Changeable Z babystep icons.
Duet Web Control wishlist
11
23
3.2k
    dintid
    The icons now reflects tower printers (Prusa style) where the hotend moves up and down, but is in reverse of printers where the bed moves up and down (Ultimaker style).
    Ie z+ icon is a thumb up, but z+ makes my bed go down.
    It’s hugely confusing for some reason. Please either make different sets to choose from, or redesig to more “neutral” icons where distance is show by indicating distance between nozzle and bed.
    RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
      Dougal1957
      the icons indicate the distance between the Nozzle and the bed ie up or + is an increase in that gap and has no relation to the direction the bed is moving.
        fma
        I also find the icons confusing. I propose icons like:
        Or even just the arrows…
        Frédéric
          DjDemonD
          You can't suit all configurations on some machines +z is head moving up on others +z means the bed goes down. I have a corexy and a delta so it's forever catching me out.
          www.precisionpiezo.co.uk
            ephemeris
            I'm glad I'm not the only one who can't make sense of it. Something like the iconography suggested by fma would be much appreciated.
              Danal
              As currently implemented in the Duet Web, these are not actually icons. They are characters from the "halfling" glyph font.
              That font does not contain the exact suggestion that FMA made above; it does contain an up arrow above a bar, and a down arrow above a bar. Take the bar for the bed, and the arrow for nozzle spacing, and it makes some sense.
                Danal
                If you want to try this on your machine:
                1. Download DWC from github. https://github.com/chrishamm/DuetWebControl
                2. Inside the zip created by github, there is another zip named DuetWebControl-1.20.zip. Pull that out somewhere.
                3. Rename it to remove the release number. DuetWebControl.zip
                4. Inside that file, there is a css folder, containing file dwc.css.gz. Extract that file somewhere.
                5. Inside the dwc.css.gz file, there is a file dwc.css. Extract that file somewhere. (if you can't deal with a .gz file on your own, you probably should not do this…)
                6. Edit the dwc.css file.
                  Find the string "\e129" and replace with "\e167"
                  Find the string "\e130" and replace with "\e166"
                  Be careful not to change anything else. In particular, DO NOT introduce new 'line ends' via word wrap, hitting enter, etc, etc.
                7. Replace inside dwc.css inside dwc.css.gz, and then replace that inside the css folder in dwc.css.zip
                8. Upload the whole zip via the normal web dialogs.
                Check out the page. If you want to back out, either reverse the edits, or upload then entire DuetWebControl.zip as it came from github.
                  Danal
                  OR…
                  Just mount your micro-SD in a PC or Mac, and directly edit the dwc.css file.
                    fma
                    I just did the change on my install… These characters are perfect!
                    Thanks!
                    Frédéric
                      DjDemonD
                      Perhaps just using the words open and close would solve the problem as an alternative to the icons.
                        T3P3Tony administrators
                        Danal
                        If you are comfortable using Github then you can submit a pull request to christian to incorporate the different icons if they are clearer (I think they are better than the finger pointing)
                        Maybe also modify the however over text from "lower the printhead…" to "decrease the space between the printhead and the bed..." etc.
                          fma
                          +1 for the help text.
                          Frédéric
                            parovoZZ
                            What is z babystep?
                              fma
                              It allows you to adjust the bed Z position while printing, in case the zero is not good. Very usefull.
                              Frédéric
                                parovoZZ
                                @fma:
                                Thanks!
                                  Lakko
                                  @Danal:
                                  Is there a way to invert the hands symbols?
                                  In my coreXY printer if i made a +0.05 the bed goes down and not up and vice versa.
                                    fma
                                    Just invert "\e129" and "\e130"…
                                    Frédéric
                                      Lakko
                                      @fma:
                                      ok thank you!
                                        Danal
                                        @T3P3Tony:
                                        Danal
                                        I will do that. Separate request for the hover over text, as that would seem to be no-debate. He may or may not like the symbols. Also, I'll see if I can find even better symbols in another font.
                                        • Lakkoundefined
                                          Lakko
                                          I've tried but it seems i get a corrupted gz file, in fact i cannot connect to the duet.
                                          i came back to the old file and now it can connect again to wifi
                                          Is there a good program to create gz file? i have used 7zip but with no lucky
