you have axis skew compensation enabled in your config.g. Can you try with this disabled?
                            Leonard03undefined 1 Reply Last reply Reply Quote 1
                              Leonard03 @droftarts
                              @droftarts Sure, why not
                              Starting with this:
                              Axis compensations - XY: 0.00000, YZ: 0.00000, ZX: 0.00000
                              G28 X Y Z, again, using individual homing files, no G30 involved for now.
                              Axis positions:
                              Move to G1 X120 Y120
                              Probe #1
                              Machine X position is:  120.000
                              Probe #2
                              Probe #3
                              Probe #4
                              Well.. this is something in the right direction
                              Now, G1 X160 Y160
                              Probe #1
                              Machine X position is:  160.000
                              Machine Y position is:  160.000
                              Probe #2
                              Probe #3
                              Probe #4
                              From X160 Y160, going to X0 Y0
                              And the toolhead parked against the endstop blade! As it should
                              So @droftarts, you are right. Skew compensation is involved in this
                              Update: homeall.g works as expected without the skew compensation
                                @Leonard03 Okay, thanks for testing! I'll highlight this to @dc42, hopefully it gives him something to focus on fixing.
                                I guess a follow up question is: do you need skew compensation enabled?
                                  @droftarts Thank you 😊
                                  @droftarts said in G30 during G28 issue:
                                  This a very good question. I can answer with a maybe. But since in normal operation I don't encounter this bug, I think I leave skew compensation enabled for now.
                                  Only time when this bug presents itself (and how I discovered it) is after "Resume after power loss". In that case I can rehome only the X and Y (Z axis remains enabled) without the probe. This gives a pretty substantial layer shift in the printed model after resume.
                                  As a background: I use UPS and a mains power feedback thru a phone charger, a relay powered by the charger and two of the switching contacts of the relay connected to the duex.e3stop
                                  This way, if power is out, I stop the print, disable nozzle heater, X and Y (and the UVW) but keep the bed up to temperature and Z steppers active as long as the UPS can provide power (about an hour). If the mains power comes back, I call M916 to do the resume. At this stage problems with this occurred.
                                    @Leonard03 can you confirm that if you disable skew compensation, the original problem that occurred during homing no longer occurs?
                                    droftartsundefined Leonard03undefined 2 Replies Last reply Reply Quote 0
                                      droftarts administrators @dc42
                                      @dc42 I'm pretty sure he did:
                                        Leonard03 @dc42
                                        @dc42 @droftarts yes, I can confirm. Without skew compensation enabled the issue is solved
                                          @Leonard03 thanks.
                                          I found a bug that may account for this issue. Please try the new firmware build at https://www.dropbox.com/scl/fo/dumsdufoej44q97ek9joo/AIBRnU-wtKfMrbWPzZwH_XY?rlkey=idmyinvvcuiwmycbb1l2obz38&dl=0.
                                          Leonard03undefined gloomyandyundefined 2 Replies Last reply Reply Quote 1
                                          • gloomyandyundefined gloomyandy referenced this topic
                                            Leonard03 @dc42
                                            @dc42 Thank you very much. I tested the new binary.
                                            The issue is still there, but is way better.
                                            Now, if I resume a print, the shift in X- direction got smaller - from 10mm to ~2mm. Not quite there, but much better
