    Horrible print quality vs Arduino, my bad ?
    2.3k
    • number40fanundefined
      number40fan
      It has been a while since I have seen It discussed, but do you have M82 or M83 in the start of your .gcode.
      Arturundefined 1 Reply Last reply Reply Quote 0
      • Arturundefined
        Artur @number40fan
        @number40fan Nothing at the start of the gCode, but I have M83 in the config file, and also have the "relative extruder move" checked in Simplify, which I believe sends the M83 command on it's on. Would this be a problem ? (Pictured benchies where generated on Cura, which I believe does not use the relative extruder moves ?)
        PS: Actually,.. I just checked my Cura gCode and have found this : ;
        Generated with Cura_SteamEngine 3.2.1
        M190 S95
        M104 S230
        M109 S230
        M82 ;absolute extrusion mode
        This could be something,but, if this was all that is wrong, my print should have also been bad in the Arduino, wouldn't it ?
        • carlossprundefined
          carlosspr @Artur
          @artur said in Horrible print quality vs Arduino, my bad ?:
          Unstable wifi, it spontaneously resets it's IP.
          Have you checked that the MAC address does not exist in your other devices?. Duplicated MACs would generate stability issues.
          Regarding the overextrussion, It may also be the extruder stepper driver losing control. Is the current configuration according to the stepper rating?. I use 70% and works fine.
          • Arturundefined
            Artur @carlosspr
            @carlosspr There are no other equal MAC address in our network, and this happens with more than one board (can't say if all).
            Stepper driver is rated for 2.5A, tipically, we are driving them on 800mA since it's more than enough for reliable operation on our machines.
            I've tested the DUET on 0.8A to 2A and the problem is consistent for all currents.
              Phaedrux Moderator @Artur
              @artur using absolute extrusion on the gcode and relative in the firmware is going to cause problems. Cura can use relative as well. It's a hidden setting by default.
              • Arturundefined
                Artur @Phaedrux
                @phaedrux aren't the relative extrusion of the firmware overrided by the M82 command on the beginning of the gCode ?
                  @artur I was under the impression that the generated gcode was also different, but I could be wrong.
                  In Cura do you have RepRapFirmware selected as your gcode flavor?
                    If it was an absolute/relative issue then you wouldn't be able to get a print at all. Chances are that you have one of the configuration parameters set vastly different between the two firmwares. Is there any obvious change in the way that the machine moves?
                    • Arturundefined
                      Artur @dc42
                      @dc42 There is, it looks more Jerky in general. I've tried with the exact same acceleration and Jerk parameters (adjusted between mm/s and mm/min) and it was worse.
                      @Phaedrux Good point, it was on Marlin, I'm going to test that. Still, the problem also exists with S3D which has a Marlin/Reprap option selected. So I don't really believe this will solve the issue.
                      • Arturundefined
                        Artur
                        @Phaedrux Reprap flavor seems in Cura seems to give the print a better quality, but still not on pair with what we usually get using an Arduino.
                        @dc42 The Jerky movement have been lessen by reducing the max acceleration to 1500mm/s2 from 3000mm/s2. It now have the same overall fluidity has the arduino has with 3000mm/s2. What am I missing here ? Is there and hidden parameter I forgot to chance somewhere ?
                          @Artur, does the print complete in the same amount of time on the two systems?
                          Can you post videos of the same part being printed on your Arduino system and on Duet, with the same speeds and other parameters?
                          Because of 3D Meetup Sweden I haven't compared the settings in your Configuration.h and config.g files yet, but I will do that soon.
                          • Arturundefined
                            Artur
                            @dc42 I'll make the test, film it and I'll post. Thank you.
