My duetwifi seems to have died :(
3.0k
    gzcwnk
    Printed Ok this morning, went back to it and switched it on and while the LEDs come on, no webui, IP not pingable, so no wifi. Some fans spin up, part cooling and cold end, board cooling fan is not being spun up, tested with external power spins OK.
    I have 3 red LEDS, green LED has not worked for a long time (if ever).
    I can see the comm port in device manager, I have swapped ports and usb cables but it is not being recognised if the troubleshooting FAQ is correct.
    I installed duetsetup (or tried to)
    Connected Ok with pronterface to com5.
    Um well the help FAQ is a bit lacking, like what do I do now?
      gzcwnk
      In prontoface when I hit an axis the steppers hum a bit but nothing moves.
      I can see 24v on the PSU LED.
        gzcwnk
        Step bed temp, temp rises OK.
          gzcwnk
          M115
          SENDING:M115
          FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.16 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2016-11-08
          M115
          SENDING:M115
          So its "alive" I suppose
            gzcwnk
            So updating firmware I get,
            M997 S0
            Error: In-application programming binary "iap4e.bin" not found
            [ERROR] Error: In-application programming binary "iap4e.bin" not found
              gzcwnk
              Ok found that….installed it to /sys.
              SENDING:M997 S1
              Trying to connect at 230400 baud:
              success
              Erasing 4096 bytes...
              Erasing 233472 bytes...
              Uploading file...
              5% complete
              10% complete
              15% complete
              20% complete
              25% complete
              30% complete
              35% complete
              40% complete
              45% complete
              50% complete
              55% complete
              60% complete
              65% complete
              70% complete
              75% complete
              80% complete
              85% complete
              90% complete
              95% complete
              Upload successful
                Before trying to update the firmware on maybe not working hardware try disabling and reenabling the wifi module.
                M552 S0
                M552 S1
                What does m552 return in pronterface?
                  Well at least it was successful? πŸ˜•
                    gzcwnk
                    m115
                    SENDING:M115
                    FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-23
                    M587 S"24G" P"mypassword" never returns. Nothing on wifi router.
                    Trying to set up the wifi and no workie
                      There are pretty specific steps for upgrading to 1.20 from an older firmware. It's a bit of a change from previous updates. Did you follow those steps?
                        gzcwnk
                        Ok when I send the above it switches my password to uppercase by the look of it. M552 S1 says wrong password
                        πŸ˜•
                          https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_Installing_and_Updating_Firmware
                          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_to_DuetWiFiFirmware_1_Num_19
                            gzcwnk
                            as far as I know.
                              gzcwnk
                              Ok so this is a 3rd set of instructions!
                                gzcwnk
                                OK so its all upper case so I need to find something else to send commands with
                                  gzcwnk
                                  M98 P/macros/SetNetwork
                                  Warning: Macro file /macros/SetNetwork not found.<lf>ok<lf>Warning: Macro file /macros/SetNetwork not found.<lf>ok <lf>hmmm something wrong here…</lf></lf></lf></lf>
                                    gzcwnk
                                    M552 S1
                                    ok<lf>WiFi module started <lf>M587
                                    Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>?
                                    It can see 24G so wifi hardware must be OK?
                                    I know the password is correct.</lf></lf></lf></lf></lf></lf></lf></lf>
                                      gzcwnk
                                      M587 S"G24" P"xxxxxxx"
                                      M587: Failed to add SSID to remembered list<lf>ok <lf>?</lf></lf>
                                        gzcwnk
                                        OK I am failing to get an IP address.
                                          gzcwnk
                                          (COM7) Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>G24 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle</lf></lf></lf></lf></lf></lf>
                                          4 out of 31
