    BLTouch getting triggered
    6.3k
    • garyd9undefined
      garyd9
      Do you use a macro to start mesh compensation? If so, I'd suggest calling G28 (to home), followed by:
      [[language]]
      ; assumes there are gcodes before this point to home the machine
      G91 ; set relative movements
      M400 ; ensure the homing movements are complete
      G1 Z5 ; get the nozzle away from the bed
      G4 S1 ; wait for the movement to actually finish - might have to increase S1 to S2
      M401 ; deploy the probe
      G29 ; start mesh checks
      M402 ; make sure the probe is retracted
      Any other place that you use the BLTouch, such as G30 calls, see what happens if you don't call "M401" and see if it works. I've found that many times I had explicit calls to M401 they weren't needed because the duet firmware knew to deploy on it's own. (It's a bit of trial and error to get it right.)
      Also, any time you do use the probe, ensure that you explicitly move the nozzle away from the bed (or the bed away from the nozzle) before any probe related gcodes.
      • pao_wikhanundefined
        pao_wikhan
        yes i home all then run mesh compensation button.
        compensation does not complete fully and if it does i see all red on the viewer and it is way above.
        i will try to make a macro over your script.
        Machine:
        hypercube evolution.
        • garyd9undefined
          garyd9
          M574 Z0 S0?
          What's in your homeall.g and homez.g scripts?
          A question I don't know the answer to (and probably not related to the original post): If using a BLTouch to home Z, shouldn't the M574 line for Z be "M574 Z1 S2"?
          Edit: added that my question probably isn't directly related to the OP's question
            @pao_wikhan:
            Machine:
            Did you see my reply yesterday?
              pao_wikhan
              Hi David, Gary, yes. i am tweaking the probe speed, dive height and travel speed, also probe trigger value;; looking for that good value.
              as for homing concerns it is homing indeed. but when i do a mesh compensation, it then reaches a point where the calibration stops or ends up with the 1000 value.
              im not sure if external factors are triggering the probe to be that.
              should i set M574 Z0 Snnn, n being 2? also Z1 or Z0?
              • garyd9undefined
                garyd9
                Depending on the contents of your homeall and homez files, the parameters for M574 I mentioned might not matter. (If you home Z using G30, they don't matter.)
                As for your problem, I'd like to try and help, but I'm not sure I'm understanding the problem. There aren't enough details for me to completely understand. Is the BLTouch going into an error (flashing red) state when the mesh probing stops working properly?
                If you're BLTouch probe is triggering when your nozzle is still over 3mm from the bed (as indicated by your G31 command), then you're probably going to need a larger "dive height" on the M558 command. Try going to 10. (That's the H parameter on the M558 command.)
                Try this: comment out your existing M558 command (don't delete it - just put a semi-colon in front of it) and add this one :
                M558 P5 X0 Y0 Z1 H10 F100 T4000
                (This is what I'm using and it works great. The only difference is that I have a H of 5, but my trigger height is less than 1mm.)
                After you save the config.g and the duet restarts, go into the web page, to the G-Code Console page, and type "M558" (With no parameters) and hit 'Send'. It should respond by showing you something similar to:
                "Z Probe type 5, invert no, dive height 10.0mm, probe speed 100mm/min, travel speed 4000mm/min, recovery time 0.00 sec, max taps 1, max diff 0.01"
                (This is just to ensure that the M558 command worked properly.)
                Please post back letting us know how this works out.
                Take care
                Gary
                  pao_wikhan
                  im guessing its a hardware thing. so i've removed the bed and trying to make it all be straight and aligned again.
                  will inform you when im back to software troubleshooting again.
                    pao_wikhan
                    okay so now im having this.
                    [[language]]
                    G29
                    Error: Z probe already triggered before probing move started
                      pao_wikhan
                      this is what i get when i center and do a home now.
                      [[language]]
                      2:50:26 PMG30 S-1
                      Stopped at height 3.962 mm  Z=3.96
                      2:49:13 PMG1 Z10 F200
                      2:49:05 PMG30 S-1
                      Stopped at height 3.968 mm    Z=3.97
                      2:48:57 PMG1 Z10 F200
                      2:48:51 PMG92 Z0
                      it seems the height is varying
                        pao_wikhan
                        [[language]]
                        2:59:53 PMG30 S-1
                        Stopped at height 4.013 mm                    Z=4.01
                        2:59:41 PMG1 Z10 F200
                        2:59:15 PMG30 S-1
                        Stopped at height 3.995 mm                     Z=4.00
                        2:59:03 PMG1 Z10 F200
                        2:58:01 PMG30 S-1
                        2:57:48 PMG1 Z10 F200
                        2:56:52 PMG1 Z0
                        2:56:38 PMG30 S-1
                        Stopped at height 3.978 mm                      Z=3.98
                        2:56:25 PMG1 Z10 F200
                        2:56:17 PMG92 Z0
                        2:55:36 PMG92 Z10
                        2:55:27 PMG31 P100 X0 Y0 Z3.97;
                        2:55:15 PMM558 P5 X0 Y0 Z1 H10 F100 T4000
                        2:54:51 PMG1 Z0
                        2:54:42 PMG28 Z
                        2:54:31 PMG1 X145 Y135 F2200
                        2:53:58 PMConnection established!
