    G30 during G28 issue
    My Duet controlled machine
    917
    • fcwiltundefined
      fcwilt @Leonard03
      @Leonard03
      Just FYI - G92 is not a movement command, it merely sets the current axis position to whatever value present.
      So G92 X123 Y456 sets the logical X position to 123 and the logical Y position to 456.
      Leonard03undefined 1 Reply Last reply Reply Quote 0
      • Leonard03undefined
        Leonard03 @fcwilt
        @fcwilt Yes. In this case I only used G92 to measure the distance between logical and physical positions 😄
        Hmm.. I did it wrong?
        I'm referring to G1 H4 command. It was better to measure from let's say X80 to the endstop? 😕
        • fcwiltundefined
          fcwilt @Leonard03
          @Leonard03 said in G30 during G28 issue:
          I'm not sure what you mean by "measure".
            Leonard03 @fcwilt
            @fcwilt Since every G30 command alters the X coordinate without physically moving the stepper, after the initial homing, I don't know where the toolhead is.
            By setting its physical position to X0 Y0, using G92, I can measure the distance between the reported and actual positions relative to endstop.
            Let's say I move the nozzle to X80 and perform 10 probes at that point; the reported coordinate is no longer X80, regardless of the actual physical position. If I set that position as the zero position and perform a G1 H4 move toward the endstop, the reported X position afterward is the offset amount. I want to obtain that value from a theoretical zero point.
            Normally, if I move to X80 and return by pressing the endstop blade, the actual and reported coordinates should be close (accounting for endstop accuracy), but currently, they are not. I do this out of curiosity to see "how much."
            Hope this make sense 😁
              droftarts administrators @Leonard03
              M556 S100 X0.69
              I just noticed you have axis skew compensation enabled in your config.g. Can you try with this disabled?
              Leonard03undefined 1 Reply Last reply Reply Quote 1
                Leonard03 @droftarts
                @droftarts Sure, why not
                Starting with this:
                Axis compensations - XY: 0.00000, YZ: 0.00000, ZX: 0.00000
                G28 X Y Z, again, using individual homing files, no G30 involved for now.
                Axis positions:
                User X position is:  4.000
                Machine X position is:  4.000
                User Y position is:  -2.000
                Machine Y position is:  -2.000
                Move to G1 X120 Y120
                Probe #1
                User X position is:  120.000
                Machine X position is:  120.000
                User Y position is:  120.000
                Machine Y position is:  120.000
                Probe #2
                Probe #3
                Probe #4
                Well.. this is something in the right direction
                Now, G1 X160 Y160
                Probe #1
                User X position is:  160.000
                Machine X position is:  160.000
                User Y position is:  160.000
                Machine Y position is:  160.000
                Probe #2
                Probe #3
                Probe #4
                From X160 Y160, going to X0 Y0
                User Y position is:  0.00
                Machine Y position is:  0.00
                And the toolhead parked against the endstop blade! As it should
                So @droftarts, you are right. Skew compensation is involved in this
                Update: homeall.g works as expected without the skew compensation
                  @Leonard03 Okay, thanks for testing! I'll highlight this to @dc42, hopefully it gives him something to focus on fixing.
                  I guess a follow up question is: do you need skew compensation enabled?
                    @droftarts Thank you 😊
                    @droftarts said in G30 during G28 issue:
                    This a very good question. I can answer with a maybe. But since in normal operation I don't encounter this bug, I think I leave skew compensation enabled for now.
                    Only time when this bug presents itself (and how I discovered it) is after "Resume after power loss". In that case I can rehome only the X and Y (Z axis remains enabled) without the probe. This gives a pretty substantial layer shift in the printed model after resume.
                    As a background: I use UPS and a mains power feedback thru a phone charger, a relay powered by the charger and two of the switching contacts of the relay connected to the duex.e3stop
                    This way, if power is out, I stop the print, disable nozzle heater, X and Y (and the UVW) but keep the bed up to temperature and Z steppers active as long as the UPS can provide power (about an hour). If the mains power comes back, I call M916 to do the resume. At this stage problems with this occurred.
                      dc42 administrators @Leonard03
                      @Leonard03 can you confirm that if you disable skew compensation, the original problem that occurred during homing no longer occurs?
                      droftartsundefined Leonard03undefined 2 Replies Last reply Reply Quote 0
                        droftarts administrators @dc42
                        @dc42 I'm pretty sure he did:
                          Leonard03 @dc42
                          @dc42 @droftarts yes, I can confirm. Without skew compensation enabled the issue is solved
                            @Leonard03 thanks.
