Black printbite and IR Sensor - very inconsistent heights?
IR Height Sensor
10
30
4.5k
    Dougal1957
    can you lower your IR Sensor by about 1 mm in relation to the nozzle?
    I think the recommended distance is between 1 and 2 mm but it is a while since I used one
      RGN01
      Yes, I could try that but I don't have much height to play with. The dimension I quoted to David is the height of the bottom of the sensor board above the PrintBite when the sensor triggers - 3.3mm approximately. At that point the nozzle is 2.26mm above the PrintBite so the height difference is close to the recommended 1.5mm - actually a bit lower than recommended but it never fouled a print on the previous print surface (PEI on a black PCB heatbed).
      Now that I've made the change to aluminium plate and added the PrintBite I'm beginning to wonder if that inductive proximity sensor isn't my best bet. Either that or a BL Touch, perhaps.
      Richard
        RGN01
        I've just used Blu-Tack to mount an inductive sensor under my carriage and tested that manually by monitoring the LED on it as I lowered the nozzle. Even like that it is repeatable to less than 0.01mm and the peaks and valleys seem to have gone.
        I just need to figure out how to wire it up (I'm already using an NPN inductive sensor on Z-max as my Z-home and only want this one for Z-probe, not homing.
        Richard
          I'll ask Jason again for a sample of matt black PrintBite to test the IR sensor with.
            RGN01
            Thanks, David.
            It does seem to be something to do with the interaction between the PrintBite and the IR sensor. I'm busy printing a mount for the inductive sensor and will try that later.
            Is it possible to connect the NPN inductive sensor yo the Z-probe input of the Duet WiFi through a Schottky diode? Is it the Z-Probe_In pin that I connect to the diode and the sensor and then just set it as a switch input?
            Richard
              @RGN01:
              Yes, see the wiki. If you use the Z probe input then an ordinary small signal silicon diode will probably work too if you don't have a Schottky one.
                Mutley
                Hi Richard, Generally it has been positive feedback with the IR sensor on the black (matte) PB. Dave will have some to test early in the week. Possibly a silly question but any surface imperfections or scratches on the PB that might be distorting the readings?
                J
                  RGN01
                  Thanks, I found the new one (the format is growing on me) and got it sorted. The applicable lines in config.g are as follows:
                  [c]; IR Z-probe
                  M558 P1 H4 F250 T2000 ; Set Z probe type to unmodulated and the dive height + speeds
                  G31 P500 X9 Y21 Z2.26 ; Set Z probe trigger value, offset and trigger height
                  ; Inductive Sensor
                  M558 I1 P5 H4 F250 T2000 ; Set Z probe type to digital and the dive height + speeds (I1 = invert signal)
                  G31 X9 Y21 Z2.26 ; Set Z probe trigger value, offset and trigger height
                  [/c]
                  I'm constantly amazed at the ease of changing things with the Duet!
                  Richard
                  (edited to fix typos)
                    @RGN01:
                    T
                    "One firmware binary to rule them all" (all Duets that is) - with apologies to JRR Tolkien.
                    Seriously, we want you to be able to change ANYTHING that isn't a 1-off requirement by sending the appropriate GCode, either in config.g or live from DWC or USB. I even have a macro for homing my Cartesian printer and then turning it into a pretend CoreXY printer for firmware testing.
                    In the unlikely event that your requirement is a 1-off (e.g. the user who recently needed to add a 13th stepper driver), RepRapFirmware is open source so you have the freedom to modify it - and it will stay that way.
                      RGN01
                      To close this out - I'm now using a TL-W5MC1 inductive proximity sensor and am getting repeatability of about 0.002mm and the PrintBite is showing as flat to all intents and purposes.
                      I'm adjusting a few things to now get it level but one step closer and that sensor works well - especially at the price! https://www.ebay.co.uk/itm/5mm-Noncontact-Inductive-Proximity-Sensor-Switch-Detect-DC-6-36V-NPN-TL-W5MC1-/253114333447
                      Richard
                        rkrammes
                        My results with the matt white Printbite+ with a grid. 😞 I purchased my sensor more than a year ago and it is not a surface mount board. Would it be worthwhile to put some electrical tape in the corners and define points there for probing? I really like both this sensor and Printbite but if one has to go unfortunately it will be the sensor.
                          GeckoBox3D
                          @dc42:
                          Any update on this? I've been waiting to see someone's results for a while as my old gridded printbite gives horrendous IR probe results
                            I've just chased for samples again.
                            JohnOCFIIundefined 1 Reply Last reply 22 Apr 2018, 02:26 Reply Quote 0
                            • JohnOCFIIundefined
                              JohnOCFII @dc42
                              @dc42 Any chance yet to re-test the IR sensor with PrintBIte?
                                Thanks for the reminder, I've chased again for a sample.
                                  npm1
                                  Would TL-W5MC1 be better than the cylinder inductive sensors or would they be equal in experience and deviation.
                                  Please let us know of ur experience.
                                  Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
                                    nyt
                                    I use the black matte printbite with an ir sensor I got off ebay. It's quite consistent when doing mesh leveling, but sometimes homing is a bit off compared to the leveling.
                                    https://www.ebay.com/itm/Mini-IR-Differential-Height-Sensing-Board-with-1-Cable-3D-Printer/152929325455
                                    And here you can see the center point, which is the same as the homing probe point, is off by 0.03mm
                                      To get accurate homing, make sure that the XY position at which you home Z coincides with one of the points in the mesh. This isn't as easy as it sounds, because when you execute G30 to home Z, probing is done at the current location; whereas when you use G29 to generate a height map, the nozzle position is adjusted to allow for the offset of the probe. So in homez.g and homeall.g, choose the XY location that you send the nozzle to before you execute G30 so that it is at the location of a probe point close to the centre of the bed minus the Z probe XY offset that you specified in the G31 command.
