Welcome to the New Forum
@briangilbert This is NodeBB. It is very similar to Discourse but I doubt that the Discourse app would work.
@msquared thanks.. do you know if there is a mobile app that supports it?
Beside Safari
Hey All,
I believe that I found and resolved the issue that was causing errors on the forum during peak load times. Please let me know if you continue to see any errors. Thanks!
-M
@briangilbert said in Welcome to the New Forum:
Beside Safari
Maybe they is a Tapatalk plugin?
Is there a PM function?
How do I stop getting email notifications? I have turn off all notifications already...
@resam said in Welcome to the New Forum:
@T3P3Tony any chance to improve the email notifications? They completely mess up the markup. Not even quotes are displayed correctly - it's just the whole text in a single line... This makes it really difficult to follow and actually read, because "old quoted text" is indistinguishable from the actual new reply text.
Basically this open issue: https://github.com/NodeBB/NodeBB/issues/6348
Would be nice if you could raise your voice over there to put some attention on it! -
Hey, sorry to complain, but, why do web 'programmers' persist in creating websites where the background is all white, while presenting system text in a light grey font? Are they retarded? I know that Wozniak envisioned a world where no paper would be used in the then upcoming computer environment. But, paper doesn't glow, computer screens do. They generally glow bright white, which causes the Human pupil to contract...restricting the intensity of the light entering the eyeball, but then the text is a light grey color! So the pupil must dilate to allow enough light into the eyeball for the brain to be able to recognize the characters. End result? Old-f.arts suffer significant eyestrain, but its a kewl website.
@3mm Thankfully, there are a number of different "skins" you can choose. The one I'm using now has white text on a gray or black background.
You can access this via the Profile menu in the upper right of the window. Under that, choose settings. in the upper left is the "Select a Skin" setting. The one I'm using now is called "slate." There are many others too.
John
@otaku521 You will probably still be getting notifications from individual topics you were watching (either due to automatic settings or manually clicked watching) if you de-select watching on this threads you should stop getting any email notifications.
Is there a small manual for the new forum?
For example, I do not find that correct information about incorporation of code.
I saw this string by chance
```TEST```
Are there any more, as in old forum.
@zerspaner_gerd Most of the features for dealing with the options for text/code etc are explained here:
My first post in this thread has some information about how to upload images etc.
Cheers
