I can't get the Bltouch working
IR Height Sensor
10.4k
    dc42 administrators @Saltypetz
    @saltypetz said in I can't get the Bltouch working:
    I had a copy of the factory sc card and loaded that so everything is factory setting. The Z-Probe is reading 245 right now.
    A steady reading other than 0 or 1000 should be impossible with P9 selected in the M558 command. Please run M558 without parameters and check what probe type number it reports.
      Saltypetz
      Here is what did. Set sd card back to factory the I edit this. Setup with https://configurator.reprapfirmware.org/
      M574 Z1 S2 ; Set endstops controlled by probe
      M558 P1 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 X0 Y0 Z0 P25 ; Set Z probe trigger value, offset and trigger height
      M557 X15:355 Y15:235 S20 ; Define mesh grid
      M307 H3 A-1 C-1 D-1 ;
      On this line M558 P1 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to unmodulated and the dive height + speeds
      My Z-Prode is at 243 with this numbers and with the https://configurator.reprapfirmware.org/
      also 243. I when number by number changing them one at a time as soon as I put P9 the Z prober goes to 1000.
      M558 P9 X0 Y0 Z1 H5 F100 T2000
      G31 X0 Y0 Z0 P25
      I tried this and it goes to 1000 right away.
      My Config,g file.
      ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
      ; generated by RepRapFirmware Configuration Tool on Fri May 18 2018 16:29:29 GMT-0400 (Eastern Daylight Time)
      M550 PTevo Black Widow ; Set machine name
      M552 S1 ; Enable network
      ;*** Access point is configured manually via M587
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z4000 E420:420 ; Set steps per mm
      M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250:250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X370 Y250 Z300 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M305 P1 X150 T"K" ; Set thermistor + ADC parameters for heater 0
      M143 H1 S370 ; Set temperature limit for heater 1 to 370C
      M305 P2 X151 T"K" ; Set thermistor + ADC parameters for heater 1
      M143 H2 S370 ; Set temperature limit for heater 2 to 370C
      M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X0 Y63 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
        I believe it is normal for the bltouch to read 1000 when it is not deployed. It should go to zero when you deploy it, if you have connected it correctly.
        undefined 1 Reply Last reply 19 May 2018, 14:15 Reply Quote 0
          Saltypetz
          So I should put this in place of the
          G31 X0 Y0 Z0 P25
          inplace of the configurator.reprapfirmware info.
            Scachi @dc42
            @dc42 said in I can't get the Bltouch working:
            Mine works fine and reads "0" all the time (BLTouch smart) no matter if it is deployed or rectracted, it only reads 1000 when I disconnect the BLTouch sensor wire from the duet wifi.
            Maybe the bltouch models work differently, if it is a genuine-smart,genuine-classic or 3rd party "bltouch" ?
              Saltypetz
              To test the setup with the nozzle maybe a 100mm up from the bed you can check if the trigger signal is reaching the Duet by attempting to extend the pin by using the following command:
              This works perfect M280 P3 S10 I1
              Then put the Sensor in to test mode by inputting the following command:
              This the pin just goes in and out M280 P3 S120 I1
              With this setting.
              G31 X0 Y0 Z0 P25
              X & Y home no problem.
                elmoret
                I'm not super familiar with the BL Touch, but the pin going in and out 3 times seems to be expected behavior for self test?
                If you do M280 P3 S60 I1, this should perform a wiring test, letting you push the pin and then check the Z-probe reading in Duet Web Control. You should see the reading change when the pin is pushed. What readings do you see after M280 P3 S60 I1, with the pin in and then the pin out?
                https://docs.wixstatic.com/ugd/f5a1c8_d261d68b7b034a29bdfc5aaebe882983.pdf
                  Saltypetz
                  I don't know if this will help but here is the BLTouch would love to get this thing going need it bad.0_1527022615510_20180520_115638.jpg
                    elmoret
                    Getting answers to the questions I posed in the post before yours would help us help you.
                      Saltypetz
                      When you turn the printer it self test the pin go in out out two times.X and Y home Z goes to middle of bed and stops.
                      (0 %
                      × G28 Z
                      Error: Z probe already triggered at start of probing move
                      Error: G0/G1: insufficient axes homed)
                      Only on Z
                      Copy and paste all setting from https://forum.duet3d.com/topic/4487/tevo-black-widow-compatibility/2
                      Then only edit this.
