    Why don't you use Cura slicer?
    173
    32.1k
      Excellent. I hope Cura continues to improve. I have been impressed with the pace of development for version 3. I hope it keeps up.
      Will those settings affect bridging only, or overhangs as well? It would be nice if overhangs got some special treatment. There are times when I'd like to print outer walls first, but overhang performance suffers. Either speed and fan controls, or the ability to specify outer walls first, except on overhang layers, would be nice. The support generator already can tell the angle of overhangs to support, so hopefully special rules for overhangs could be made?
      • totalitarianundefined
        totalitarian
        @burtoogle:
        Just turn combing off, and then it won't drag the nozzle through the infill.
        That did it thanks
        • burtoogleundefined
          burtoogle
          OK, I'll look into what it will take to be able to specify settings for overhangs. A relatively easy solution would be to use the bridge settings for walls whose overhang angle is less than some threshold. Would that be acceptable?
            totalitarian
            @Phaedrux:
            1. Cura has no speed control for small perimeters like bolt holes so the quality of the holes is incredibly poor. It leaves gaps and drags the filament around the curve. This makes the holes weak. Slic3r knows to slow down and the hole quality is perfect.
            3. Slic3r has an ensure vertical thickness setting, which will find areas of the top surface that might need additional layers underneath them and will add some material in a gap fill pattern. Typically under curves surfaces. This ensures the top surfaces will properly fill. I often have gaps when I use Cura, and the solution given to me by Ultimaker is to just use more top layers and denser infill.
            6. Cura lacks variable layer height. It would appear that this is coming in the next release, so I look forward to that.
            Variable layer height has now bee added, although it's automatic.
            I too have noticed that I get gaps on curved surfaces. I think there is a setting to sure it but can't find where it is now.
            I too would like to slow down automatically on small parameters
              totalitarian
              One issue i've just noticed it curves don't play nice with pressure advance. Anyone else noticed a stuttering with it turned on?
                burtoogle
                David can confirm but I think that the latest beta of RRF has some fix for pressure advance related to the smoothness of extrusion rates in curves.
                  @burtoogle:
                  Yes I think that would work well. Overhangs and bridging are pretty similar in their requirements for slow speeds and lots of cooling so they stay in place. This one change alone would make Cura more usable for me.
                  One thing that Slic3r also has is an extrusion multiplier specifically for bridges, with the logic being that since you're extruding into thin air, you want a thinner extrudate so that it gets pulled taught, and there is less plastic, and therefore, less thermal mass so that it cools faster. I've found this very useful when printing with larger nozzle diameters.
                  I would also say that being able to look ahead and detect a bridge is about to begin and slowing down before leaving the edge of the supporting layer so that it has a chance to anchor itself. I notice that Slic3r will slow down a little too late and the extrudate will break or disconnect.
                  Also, I've just been looking into the variable layer height plugin and it looks really good. The manual GUI from Slic3r PE is a bit weird and fiddly to use. The 1.3 dev branch of Slic3r has an automatic function which obeys a full steps/mm value you specify which is a much better way to do it. I hope the Cura version is similar.
                  https://community.ultimaker.com/topic/20451-cura-variable-layer-heigth/
                    burtoogle
                    @Phaedrux:
                    Yes, I have a bridge flow setting which does the same as the slic3r extrusion multiplier.
                    What I have implemented is that the bridged region of walls extends a little onto the solid regions that support the bridge so that the bridge settings come into action just before the air below starts and finish just after the next solid region is encountered.
                    I am not involved in the variable layer height stuff other than I made some small contribution to speed up their implementation.
                      Your implementation sounds great. Can't wait to try it out.
                      • biscuitladundefined
                        biscuitlad
                        As far as the seg faults under linux go, I had another great one on a clean install. I want to add my K8400 dual nozzle. Can't.
                        I can add the single nozzle variant no problem. Try and add the second nozzle. Boom! Just dies.