                            I found a bug that may account for this issue. Please try the new firmware build at https://www.dropbox.com/scl/fo/dumsdufoej44q97ek9joo/AIBRnU-wtKfMrbWPzZwH_XY?rlkey=idmyinvvcuiwmycbb1l2obz38&dl=0.
                            Leonard03undefined gloomyandyundefined 2 Replies Last reply Reply Quote 1
                            • gloomyandyundefined gloomyandy referenced this topic
                              Leonard03 @dc42
                              @dc42 Thank you very much. I tested the new binary.
                              The issue is still there, but is way better.
                              Now, if I resume a print, the shift in X- direction got smaller - from 10mm to ~2mm. Not quite there, but much better
                                Leonard03
                                As a visual representation; all 3 prints had a "power failure" occurred to them 😄
                                  gloomyandy @dc42
                                  @dc42 It seems that the latest change has helped with this problem: https://forum.duet3d.com/topic/37913/3-6-0-rc2-error-g30-z-probe-readings-not-consistent
                                    @Leonard03 thanks for your feedback.
                                    Please try the new frmware build at https://www.dropbox.com/scl/fo/xk6t4cibc602j0s3qmp48/AGouwT4mDySsLdBItGjDUcM?rlkey=k8j1rrfx18ixoyvizvs0hbehz&dl=0 and report whether it is better/same/worse.
                                      Leonard03 @dc42
                                      @dc42 Thank you for the update
                                      Sadly, is still the same. 2mm shift in X-
                                      The left is without M556
                                      The right with M556
                                        @Leonard03 Thanks for your continued testing. Was the calibration cube on the right caused by a pause/resume, or by a "power failure" (please explain how you did this!)?
                                        I've just been testing this too, and find that I was able to provoke the bug when using G30 and skew compensation in 3.6.0-rc.3, but that it works correctly in 3.6.0-rc.3+1.
                                        With one bug resolved, I think there's something else going on when you pause and/or 'simulate a power failure', then resume/resurrect. It would seem that skew compensation is not applied, or the position is reset. When a print is paused, or there is a power failure, RRF creates a 'resurrect.g' file in the /sys folder, which is then used to return the tool to the correct position a resume the job. It could be that it is not applying skew compensation at the correct point during this.
                                        Could you:
                                        1. Start a print normally.
                                        2. Pause the print, or 'simulate a power failure'
                                        3. Send M556 to show the current skew compensation setting
                                        4. Copy the 'resurrect.g' file from /sys and post it
                                        5. resume the print and see if it shifts
                                        6. Post your pause.g, resume.g and the output of M556 (in case it has changed, or isn't being applied any longer)
                                        Thanks!
                                          @droftarts I also thank you for the continued help with this issue
                                          Those are fair questions, and I will split my answer in two parts:
                                          How it works and what actually happens
                                          My printer has two power plugs (one and a half actually 😆)
                                          First, is the main power plug. Is the power plug for the UPS. Then, in the UPS is plugged the printer's ATX power supply and from it the Duet and DueX are powered.
                                          The second, is a phone charger. A 5V 500mA power supply that serves as a power feedback.
                                          From it I powering a 5V simple relay. The switching contacts of that relay (two of them) are wired to duex.e3stop
                                          On that input, I have defined two triggers in config.g:
                                          M950 J2 C"^duex.e3stop"										; Input 1 uses e2stop pin, pullup enabled (power feedback for UPS)
                                          M581 P2 T2 S1 R1											; external trigger 1, trigger occurs on the inactive-to-active edge, trigger at any time (UPS Backup power)
                                          M581 P2 T3 S0 R2											; external trigger 1, trigger occurs on the active-to-inactive edge, trigger only when not printing from SD card (AC back, resume prompt)
                                          Trigger2.g senses if that relay has power to it, so if a print is in progress, it will be executed.
