Configuration Z-Probe
config.g
; Configuration file for Duet WiFi (firmware version 1.20 or newer)
; generated by RepRapFirmware Configuration Tool on Sun Jan 21 2018 07:57:47 GMT+0100 (Hora estándar romance); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like Marlin
; Automatic saving after power loss is not enabled;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R157 L397.1073 B175 H518.3 ;M665 R160 L360.25 B160 H518.34 Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops
M557 R130 S20 ; Define mesh grid;Drives
M569 P3 S0 ; Drive 3 goes forwards
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolatio
M92 X80 Y80 Z80 E2613 ; Set steps per mm
M566 X600 Y600 Z600 E40 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000 Y12000 Z12000 E3000 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E120 ; Set accelerations (mm/s^2)
M906 X1800 Y1800 Z1800 E999 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S298 ; Set maximum heater temperature to 285C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 C0 R4700;M305 P1 T100000 B4725 C7.06e-8 R4700 xx Set thermistor + ADC parameters for heat
M305 P2 T100000 B4138 C0 R4700;M305 P2 T100000 B4725 C7.06e-8 R4700 xx Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H2 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 Duet3D ; Set machine name
M587 S"DIR869L2" P"A1B2C3D4" I192.168.1.50; Configure access point. M587 S"NOMBRE RED" P"PASSWORD" I"ip"
M586 P0 S1 ; Enable HTTP
M586 P1 S1 ; Enable FTP
M586 P2 S1 ; Enable Telnet
M552 S1; Fans
M106 P2 S1 I0 F500 H2 T70 ; Por tempertura
M106 P1 H-1 ; Ventilador controlado por gcode
M106 P0 H-1 ; Ventilador controlado por gcode; Escher Ir Differential sensor
M558 P1 H10 F120 T6000 ; Set Z probe type to smart, dive height, and the probe + travel speeds
G31 P500 X0 Y0 Z1.250 ; <------------------------------------------Set Z probe trigger value, offset and trigger height; Miscellaneous
M501 ; Load saved parameters from non-volatile memory -
Do you have the homed height (H parameter in M665) set too high? If so then the travel move to the first probe point may crash into the bed before the probing move starts. You can increase the dive height (H parameter in M558) temporarily to avoid this, until you have established a more accurate value for the homed height.
The M parameter in M665, there isn't the height of the printer volume?
If is this height, the M value its Ok, the printer its tall. I have obtain this value with DWC, homing the printer, and after moving down the head until reach the bed....
More on this... This value its unchanged since months... When the printer work well
I can find the gcode... but i haved a idea...
CHECK IF Z-PROBE WORKS
How?
Moving with relative position head, and check endstops....
This can be used?
Macro for check Z-Probe
1 G91
2 G1 X-50 Y-50 Z-50 F100 S1i am not sure, how the printer its a Delta if the 2 line is: G1 Z-50 F1OO S1, only moves one Stepper...
And if this is correct, Zprobe DON'T stops the movement, in DWC can be read in Z-PROBE field, as IR PROBE has detected and obstacle.... but the movement DON'T STOPS...
In a Delta, the flag S1, in the Gcode (G1), Stops the movement if endstops is triggered??? Not sure..
EDIT
I have find in: [http://reprap.org/wiki/G-code/es#G0_.26_G1:_Move]
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S variable in this way, as damage may occur if you assume incorrectly. In Duet-dc42 firmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1
There is some flag in Duet... for Sensing endstops with G1 movements???
I want to say I had to add something to my homeall.g in order for the z probe to work. Before I added it the z probe would show its working but during homing it wouldn’t actually stop z movement.
I don’t have a delta but I’m just guessing you need to add it also. When i get off work I can look at my homeall.g to see what I added.
@peirof said in Configuration Z-Probe:
How?
See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
@stealthy_tt Thanks
Think... that this can't use it....
i'd like check if Z-Probe stops the movements, with calibrate...no stops... but i wat check if, with normal movements, G1, the zprobe stops the head movement. I have cheked, that Z-Probe(Mini Ir) is reconiced by Duet, when i close some object to Mini IR, in DWC, can see how the field Zprobe raises until 46x... but.... when i calibrate the printer... and trigger Zprobe, dont stops the movement....
For this .... i want check, with G1 flag, in Zprobe is well reconiced...
Its supposed, with cartesian printer type, if gcode, G1 Z-200 S1, move the head 200 mm downwards, if Zprobe its triggered, the movement must stop. No? but with a Delta printer, this flag S1 don't work.... There is similar flag for a Delta?
You are confusing an endstop switch with a Z probe. G1 S1 commands are for use with endstop switches, not with a Z probe.
And iirc s2 is for z probe right? I’m not home to check my config for it but that’s what I believe i set for mine.
To use a Z probe for Z homing, use a G30 command, not a G1 S2 command. See the first item in https://duet3d.dozuki.com/Wiki/FAQ.
You are correct but I’m sure you already knew that haha. I have a g30 command in homeall.g
after some test... i have cheked when i send G30 S-1, and put an obstacle in ZProbe.... *** STOPS THE HEAD MOVEMENT***... this discards a fault to Zprobe, and bad conection....
IF:
- When printer power on, ZProbe blinks correct.
- When by console send G30 S-1, printer head stops with a obstacle
- When try calibrate, Zprobe DON'T stops printer head movement...
Why?
A- Something is wrong in bed.g?
B- Something is wrong in config.g?
C- Le falla "lajuntadelatrocola"What can i do?
Latest test are made with Mini IR
Copy bed.g i am using
*; bed.g
; called to perform automatic delta calibration via G32M561 ; clear any bed transform, otherwise homing may be at the wrong height
G28 ; home the printer; bed.g file for RepRapFirmware, generated by Escher3D calculator
; 16 points, 6 factors, probing radius: 140, probe offset (0, 0)
; 16 points, 6 factors, probing radius: 125, probe offset (0, 0)G30 P0 X-67,5 Y117 Z-9999 H0
G30 P1 X67,5 Y117 Z-9999 H0
G30 P2 X135 Y0 Z-9999 H0
G30 P3 X67,5 Y-117 Z-9999 H0
G30 P4 X-67,5 Y-117 Z-9999 H0
G30 P5 X-135 Y0 Z-9999 H0
G30 P6 X0 Y-90 Z-9999 H0
G30 P7 X-77,95 Y-45 Z-9999 H0
G30 P8 X-77,95 Y45 Z-9999 H0
G30 P9 X0 Y90 Z-9999 H0
G30 P10 X77,95 Y45 Z-9999 H0
G30 P11 X77,75 Y-45 Z-9999 H0
G30 P12 X0 Y45 Z-9999 H0
G30 P13 X22,5 Y0 Z-9999 H0
G30 P14 X-22,5 Y0 Z-9999 H0
G30 P15 X0 Y0 Z-9999 S6* -
IF:
Why?
*; bed.g
G30 P15 X0 Y0 Z-9999 S6*Did you also place the code for z probe in homedelta?
@peirof why is there a * on the s6 param on the last line ?
In homedelta.g... it's mecessary place code? Homing a Delta, there is with endstops, No?...
Delta dont use Zprobe for Homing. No?
@peirof No delta doesn't use the Z Probe for homing.
eee... i have try to put that text in Italic, with forum web app... but dont reconised...
the *, there isn't in bed.g...
@peirof OK it just looked strange!
Please test the Z probe with a G30 command as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
