    Webcam integration.
    Duet Web Control wishlist
    1.3k
    • akku3Dundefined
      akku3D
      hello forum,
      I'm running a webcam (logitech c270) on a raspberry pi zero w with motion eye.
      The integration into the duet web interface works great.
      Now I would also like to make timelaps recordings. Does anyone have a tip on how I can do that?
      Awesome would be a button in the duet web interface to start the timelaps.
      • Cataundefined
        Cata
        Is better to add the start and finish of the timelapse with codes in the gcode.
        • fmaundefined
          fma
          M42 G-Code can switch a pin (you can free a fan output with M106 and I negative param).
          If this pin could be read by MotionEyOS and trigger the start of timelapse…
          Frédéric
          • akku3Dundefined
            akku3D
            Hello Frédéric,
            can you explain that in more detail please! preferably step by step.
            • fmaundefined
              fma
              This is just an idea! I didn't dig it… I think it is easy to set a pin on the Duet (using M106 / M42), but I don't know how to trigger a timelapse with MotionEyeOS; this is something you should as on MotionEyeOS list (if there any).
              Frédéric
              • peter247undefined
                peter247
                To me you want to take a picture on every increase of the Z layer height which I`ve heard ocaprint does , so why reinvert the wheel.
                So what is needed is a macro for every increase in layers ?.
                Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                  T3P3Tony administrators
                  Many slicers have the ability to insert GCode at layer change.