                        Raised on it github. Discover it's an old bug that's still there after many months. Means it's impossible to add a dual nozzle printer. Again it's one of those annoying python gui issues that's causing it. So frustrating, both for users and the developers I imagine.
                        This is under the latest LTS version of Ubuntu.
                          burtoogle
                          Here's an example of bridge settings being used in overhang regions. There is a setting to control how much overhang is needed to use the bridge settings rather than the normal settings.
                          The Cura devs are not very quick at testing/merging PRs so it will take quite a while before this (or similar) appears in a release.
                            burtoogle
                            Here's a question - how do the other slicers handle the combination of bridges and support? Is bridging disabled when supports are in use?
                              In Slic3r there is a checkbox toggle to ignore supporting bridges. Just like there is for support on build plate only.
                                burtoogle
                                OK, thanks. Do you know what happens if both are enabled? WIll slic3r still print using bridge settings even when there is support below?
                                At the moment, my cura implementation has a switch to enable/disable the bridge settings (and, of course it has the on/off for the support as well) but if both the bridge settings and support are enabled, it will use both. It's actually quite a lot of effort (I think) to detect if an area has support under it so that the bridging can automatically be turned off so I wasn't going to do that.
                                  As far as I know, even with support turned on for bridges, it will still use the modified speed settings for the bridging sections. I'm not at my printer right now so I can't verify.
                                  But I do have access to slic3r right now. I made a simple STL to test. https://www.tinkercad.com/things/gXWCAMR5SEE
                                  It looks like for some reason even with support for bridging turned off it still adds a support for the outermost wall. I've never noticed that before. With Don't support bridges checked, and only on build plate unchecked, it will add supports on both outer walls, but not under the bridge. With only on build plate checked, it will add support for just the outer wall over the build plate.
                                  It might be easiest to download Slic3r PE and see how it behaves rather than me describing it.
                                    Also, I should say that Slic3r may not be doing it the best way either. The only thing it had going for it in my books was cooling control during bridges and speed control for more corner cases.
                                    • PropellerHatundefined
                                      PropellerHat
                                      Cura is in my opinion slightly better than Simplify3d. The biggest problems are the lack of custom support placement and the lack of simple things like temp and fan settings per layer numbers. There is a ton of adjustments that could be replaced by simpler ones, especially what comes to cooling. At my customer I print mainly with UMs and there is no way to poke around with thw exported gcode afterwards to set these things like "turn the fan on 70% from layer a to b".
                                        biscuitlad
                                        +1 for custom support placement / removal in cura. Surely has to be the no. 1 feature request.
                                        • Cataundefined
                                          Cata
                                          I try to use cura last week. A nigthmare to setting the machine and print settings for finally not have z offset option.
                                          • sverrebundefined
                                            sverreb
                                            Maybe this is a bit unfair as I just tested cura right now for the first time (because of this thread) coming from s3d.
                                            Parts layout is not very nice. I could not find any way to drop the part to the bed and had to resort to rotating and translating manually. This is way to clumsy. A basic drop face to bed needs to be implemented. Auto arrange placed parts outside the build volume
                                            In the gcode preview I accidentally moved a model which wiped out the gcode I was reviewing.
                                            No manual supports (yes I knew that, this is why I really didn't bother with it until today), and I do not se that i have any additional control over supports to make up for it. I use manual supports in 90% of my models (Most of the rest need no supports). I had to go hunting in the menus to actually get any semblance of controls to be visible. The usual problem I use manual support to solve is that I have parts with gaps that are too cramped to be able to extract supports from but can be bridged or can tolerate a little drooping, while I have other areas that needs the support. Hence the lack of control of the support is pretty much a dealbreaker.
                                            I could not find any way to save the print settings changes I did as a profile. I guess there is a way, but it is not obvious. Clicking the create button in manage materials (which is where I thought it would be) does not appear to do anything.
