    Configuration Z-Probe
    4.1k
    • Stealthy_TTundefined
      Stealthy_TT @dc42
      And iirc s2 is for z probe right? I’m not home to check my config for it but that’s what I believe i set for mine.
        To use a Z probe for Z homing, use a G30 command, not a G1 S2 command. See the first item in https://duet3d.dozuki.com/Wiki/FAQ.
        Stealthy_TTundefined 1 Reply Last reply Reply Quote 0
          Stealthy_TT @dc42
          You are correct but I’m sure you already knew that haha. I have a g30 command in homeall.g
          • peirofundefined
            peirof
            after some test... i have cheked when i send G30 S-1, and put an obstacle in ZProbe.... *** STOPS THE HEAD MOVEMENT***... this discards a fault to Zprobe, and bad conection....
            IF:
            • When printer power on, ZProbe blinks correct.
            • When by console send G30 S-1, printer head stops with a obstacle
            • When try calibrate, Zprobe DON'T stops printer head movement...
            Why?
            A- Something is wrong in bed.g?
            B- Something is wrong in config.g?
            C- Le falla "lajuntadelatrocola"
            What can i do?
            Latest test are made with Mini IR
            Copy bed.g i am using
            *; bed.g
            ; called to perform automatic delta calibration via G32
            M561 ; clear any bed transform, otherwise homing may be at the wrong height
            G28 ; home the printer
            ; bed.g file for RepRapFirmware, generated by Escher3D calculator
            ; 16 points, 6 factors, probing radius: 140, probe offset (0, 0)
            ; 16 points, 6 factors, probing radius: 125, probe offset (0, 0)
            G30 P0 X-67,5 Y117 Z-9999 H0
            G30 P1 X67,5 Y117 Z-9999 H0
            G30 P2 X135 Y0 Z-9999 H0
            G30 P3 X67,5 Y-117 Z-9999 H0
            G30 P4 X-67,5 Y-117 Z-9999 H0
            G30 P5 X-135 Y0 Z-9999 H0
            G30 P6 X0 Y-90 Z-9999 H0
            G30 P7 X-77,95 Y-45 Z-9999 H0
            G30 P8 X-77,95 Y45 Z-9999 H0
            G30 P9 X0 Y90 Z-9999 H0
            G30 P10 X77,95 Y45 Z-9999 H0
            G30 P11 X77,75 Y-45 Z-9999 H0
            G30 P12 X0 Y45 Z-9999 H0
            G30 P13 X22,5 Y0 Z-9999 H0
            G30 P14 X-22,5 Y0 Z-9999 H0
            G30 P15 X0 Y0 Z-9999 S6*
            Stealthy_TTundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
              Stealthy_TT @peirof
              @peirof said in Configuration Z-Probe:
              IF:
              Why?
              What can i do?
              *; bed.g
              Did you also place the code for z probe in homedelta?
              • Dougal1957undefined
                Dougal1957 @peirof
                @peirof why is there a * on the s6 param on the last line ?
                peirofundefined 1 Reply Last reply Reply Quote 0
                • peirofundefined
                  peirof
                  In homedelta.g... it's mecessary place code? Homing a Delta, there is with endstops, No?...
                  Delta dont use Zprobe for Homing. No?
                    Dougal1957 @peirof
                    @peirof No delta doesn't use the Z Probe for homing.
                    • peirofundefined
                      peirof @Dougal1957
                      @dougal1957
                      eee... i have try to put that text in Italic, with forum web app... but dont reconised...
                      the *, there isn't in bed.g...
                        Dougal1957 @peirof
                        @peirof OK it just looked strange!
                          Please test the Z probe with a G30 command as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
                            Stealthy_TT @Dougal1957
                            @dougal1957 said in Configuration Z-Probe:
                            Makes sense, like I said above I don’t have a delta. Now I know.
                              Dougal1957 @Stealthy_TT
                              @stealthy_tt yeah on a delta it always homes to max Z so the probe can't be any further away from the bed if you tried but if you've never had one then you wouldn't know that fact
                              • peirofundefined
                                peirof @dc42
                                Hi... I haved do these test, send by console G30 S1... and zprobes WORKS.. Míni Ir and Bltouch.... But calibrate dont works
                                • peirofundefined
                                  peirof
                                  What test i can do for discard problems?
                                  So far, from the tests I have done, I think two things can be ruled out:
                                  1- That the z-probes (both BlTouch / Mini IR) are damaged
                                  2- That is a problem of the wiring
                                  It seems an error in the configuration .... but I have checked it several times, and it seems that everything is fine ....
                                  One test I can do is change the firmware, although I do not think that's the case, since the Z-Probes, were working with this.
                                    So bed probing works when you do a single G30 without parameters - correct?
                                    If yes, but the hot end crashes into the bed when you run G32 to auto-calibrate a delta, then the crash is probably occurring not when actually probing, but when the firmware positions the probe at the desired XY coordinates with Z=dive height. The solution is:
                                    1. Check that your tower steps/mm is correct. 200mm of commanded Z movement should produce 200mm of movement.
                                    2. Check that the homed height (H parameter in the M665 command) is equal to the height of the nozzle above the bed when all 3 endstop switches are triggered, to within 10mm or better. Make sure the value in config.g is not being overridden by another M665 command in config-override.g.
                                    3. Until you have determined the correct M665 parameters, increase the dive height (H parameter in M558) to a large value, for example 50mm.
                                    • peirofundefined
                                      peirof @dc42
                                      @dc42 said in Configuration Z-Probe:
                                      until 1 hour ago, i have no test.... but seems to be this
                                      "...Until you have determined the correct M665 parameters, increase the dive height (H parameter in M558) to a large value, for example 50mm...."
                                      thanks Steve....
                                      P.D.: If you come to Valencia (Spain), you are invited to a" Paella Valenciana".☺
                                        dc42 administrators @peirof
                                        The black rice one? My favourite sort!
                                        • peirofundefined
                                          peirof @dc42
                                          That's similar to the original E3D v6 extruder, there are Chinese copies that are not bad ... Well, in the "Paella Valenciana" something similar happens, the original "paella of chicken and rabbit rice" .... the black rice. .. is very good with "ajoaceite" (A kind of mayonnaise with garlic), but ... it is not the original
