    Heater fault, spurious spikes [SOLVED]
    1.7k
      @paboman said in Heater fault, spurious spikes:
      sensor short to other wiring
      That suggests it is not a noise issue. Check that there is no way for the PT100 cartridge wires to short to the heater block.
      pabomanundefined 3 Replies Last reply Reply Quote 0
      • pabomanundefined
        paboman @dc42
        that is quite impossible, maybe is the pt100 damaged somehow (but i dont think so), wires are well insulated.
        Can this spikes be caused by an intermittent connection in the connectors?
        one is the DuPont on the daughterboard, then I have a second one along one of the towers, which is a 4 pole mini xlr (http://www.switchcraft.com/Category.aspx?Parent=806)
        Moving them does not produce any spikes at all
        • pabomanundefined
          paboman @dc42
          @dc42 just checked again, none of the sensor wires touches the heater block
            deckingman
            As a work around, you could "de-sensitise" the fault anomaly detection by increasing the P and/or T parameters in M570 https://duet3d.dozuki.com/Wiki/GCode#Section_M570_Configure_heater_fault_detection
            pabomanundefined 1 Reply Last reply Reply Quote 0
            • pabomanundefined
              paboman @deckingman
              @deckingman
              thank you!
              now I have changed the 4 wires cable of the pt100 with a shielded one as this is the only thing I can do.
              My plan is to run the printer and later check if random spikes are still there but i cant look at the graph forever so i would like to record the temperature graph somehow.
              I know repetier host has a nice interface for the temps but how to connect the duet wifi to repetier ? what is the ip port ?
              • sonderzugundefined
                sonderzug
                Hi all,
                I've had a somewhat related issue with both PT100 and Type K sensors, leaving me unable to print at the temperatures neccessary for the materials I use. I've documented this in another thread, unfortunately without a working fix at this moment (https://forum.duet3d.com/topic/4966/highly-erratic-temperature-readings-above-certain-temperature). It seems that the insulation inside the sensor cartridges is not stable at higher temperatures (>300°C). While this doesn't really apply to you (you're printing at pretty standard temperatures as it seems), a failing cartridge insulation and short to the heater block might still be the case?
                Best regards, Niklas
                • pabomanundefined
                  paboman @dc42
                  @dc42 I have changed the pt100 cable with a shielded one but I am still missing something...
                  I am sure the PT100 cable is picking up estruder noise as the temperature graph became noisy as soon as E motors is energized
                  Routing the cable externally to the printer also makes the graph look clean but I cant route the cables in a different way.
                  Cant understand this behavior as all my cables are shielded, steppers cables are twisted and shielded....what am I doing wrong ?
                  Look only at the noise, the temperature was raising and falling because of me turning on/off the heater to see if it has any correlation but it hasn't
                  Shield of the extruder stepper is connected to the extruder motor case and to nothing on the other end
                  The shielding of the PT100 is connected to nothing on both ends
                    dc42 administrators @paboman
                    @paboman, try connecting the shield of the PT100 cable to ground. There is a ground pin on the daughter board OUTPUT connector, it's the corner pin of that connector closest to the INPUT legend.
                    pabomanundefined 2 Replies Last reply Reply Quote 0
                    • pabomanundefined
                      paboman @dc42
                      Can I use the negative terminal of the main input ?
                      I mean the GND on the big green connector
                      thx!
                      • pabomanundefined
                        paboman @dc42
                        Now its better but still jumping up and down in the 2°C range
                        I will run the printer to see if it spikes again
                        Is there any way to filter / flatten the readings even more or this is the best I can achieve ?
                        thanks again David!
                        • pabomanundefined
                          paboman
                          UPDATE:
                          SOLVED
                          I made better connection at the shield line and now my temps are within 1°C