                                          It's macro is this:
                                          ; Called when mains power is intrerrupted and UPS battery is in use
                                          M118 S"Running on backup power !" L0	; display warning message when using UPS battery
                                          M25										; Pause printing process
                                          M400
                                          M0										; cancel current job
                                          M568 P0 A0								; turn off nozzle heater
                                          G91
                                          ; G1 Z-5
                                          M18 X Y E0								; Disable steppers to conserve battery power, but leave Z stepper energized
                                          M552 S-1								; Disable Wi-Fi adapter
                                          if global.MMUmode = true
                                          	echo >>"0:/sys/MMU Control/errLog.txt" state.time, ",", "Blackout occured", "Z="^move.axes[2].machinePosition-5	; -5 is the Z lift in pause.g
                                          	M18 UVW								; disable MMU steppers
                                          If the power goes out, the printer will continue to run on the UPS's battery, in the end safely shutting down the printer.
                                          From what I intended to happen.. is as follows:
                                          • Show a dialog that the power is lost (really this never shows because of the pause dialog that is shown after that; not a problem)
                                          • list itemPause the print (using the M25), stage that the ressurect is created (if I'm not mistaken)
                                          • Cancel the print (M0) (stop.g behaves a bit differently in this case, compared with a normal job end, I will describe it later)
                                          • Turn off the nozzle heater, for a safe shutdown if the power is not restored in time
                                          • Disable X, Y and extruder steppers to conserve power
                                          • Disable the WiFi adapter (if the power goes out, the router will be also powered off, so to prevent the board from continuing to search for the network and flood the PanelDue interface with dialogs complaining that it can't find the network)
                                          • If the MMU is enabled, disable its steppers as well (to conserve power) and log this event to a file.
                                          As stated above, regarding the M0 or stop.g in this scenario:
                                          ; stop.g
                                          ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                                          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 16:23:44 GMT+0200 (Eastern European Standard Time)
                                          G91
                                          G1 Z10 F6000										; lift z by 10mm
                                          if global.MMUmode = false
                                          	M221 S100 D0
                                          	T-1
                                          	M106 P0 S0
                                          else
                                          	M221 S100 D0
                                          	M221 S100 D1
                                          	M221 S100 D2
                                          	M221 S100 D3
                                          	M221 S100 D4
                                          	M572 D{state.currentTool} S0
                                          	G1 E3 F800
                                          	M106 P0 S0
                                          	T-1
                                          	M98 P"0:/sys/MMU Control/moveIdler.g" S5
                                          	M98 P"0:/sys/MMU Control/counterCheck.g"
                                          G90
                                          G0 X0 Y300 F3600																; go to the back left corner
                                          M18 X Y E0																		; disable X, Y and E steppers
                                          if global.MMUmode = true														; if MMU is enabled
                                          	M18 U V W																	; disable MMU steppers
                                          	if state.status = "processing"
                                          		echo >>"0:/sys/MMU Control/errLog.txt" state.time, ",", "Print complete!"
                                          M568 P0 A0																		; turn off tool 0 heater
                                          if sensors.gpIn[1].value = 1
                                          	M140 S-273.15																; turn off bed heater
                                          	if move.axes[2].machinePosition < 150
                                          		G1 Z150
                                          	M400
                                          	M18 Z
                                          	M81 S1																		; turn off ATX after nozzle cooldown
                                          In normal operation, at the end of the print, I lift the nozzle above the print, reset extrude factor override percentage just in case it was modified during the print, disable pressure advance, and an attempt to give the filament end a nice, sharp tip , so it can be loaded easily next time, then unload the filament.
                                          Then move the bed forward, park the tool carriage to endstop, disable the MMU steppers and turn off the nozzle heater.
                                          Now, if the power feedback says that there is no mains power (the charger, relay and duex.e3stop input), keep the bed at the print temperature, so the print will not detach from the print surface, and don't rise the Z too much but keep the Z steppers energized, so they keep their positions set by the G32 at the start of the print. Also, keep the power supply turned on (opposite to the M81 S1 if there are no power related issues)
                                          After this is completed, the printer will wait until the power is recovered. The UPS cand provide almost one and a half time to resume.
