    BLTouch getting triggered
    6.3k
    • pao_wikhanundefined
      pao_wikhan
      okay so now im having this.
      [[language]]
      G29
      Error: Z probe already triggered before probing move started
        pao_wikhan
        this is what i get when i center and do a home now.
        [[language]]
        2:50:26 PMG30 S-1
        Stopped at height 3.962 mm  Z=3.96
        2:49:13 PMG1 Z10 F200
        2:49:05 PMG30 S-1
        Stopped at height 3.968 mm    Z=3.97
        2:48:57 PMG1 Z10 F200
        2:48:51 PMG92 Z0
        it seems the height is varying
          pao_wikhan
          [[language]]
          2:59:53 PMG30 S-1
          Stopped at height 4.013 mm                    Z=4.01
          2:59:41 PMG1 Z10 F200
          2:59:15 PMG30 S-1
          Stopped at height 3.995 mm                     Z=4.00
          2:59:03 PMG1 Z10 F200
          2:58:01 PMG30 S-1
          2:57:48 PMG1 Z10 F200
          2:56:52 PMG1 Z0
          2:56:38 PMG30 S-1
          Stopped at height 3.978 mm                      Z=3.98
          2:56:25 PMG1 Z10 F200
          2:56:17 PMG92 Z0
          2:55:36 PMG92 Z10
          2:55:27 PMG31 P100 X0 Y0 Z3.97;
          2:55:15 PMM558 P5 X0 Y0 Z1 H10 F100 T4000
          2:54:51 PMG1 Z0
          2:54:42 PMG28 Z
          2:54:31 PMG1 X145 Y135 F2200
          2:53:58 PMConnection established!
          i settled with 3.97 as Zoffset
          [[language]]
          G29
          9 points probed, mean error 8.429, deviation 0.212
          Height map saved to file heightmap.csv
          looking at the height map.its like its in the air.
          [[language]]
          RepRapFirmware height map file v2 generated at 2018-01-02 15:02, mean error 8.429, deviation 0.212
          xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
          10.00,290.00,0.00,270.00,-1.00,108.80,108.80,3,3
            8.383,  8.271,  8.016
            8.469,  8.403,  8.299
            8.609,  8.731,  8.682
            pao_wikhan
            now when i center again and run a G28 Z the Z is showing -12.84
            im lost now..as when i run all the necessary parameters to ensure the bed to nozzle height changes.
              pao_wikhan
              reran G29 and now this is the height map.
              [[language]]
              RepRapFirmware height map file v2 generated at 2018-01-02 15:37, mean error 8.530, deviation 0.221
                8.489,  8.348,  8.118
                8.582,  8.517,  8.362
                8.716,  8.834,  8.805
              when i do a G28 Z and Z0, the offset is correct. is it possible that compensation is not working?
                pao_wikhan
                this is the updated endstop on config.g
                [[language]]
                M574 Z0 S2 ; Set active low endstops
                M574 X1 Y1 S1 ; Set active high endstops
                G31 P100 X0 Y0 Z4.7
                M557 X10:290 Y0:270 S108.8 ; Define mesh grid
                  How are you homing Z?
                  After homing Z, does Z=0 correspond to the position when the nozzle is just touching the bed?
                    pao_wikhan
                    yes. i think i got it now.
                    weird part is there is a deviation value that is ~8mm
                    and it is always there.
                    [[language]]
                    Number of probe points: 9
                    Probe area: 473.5 cm²
                    Maximum deviations: 7.699 / 8.365 mm
                    Mean error: 8.077 mm
                    RMS error: 0.198 mm
                      That mean error suggests to me that you have an 8mm error in your Z=0 position after homing and before bed probing.
                        pao_wikhan
                        Thanks All!
                        David, Gary, and the guys on the hevo FB group that are here.
                        im doing a test print, and ti seems like the offset changes.
                        i had to do a babystep to compensate the offset.
                        BTW, i updated my firmware to RC1 and it appears to be better.
                        [[language]]
                        Firmware Electronics:	Duet WiFi 1.02 or later
                        Firmware Version:	1.21RC1 (2018-01-25)
                        WiFi Server Version:	1.20
                        Web Interface Version:	1.20
                        Someone asked me to upload my home files.
                        homeall
                        [[language]]
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool on Wed Dec 27 2017 18:31:34 GMT+0800 (PHT)
                        G1 Z7 F800           ; lift Z relative to current position
                        M280 P3 S160 I1    ;Clear any alarm
                        ;M401			; deploy probe
                        G1 S1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                        G1 S1 X-305             ; home X axis
                        G1 S1 Y-305             ; home Y axis
                        G1 X5 Y5 F360000        ; go back a few mm
                        G1 S1 X-305 F360        ; move slowly to X axis endstop once more (second pass)
                        G1 S1 Y-305             ; then move slowly to Y axis endstop
                        G90                     ; absolute positioning
                        G1 X10 Y0 F360000        ; go to first bed probe point and home Z
                        G30                     ; home Z by probing the bed
                        ;G1 Z0 F100;            ; uncomment this line to lift the nozzle after homing
                        homeZ
                        [[language]]
                        ; homez.g
                        ; called to home the Z axis
                        ;M280 P7 S160 I1    ;Clear any alarm
                        ;G1 X10 Y0 F6000 ; go to first probe point
                        • garyd9undefined
                          garyd9
                          Here's an irony:
                          I'm going to be returning my BLTouch (to amazon.) When I first installed it, 5 probes in a row at the exact same place would differ by no more than about 0.03mm. That was tolerable. (Not great, but good enough to print with a .4mm nozzle.)
