    An attempt to investigate pressure in the extrusion system
    29
    3.1k
    • fmaundefined
      fma
      Well, you don't really need to upload videos, just to link them. I'm not sure what they don't forbid you to do…
      Can you freely install extensions?
      Frédéric
        @deckingman:
        @dc42:
        Hi Ian, regarding your comment "this free version of WordPress doesn’t allow me to embed Videos into posts (at least, I haven’t found a way of being able to do it)", I have a video embedded in mine. Just put the YouTube link on a line by itself. In HTML editing mode, mine looks like this:
        https://www.youtube.com/watch?v=xVrRGaeOiKA
        Note, no tags around it.
        HTH David
        Hi David,
        Thanks for that but what I meant was that I can't put the actual video clip into the post like I can with still images. For sure I can put links to YouTube videos (which is what I have done) but it means that readers need to switch between browser windows (one for the post and another for the video).
        Edit. To upload videos directly to the site I get this message "To upload video files to your site, upgrade your plan".
        If you do what I suggested then it will embed them. See the one at the end of https://miscsolutions.wordpress.com/mini-height-sensor-board/ (before the Appendix and comments).
          deckingman
          @fma:
          Yes, adding links to the videos that's is exactly what I do, because as I have said, the free version of WordPress does not allow me to upload them directly to my site. The link tool that WordPress supply is quite good in that you can add a link to the URL but then give that link a meaningful name. So instead of having https://www.youtube.com/channel/UCEMXNdKKMLIVwEqPvohKsng in the post, I can have something like "Click here to access the Linked Video". I can also change the behaviour, such as whether clicking the link opens a new browser window or not.
          No, I can't add extension either - just a limited number of themes, each with a limited number of options.
          For info, I use a paid version of WordPress for my main business web site, so I do know the difference. As my blog is purely for other people's benefit and I get nothing out of it, I'm not going to pay money for it. It's bad enough putting in the time. Of course, if someone else wants to cough up the annual fees for a paid site then I'll gladly upgrade 🙂
          • fmaundefined
            fma
            As said, you don't need to upload the videos on your blog ; recent wordpress releases allow you to embed videos just by putting the link (as David said), but previous ones need an extension. If you can't install it, then it is a problem.
            Frédéric
              @fma:
              I have had that video link working for 2-3 years. So support for this feature in Wordpress can't be all that recent.
                deckingman
                @dc42:
                Hi David,
                Just tried it again and it doesn't work for me. All I get is the link words but not the window with a play button like you have.
                I think it must depend on the theme. If you recall we had a similar discussion about how my posts were indexed (or not in my case) and your suggestion didn't work on my theme. Changing the theme to something else, did however work.
                  deckingman
                  @fma
                  It also depends on whether you are using WordPress.com or WordPress.org. WordPress.org means that you host the site so you can do pretty much anything you like. That's what I use for my decking web site. WordPress.com is hosted by Wordpress so they limit what you can do (or charge you money for the features you want). That's probably why the features available to me are limited - so that they can induce me to pay them money.
                  @All. Can we leave this discussion for another time or someone start another post please. The pros and cons and what you can\can't do with various WordPress plans have nothing to do with pressure in the extrusion system.
                  Thanks
                  • DjDemonDundefined
                    DjDemonD
                    @BDubs:
                    Very nicely done! I appreciate you sharing the research. I was really surprised to see that 40 watts was enough to melt all that material that fast.
                    Hi Ian, I was thinking the same thing about getting back on topic.
                    I sell 50w heaters and they get you up to temp quicker but the wattage whilst maintaining temperature is 8-9w and will be the same whether you use a 50,40,30 or 23w cartridge. It's getting the heat into the filament that is difficult. Circumferential heaters might do this better than larger heater blocks.
                    I'm sure a very long melt chamber would improve maximum volumetric throughput but would it decrease accuracy of extrusion? How differently does molten filament behave to solid? I don't know.
                    www.precisionpiezo.co.uk
                    • appjawsundefined
                      appjaws
                      Ian,
                      Thank you for all of your work to improve printing quality and speed. I found this blog and video very informative and clearly shows that pressure advance works really well for straight lines.
                      Is pressure advance needed for circles, after all circles are made up of very small straight lines so I can't see how pressure advance could work and be effective in such a short time and distance.
                      I wonder if it would be possible to only apply pressure advance for lines over a certain length?
                      anyway, great work, thank you
                      Paul
                      PS I left this comment on the blog.
                      appjaws - Core XYUV Duet Ethernet Duex5
                      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                      Ormerod 1-converted to laser engraver, Duet wifi
                      OpenSCAD version 2024.03.18
                      Simplify3D 5.1.2
                      • timcurtis67undefined
                        timcurtis67
                        Ian, As always, I like the research you do to advance printing. Excellent work.
                        I hope this isn't too far off the subject,
                        So far my brief take on pressure advance (minimum user experience) is that it would be more accurate if it were applied by the slicing software instead of the controller board. The slicer software would be better suited to determine segment lengths and apply pressure advance as needed. Small round shapes would be recognized and adjustments made at the time of processing the gcode file.
