    [Off topic] all metal pla clogging
    4.6k
      deckingman
      It's heat creep. The filament softens and swells in the area of the heat break.
      What you can do.
      A) Use the least amount or retraction possible. With too much retraction, you can pull molten filament up into or beyond the heat break where it will then cool and solidify.
      B) Print at a lower temperature if at all possible.
      C) Try a more powerful fan to increase the air flow over the heat sink.
      D) Ditch the all metal heat sinks and use the Lite version with a PTFE liner all the way through the heat break.
      "D" will almost definitely cure the problem but then you will be limited to printing at lower temperatures due to the fact that PTFE starts to degrade at around 230 degC. Which is fine for PLA, PETG, ABS etc but not for some of the more exotic filaments.
      • denkeundefined
        denke
        Thanks for the reply, understanding waht really happens helps a lot!
        I'll try to swap the fan.
        What do you think of a layer of silicone between the heater block and the radiator to reduce the radiated heat? Or will that just make the problem worse because sillicon has a higher thermal conductivity than free air?
        • dragonnundefined
          dragonn
          10mm retraction is way to much on a full metal. Even on bowden system, in my printer I have it between 1-2mm. What I find out is that pressure advance helps a lot with keeping the retraction low. But first check that the airflow around the heatsink is blocked like cables behind it. I personally really like the Prusa i3 MK2 solution which allows much better airflow around the heatsink, I even adopted it in my Hypercube Evolution
          • Qdeathstarundefined
            Qdeathstar
            Dyzend has water cooling as an option which would surely solve the heat creep issue....
            I can’t seem to find any real reviews on the dyzend. I’m sort of skeptical about toms reviews because everything he gets is “very good” and that’s suspicious....
            dragonnundefined 1 Reply Last reply Reply Quote 0
            • dragonnundefined
              dragonn @Qdeathstar
              @qdeathstar E3D has water cooling solutions already too. But in my opinion this is overkill unless you a printing in a heated chamber.
              Qdeathstarundefined 1 Reply Last reply Reply Quote 0
              • denkeundefined
                denke
                @dragonn The 10mm was just a test, for an idea that if the retracted filament had more time to cool down ... I was flying kind of blind about the issue.
                @Qdeathstar @dragonn I'm using a smart effector, I'm not sure if a water cooling solution could work with it. Please prove me wrong 🙂
                I'm using some noname chineese 40x40x10mm fan bought from a local webshop, and just now as I paid closer attention found that it has great airflow unless I mount it, and it has to force the air between the blades of the heatsink. In this case it feels kind of crappy, so I'll buy some new fans on monday. Maybe a Sunon MB40202V1-G99 ?
                • dragonnundefined
                  dragonn @denke
                  @denke most 40mm fan tunnels for the E3D v6 are just crap because the have to much flow resistance. Maybe even mounting the fan without any tunnel would work better. I would suggest you to go with the stock 30mm tunnel and stock E3D v6 fan, I compared it to some 30x30 Sunon and the stock E3D is the much powerful.
                    Qdeathstar @dragonn
                    @dragonn
                    Not for the v6, correct? If they do that is exciting news...
                      40mm fans can work fine, but pay attention to the static pressure rating as well as the CFM rating. Higher static pressure is good for blowing into a restricted orifice, such as a heataink.
                      I found a sunon 30mm fan that fit the bill and is actually very quiet.
                      https://www.digikey.ca/product-detail/en/sunon-fans/MC30101V1-000U-A99/259-1550-ND/2757778
                      • Jackalundefined
                        Jackal
                        Your setup is pretty normal, so I believe your problem is just due to too much retraction that molten PLA is pulled out into the cold zone and then got squashed by new filament.
                        • denkeundefined
                          denke
                          @Phaedrux Thanks, I think I'll stick to the 40mm, it should be more quiet for the same effect. At least I hope. It should be easyer to find a 24V piece as well.
                          @Jackal A few hours ago it happened with 0 retraction printing 40mm/s 0.2mm layer height @ layer ~60 so I lean towards insufficent cooling or bad thermal connection between the radiator and heatbreak.
                          Furthermora it seems that the clogging is more probable the longer I print. If I start a new print after cleaning up a clog without cooling down, the clog almost always happens within 5 layers
                          • dragonnundefined
                            dragonn
                            Do you have thermal paste between the heatbreak and radiator?
                              deckingman @denke
                              @denke said in [Off topic] all metal pla clogging:
                              That's to be expected with a heat creep issue. The longer you hold the print temperature, the further up the heat break/heat sink it'll creep. Do you really need to be able to print at temperatures higher than 230 deg C? I only ask because as I said in my first reply, the Lite version of the heat sinks with PTFE liner all the way through the heat break will almost certainly fix the problem.
                              • denkeundefined
                                denke
                                @dragonn No, I do not. Does it make a big difference? Is there a special kind for this temp, or just some off-the-shelf cpu paste will do?
                                @deckingman yes, the ptfe would limit me to 225-235 C but for eg. PET-G needs 255 for a strong layer adhesion for me.
                                Hertz ABS needs 240-275 which is way up. I would essentially be limited to PLA according to theese numbers.
                                If the new fan possibly with the thermal paste between the break and the radiator will not work, I'll probably snap, grab a drill and transform one of those crappy steel heatbreaks from all metal to ptfe and use that for PLA until my stock is gone.
                                • dragonnundefined
                                  dragonn @denke
                                  @denke Yeah it makes, even E3D suggest it in they wiki https://wiki.e3d-online.com/E3D-v6_Assembly#Thermal_Compound as far I know every good cpu paste will do it too. Even seen a post on this forum where someone used solder paste and solder the heatbreak into the heatsink.
                                  • denkeundefined
                                    denke
                                    LOL a bit radical, but nice! 🙂
                                    Thank You all for your help, and you helped a lot!