                      1. In your software config.g file input the following G-Code commands to allow the setup to work:
                      G31 X0 Y0 Z0 P25
                      Important: mode 9 is supported in firmware 1.21 and later only. If you are using earlier firmware, replace P9 in the M558 command by P5.
                      In the G31 command the X and Y are the offset of the sensor in relation to the nozzle (so input your own) the number for Z is the trigger height (read on for this). This is the height that is obtained from reading the height the nozzle is from the bed when the sensor pin contacts the bed and retracts, P is the signal threshold.
                      It is required to invert the signal “I1” when using the expansion header pins and not the Duex to connect the BLTouch.
                      Ensure in your config-override.g file (in the /sys folder of the SD card) does not contain an M307 H3 command that overrides the above configuration.
                      2. Create a deployprobe.g file (in the /sys folder of the SD card) it should contain the following single command:
                      M280 P3 S10 I1
                      1. Create a retractprobe.g file (in the /sys folder of the SD card) it should contain the following single command:
                      M280 P3 S90 I1
                      Commissioning & Testing
                      (THIS WORK PERTFECT) M280 P3 S10 I1
                      **( THIS THE PIN JUST GO IN AND OUT WITHOUT STOPPING)**M280 P3 S120 I1
                      If all is well the web interface should report a value of ” 0” in the Z probe column when the pin is extended. You can then lightly touch the extended probe pin to check that the pin retracts, the value in the Z probe Column should change to “1000”
                      If all is good It is at this point that you can deploy the probe using the M280 P3 S10 I1 command and slowly lower the nozzle to the bed and find out your own Z trigger height, when the probe touches the bed and the pin retracts you can take a reading of the Z height and use that to input into the G31 command in the config.g file
                        Saltypetz
                        ; executed by the firmware on ; Config start-up
                        ; generated by RepRapFirmware Configuration Tool on Sat Mar 03 2018 14:29:05 GMT-0500 (Eastern Standard Time)
                        M550 P"Black Widow" ; Set machine name
                        M587 S"NETWORKNAMEHERE" P"NETWORKPASSWORDHERE" ; Configure access point. You can delete this line once connected
                        M569 P0 S1 ; Drive 0 goes forwards X
                        M569 P1 S0 ; Drive 1 goes backwards Y
                        M569 P2 S0 ; Drive 2 goes backwards Z
                        M569 P3 S1 ; Drive 3 goes forwards E
                        M92 X80 Y80 Z1600 E427 ; Set steps per mm for 16x microstepping
                        M566 X900 Y900 Z12 E10 ; Set maximum instantaneous speed changes (mm/min)
                        M203 X6000 Y6000 Z500 E1200 ; Set maximum speeds (mm/min)
                        M201 X500 Y150 Z300 E200 ; Set accelerations (mm/s^2)
                        M906 X1050 Y1050 Z1300 E1050 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M208 X335 Y260 Z250 S0 ; Set axis maxima
                        M574 X1 Y1 S0 ; Set active low endstops
                        M557 X0:335 Y45:260 S20 ; Define mesh grid
                        M301 H0 S1.00 P32.6 I1.360 D79.4 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                        M143 H0 S80 ; Set temperature limit for heater 0 to 80C
                        M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                        M143 H1 S240 ; Set temperature limit for heater 1 to 220C
                        M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H1 T100 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M563 P0 D0 H1 F2 ; Define tool 0
                        G31 X0 Y0 Z0 P25
                        M501
                        T0 ; Select first tool
                          Nylkos
                          Not sure where you are in the process of fixing your BLTouch...
                          I have been away for a while but I had, when I started a similar situation with a BLTouch.
                          Red background in web controller
                          I used these in my Config.g
                          G31 X30 Y18 Z1 P200 ; Set Z probe trigger value, offset and trigger height
                          I also needed to use Replace M401 by M98 Pdeployprobe.g and M402 by M98 Pretractprobe.g
                            Saltypetz
                            Yes but i have the new board. Everything works X and Y home Z goes to center then Z - Probe doesn't know what to do. I used all your setting and tried editing the Z - probe. That is the only problem. I love the board but it is very hard to get help.
                            Thank you,
                              elmoret
                              I posted a question a few posts back, getting the answer to that will help us help you.
                              69 out of 73