                        Just my opinion,
                        • Dougal1957undefined
                          Dougal1957
                          @timcurtis67:
                          Just my opinion,
                          And the Only Slicer I know that has this feature is Kiss 1.6.x although I believe they call it it Preload but it does work extremely well.
                          Doug
                          • BDubsundefined
                            BDubs
                            @DjDemonD:
                            I just visualized a toroid shaped heater…that would be interesting and way more consistent than a lop-sided cylinder somewhere in the block. Aside from coiled induction heaters I haven't seen one suitable for our needs yet.
                            This is interesting if you haven't seen it yet: https://3dplatform.com/extruders/ note that some models use 6mm filament. I was thinking about this while thinking of the diamond sucking in 3 filaments at the same time. I am wondering how they deal with enough melting and throughput. I am assuming they run higher wattage heaters.
                            6mm filament is 4.5 times larger (surface area and volume) compared to 2.85mm filament. So there's 4.5x more to melt in the chamber.
                              deckingman
                              @DjDemonD:
                              The Diamond 5 colour comes with an 80W heater for some strange reason (well I do know the reason but it's ill founded). It makes no difference to the melt rate and a 40Watt does the job just as well. It does get up to temperature really quickly but it's uncontrollable due to the large swings which even PID can't cope with.
                              As I've said before on numerous occasions, it's contact area between the heated surface and the filament that will help heat transfer. That and the time the filament is in contact with that hot surface. That's why mixing hot ends are so good for high speed printing (if you set the mixing ratio to 33% for each filament). Not only does a Diamond 3 colour have 3 melt chambers, but for any given print speed, each of the 3 filaments move through the chamber at 1/3 the speed giving much more time for the heat to penetrate from the surface through to the core.
                              One of these days, I'll see what speeds I can get up to with the 5 colour….........
                              • DjDemonDundefined
                                DjDemonD
                                @BDubs:
                                @DjDemonD:
                                See the mini hotend from deltaprintr, https://www.deltaprintr.com/product/mini-hotend/ I have one and it works great, a slightly larger heater would enable even better performance, as sudden changes in extrusion rate are not buffered by the smaller heat capacity of the heater block. But for any given set temperature I seem to heat filament to a higher temp than with an e3d style setup, this could be thermistor related sure but the circumferential heater as an idea has merit,
                                The other thing I think have got right is that their thermistor (which is very small) sits in a recess in the nozzle, so you measure and control nozzle temp, not heater block temp.
                                Love to see the 5 colour printing at max speed Ian.
                                  deckingman
                                  @timcurtis67:
                                  Just my opinion,
                                  Hi Tim,
                                  Interestingly enough, you are not the first to come up with that. One of my blog followers (Rob Miller) just sent me this link https://mattshub.com/2017/10/02/linear-advance/
                                  I swear I hadn't seen it before I did my tests. It's really spooky how they used the same test print method of parallel lines (nothing like the speeds I ran at though).
                                  I don't necessarily agree with their assertion that the pressure is simply a factor of the "springiness" of the filament. Maybe it is but I'd have thought that the pressure would be pretty constant regardless of the print speed whereas with my tests, there seems to a clear link between speed and pressure. Or if it was just springiness, it would be linked to the length of the move perhaps? Maybe it's right but it's a dangerous assumption to make without some actual measurements IMO.
                                    deckingman
                                    @DjDemonD:
                                    I might need to build a bigger printer. I'm not sure what the limit is for the 3 colour but with my bed size of 360mm, the best I could get with 500mm\s^2 acceleration is 424 mm\sec :). I guess I could up the acceleration and\or print across the diagonal…...........
                                    Ref filament melting - How about do away with the heater and use a near infra red laser???? 🙂
                                    • DjDemonDundefined
                                      DjDemonD
                                      Or induction, or various other methods. A resistor is cheap, simple and effective but we are talking extreme printing now.
                                        deckingman
                                        @DjDemonD:
                                        …......................but we are talking extreme printing now.
                                        That's my kind of talk!…...........I like extreme. 🙂
                                          deckingman
                                          So thanks to all those who tried to help this old guy sort his blog out - especially bot. It seems all I had to do was put the URL on a new line! - DOH.
                                          Anyway, video link is now embedded complete with fancy window and play button.
                                          All I need to do now is chop it up into smaller bits and embed each clip at the appropriate point on the post. Might be a while before I get time to do that though.
                                          • fmaundefined
                                            fma
                                            I watch the video and read the blog, yesterday night: very interesting!
                                            As I think it would be interesting to have a closed-loop XYZ system (using encoders), it would be even more usefull to have a closed-loop pressure regulating system. But as you said, this would require to find a way to measure that pressure.
                                            If you have an better idea what transducer could be used on your Diamond hotend, community might be able to help you getting one (either by financial help, or by providing one; some people may have access to such things)…
                                            Frédéric