                                          How I resume after a power failure:
                                          If the printer is still powered on using the UPS and the mains power comes back, the phone charger will receive power again, turning on the relay. The relay, will tell the bord that power is back, so in the rising edge of the duex.e3stop will use the trigger3.g:
                                          ; Called when mains power is back
                                          M118 S"Back on AC power" L0									; display warning message when using UPS battery
                                          M552 S1														; Enable Wi-Fi adapter again
                                          if fileexists("0:/sys/resurrect.g")
                                          	M291 P"Back on AC power. Resume print ?" R"UPS Status" S3	; Prompt if printing can be resumed
                                          	M916														; Resume print after power loss
                                          		echo >>"0:/sys/MMU Control/errLog.txt" state.time, ",", "Blackout recovered"
                                          Now that everything is good to go:
                                          • Reenable the WiFi module and reconect to the router
                                          • Search for the ressurrect.g and if it is found, ask if the print can be resumed.
                                          • If I confirm, run the M916 command to go ahead.
                                          Resurrect-prologue.g is this:
                                          M17 E0
                                          G28 X Y						; home X and Y, hope that Z hasn't moved
                                          	M98 P"0:/sys/MMU Control/homeMMU.g"
                                          G91
                                          G1 Z-5
                                          • Reenable the extruder stepper (this is a very old bug in RRF. I can't use the MMU to load filament if the extruder stepper is disabled, so enable it before anything else)
                                          • Home X and Y axis (Z axis has never been disabled)
                                          • Rehome the MMU (UVW axis)
                                          • Lower the Z axis (I can't remember exactly why this is necessary, but it works)
                                            And after, RRF executes ressurrect.g.
                                          Until now, is anything that seems out of place?
                                          Pause.g is this, but is complicated:
                                          ; pause.g
                                          ; called when a print from SD card is paused
                                          	M83							; relative extruder moves
                                          	G10
                                          	G91							; relative positioning
                                          	G1 Z5 F600					; lift Z by 5mm
                                          	G90							; absolute positioning
                                          	G1 X0 Y0 F6000				; go to X=0 Y=0
                                          	M591 D0 S0
                                          else
                                          	if state.status != "paused"
                                          		echo >>"0:/sys/MMU Control/errLog.txt" state.time, ",", "Pause"
                                          	set global.pause = false
                                          	if state.status = "pausing"
                                          		if global.errQueue[#global.errQueue-1] = "SELECTOR_CANNOT_HOME" || global.errQueue[#global.errQueue-1] = "SELECTOR_CANNOT_MOVE" || global.errQueue[#global.errQueue-1] = "INSPECT_FINDA"
                                          			M18 U
                                          		elif global.errQueue[#global.errQueue-1] = "PULLEY_CANNOT_MOVE"
                                          			M18 V
                                          		elif global.errQueue[#global.errQueue-1] = "IDLER_CANNOT_HOME" || global.errQueue[#global.errQueue-1] = "IDLER_CANNOT_MOVE"
                                          			M18 W
                                          	if global.spoolJoin = false && global.loadNext = false
                                          		G10
                                          	elif global.spoolJoin = true
                                          		if global.loadNext = false
                                          			G10
                                          		else
                                          			M83
                                          			G10					; retract
                                          			G1 Z5				; lift
                                          			G90
                                          			G1 X310 Y0			; go outside bed
                                          			G11					; unretract
                                          			if state.currentTool = #tools - 1
                                          				T0
                                          			else
                                          				T{state.currentTool + 1}
                                          			if global.errQueue[#global.errQueue-1] = null
                                          				G1 E30 F300		; purge air from the nozzle
                                          				G10				; retract
                                          During normal operation, or at least for now, commands after line 21 are not used
                                          Pausing and resuming a print (not a power failure) works without problems, and the skew compensation has its normal value.
                                          M556 is defined only in config.g, and for testing purposes I comment or uncomment it.
                                          So I can do a power failure simply by unplugging the charger from its mains socket
                                          Both cubes in the photo above, had a "power failure", the only difference between them is the skew compensation
                                          A side note: the ressurect.g contains a resume command, but it behaves like a M24 P0 because it don't run the resume.g
                                            Leonard03
                                            Started now a print. Pause and resume works as expected, skew compensation is active
                                            Axis compensations - XY: 0.00690, YZ: 0.00000, ZX: 0.00000
                                            Inducing a "power failure" and resuming:
                                            So skew compensation is still active and correctly applied, but the shift is there