                          After using it for less than a week, 5 readings in a row at the exact same location differ by nearly 0.2mm. At that range, my nozzle would be crashing into my glass build plate or I'd be air printing.
                          Tried cleaning it, verified my mounting, verified my wiring, etc. I spent hours on google, but I'm quite certain my Duet board isn't impacted by a bug in Marlin. 😉 From what I've read, some people just have issues with the BLTouch… some have luck with a replacement, others don't.
                          Maybe I'll reconsider the mini IR sensor.... or maybe I'll just slide pieces of paper under my nozzles every couple of days.
                            pao_wikhan
                            that is exactly my issue. now my offset is at 6mm. which is super weird.
                              pao_wikhan
                              im not sure if getting an authentic BLTouch would make a difference, im new to autolevelling so im not really sure.
                              i tried the NPN probe but it wont work for me as im used to glass printing.
                              now im quite lost at it.
                              • bartolomeusundefined
                                bartolomeus
                                I have an original bltouch which is working fine. Here's my homez for reference:
                                [[language]]
                                ; homez.g
                                M561			;reset bed compensation
                                T0 			;select tool
                                G91 			;relative coordinates
                                M280 P3 S160 I1		;release Z probe alarm
                                G1 Z5 F2000 		;lower bed
                                G4 P500 		;wait for the bed to lower
                                G90 			;absolute positioning
                                G1 X145 Y145 F3000	;move to center
                                M401			;deploy the probe
                                G30 			;calibrate Z-axis
                                M402			;Retract Probe
                                And the endstop part of config.g:
                                [[language]]
                                M574 X2 Y1 S1                            ; Set active high endstops
                                M574 Z1 S2                               ; Set endstops controlled by probe
                                M307 H3 A-1 C-1 D-1 			 ; bltouch
                                M558 P5 X0 Y0 Z1 H3 F250 T3000		 ; bltouch
                                G31 X-25 Y20 Z2.8 P25			 ; bltouch offset
                                M557 X15:265 Y25:275 S80		 ; Define mesh grid
                                  pao_wikhan
                                  okay..so i fixed the mean error. now this is my current, i placed a debug mode on the config.g as it is weird it stops at the same place all the time.
                                  still i am able to home with 3 of 5 the probe not alarming.
                                  [[language]]
                                  confg.g
                                  M667 S1        ; Select CoreXY mode
                                  M208 X0 Y0 Z0 S1                                                             ; Set axis minima
                                  M208 X300 Y285 Z300 S0                                                       ; Set axis maxima
                                  M574 Z0 S2        ; Set active low endstops (z end stop disabled)
                                  M558 P5 X0 Y0 Z1 H7 F100 T3000              ;debug mode
                                  G31 X25 Y0 Z3.31 P30                            ;debug mode
                                  ;M558 P5 X0 Y0 Z1 H10 F100 T4000                                             ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds  BLTOUCH
                                  ;G31 P5 X0 Y0 Z5                                                             ; Set Z probe trigger value, offset and trigger height BLTOUCH
                                  M557 X0:300 Y0:285 S50                                                   ; Define mesh grid
                                  [[language]]
                                  bed.g
                                  ; Probe the bed at 4 points
                                  G30 P0 X10 Y0 H0 Z-99999
                                  G30 P1 X10 Y265 H0 Z-99999
                                  G30 P2 X275 Y265 H0 Z-99999
                                  G30 P3 X275 Y0 H0 Z-99999
                                  G30 P4 X145 Y135 H0 Z-99999 S
                                  [[language]]
                                  ; homeall.g
                                  M280 P3 S160 I1        ; Clear any alarm
                                  was able to have this deviation after placing the bed, then i tried to relevel the bed then i cannot get to mesh completely as it is stopping at the same point.
                                  [[language]]
                                  RepRapFirmware height map file v2 generated at 2018-01-06 20:56, mean error 0.248, deviation 0.204
                                    0.029,  0.200,  0.093
                                    0.010,  0.435,  0.245
                                    0.110,  0.541,  0.572
                                    pao_wikhan
                                    when it reached that spot on the bed the probe triggers an alarm..which is super weird.
                                      pao_wikhan
                                      my bed is warped lightly on the middle, is that why i cant do a correct calibration?
                                        pao_wikhan
                                        able to do a 9pt mesh compensation, is there a limit to the compensation?
                                          pao_wikhan
                                          ended up doing a 4pt as the middle of the bed is stopping the probing.
                                            Try increasing the Z dive height parameter, that's H in the M558 command.