                        i settled with 3.97 as Zoffset
                        [[language]]
                        G29
                        9 points probed, mean error 8.429, deviation 0.212
                        Height map saved to file heightmap.csv
                        looking at the height map.its like its in the air.
                        [[language]]
                        RepRapFirmware height map file v2 generated at 2018-01-02 15:02, mean error 8.429, deviation 0.212
                        xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                        10.00,290.00,0.00,270.00,-1.00,108.80,108.80,3,3
                          8.383,  8.271,  8.016
                          8.469,  8.403,  8.299
                          8.609,  8.731,  8.682
                          pao_wikhan
                          now when i center again and run a G28 Z the Z is showing -12.84
                          im lost now..as when i run all the necessary parameters to ensure the bed to nozzle height changes.
                            pao_wikhan
                            reran G29 and now this is the height map.
                            [[language]]
                            RepRapFirmware height map file v2 generated at 2018-01-02 15:37, mean error 8.530, deviation 0.221
                              8.489,  8.348,  8.118
                              8.582,  8.517,  8.362
                              8.716,  8.834,  8.805
                            when i do a G28 Z and Z0, the offset is correct. is it possible that compensation is not working?
                              pao_wikhan
                              this is the updated endstop on config.g
                              [[language]]
                              M574 Z0 S2 ; Set active low endstops
                              M574 X1 Y1 S1 ; Set active high endstops
                              G31 P100 X0 Y0 Z4.7
                              M557 X10:290 Y0:270 S108.8 ; Define mesh grid
                                How are you homing Z?
                                After homing Z, does Z=0 correspond to the position when the nozzle is just touching the bed?
                                  pao_wikhan
                                  yes. i think i got it now.
                                  weird part is there is a deviation value that is ~8mm
                                  and it is always there.
                                  [[language]]
                                  Number of probe points: 9
                                  Probe area: 473.5 cm²
                                  Maximum deviations: 7.699 / 8.365 mm
                                  Mean error: 8.077 mm
                                  RMS error: 0.198 mm
                                    That mean error suggests to me that you have an 8mm error in your Z=0 position after homing and before bed probing.
                                      pao_wikhan
                                      Thanks All!
                                      David, Gary, and the guys on the hevo FB group that are here.
                                      im doing a test print, and ti seems like the offset changes.
                                      i had to do a babystep to compensate the offset.
                                      BTW, i updated my firmware to RC1 and it appears to be better.
                                      [[language]]
                                      Firmware Electronics:	Duet WiFi 1.02 or later
                                      Firmware Version:	1.21RC1 (2018-01-25)
                                      WiFi Server Version:	1.20
                                      Web Interface Version:	1.20
                                      Someone asked me to upload my home files.
                                      homeall
                                      [[language]]
                                      ; homeall.g
                                      ; called to home all axes
                                      ; generated by RepRapFirmware Configuration Tool on Wed Dec 27 2017 18:31:34 GMT+0800 (PHT)
                                      G1 Z7 F800           ; lift Z relative to current position
                                      M280 P3 S160 I1    ;Clear any alarm
                                      ;M401			; deploy probe
                                      G1 S1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                      G1 S1 X-305             ; home X axis
                                      G1 S1 Y-305             ; home Y axis
                                      G1 X5 Y5 F360000        ; go back a few mm
                                      G1 S1 X-305 F360        ; move slowly to X axis endstop once more (second pass)
                                      G1 S1 Y-305             ; then move slowly to Y axis endstop
                                      G90                     ; absolute positioning
                                      G1 X10 Y0 F360000        ; go to first bed probe point and home Z
                                      G30                     ; home Z by probing the bed
                                      ;G1 Z0 F100;            ; uncomment this line to lift the nozzle after homing
                                      homeZ
                                      [[language]]
                                      ; homez.g
                                      ; called to home the Z axis
                                      ;M280 P7 S160 I1    ;Clear any alarm
                                      ;G1 X10 Y0 F6000 ; go to first probe point
                                      • garyd9undefined
                                        garyd9
                                        Here's an irony:
                                        I'm going to be returning my BLTouch (to amazon.) When I first installed it, 5 probes in a row at the exact same place would differ by no more than about 0.03mm. That was tolerable. (Not great, but good enough to print with a .4mm nozzle.)
                                        After using it for less than a week, 5 readings in a row at the exact same location differ by nearly 0.2mm. At that range, my nozzle would be crashing into my glass build plate or I'd be air printing.
                                        Tried cleaning it, verified my mounting, verified my wiring, etc. I spent hours on google, but I'm quite certain my Duet board isn't impacted by a bug in Marlin. 😉 From what I've read, some people just have issues with the BLTouch… some have luck with a replacement, others don't.
                                        Maybe I'll reconsider the mini IR sensor.... or maybe I'll just slide pieces of paper under my nozzles every couple of days.
                                          pao_wikhan
                                          that is exactly my issue. now my offset is at 6mm. which is super weird.
                                            pao_wikhan
                                            im not sure if getting an authentic BLTouch would make a difference, im new to autolevelling so im not really sure.
                                            i tried the NPN probe but it wont work for me as im used to glass printing.
                                            now im quite lost at it.
