    Might have finally killed a DuetWifi
    4.6k
    • DjDemonDundefined
      DjDemonD
      Thanks Tony I'm thinking hotend heater cartridge short but I'll investigate. Might see if someone can repair the board if there aren't any other issues.
      www.precisionpiezo.co.uk
        Shorts between the hot end heater cartridge and it's casing appear to be fairly common. That's why we protect both sides of the thermistor inputs, because shorts between thermistors and the hot end metalwork are also common - maybe less so since E3D switched to cartridge thermistors.
        To damage a Duet like that, you need a short between something powered from VIN and either +5V or +3.3V. One such mechanism is a short between the +3.3V supply to the Z probe and the hot end metalwork, coupled with a short inside the heater cartridge. That's why the fitting instructions for the IR sensor insist that 2 or more layers of Kapton tape are put on the back of the board, to insulate it from the heater block if the hot end rotates (as E3D hot ends do).
        HTH David
        • DjDemonDundefined
          DjDemonD
          Thanks, I've been scratching my head, as having started to test components individually, the hot end heater cartridge is not shorted to the block, or to negative of the PSU, or to the PT100.
          The PSU is outputting 24.1v.
          I will continue to investigate, there is a possibility something entirely different is going on, a full strip down and rebuild is almost certainly required.
          The thing is I'm not sure if I can be bothered, I've concluded reluctantly that this machine (cutting-edge Kossel XL from 2016) is no more accurate a 3D printer than a CR10 300 which costs around 1/3 of the cost, is basically ready-assembled and just works. Since I might be planning to do some travelling I might just dismantle the XL and sell it off in pieces, and continue to use my CR10 for day-to-day printing. Will give forum members first refusal on the parts.
            If there is a short between the hot end heater cartridge and its casing, the short may only be present when the cartridge is hot.
            There are of course other ways to get a short between +3.3V or +5V and VIN, such as mounting the Duet too close to a conductive plate behind it.
            In principle, a faulty 5V regulator chip could cause a short between VIN and +5V. However, on the returned boards showing this type of symptom that we tested, I found that the 5V regulator was working correctly in all cases.
            • DjDemonDundefined
              DjDemonD
              So I finally found the time to do a full diagnostic of the machine and found the issue. A short between the hotend fan + and E0 heater cartridge, which occurred in the network cable (stranded not solid core) that I have been using to connect my smart effector to the duet.
              This explains why even on USB power only (PSU off) with the original board (v1.00) the heater cartridge was warm in the morning, it had been heating up under 5V power from the fan + to the heater cartridge all night. Probably damaging the 5v reg in the process but since its a buck converter IC, not a simple reg I'm not sure how to test it.
              The second board (v1.02 clone) instead blew the U11 74HCT02 chip immediately when Vin power was connected.
              So its possible the second board might be repairable if anyone can swap the 74HCT02 chip for me cheaply?
              Still doesn't quite explain how the paneldue died or the 4gb sd card from the original board. Edit - the second board also killed an 8gb sd card.
              But at least I now feel confident to put a third board in the machine once I have replaced all the wiring from Duet to Smart Effector.
              It might be just the quality of network cable I chose or how I have implemented/routed it, but I would consider going for something better quality than network cable for this purpose, they are designed to be static, not moving around on the end of a delta effector at high acceleration for hundreds of hours. Cheap cable has cost me 2 duetwifi and one (maybe two) paneldue! I will look into multicore highly flexible quality cable.
              T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                T3P3Tony administrators @DjDemonD
                @djdemond thanks for the detailed investigation and cautionary note about the cables.
                The PanelDue has 5V from the Duet so that would have received 24V as David said above, how much damage that has done to the rest of the PanelDue/screen is unknown. As the SD card has failed I guess that the 3.3V regulator also failed, putting 24V onto the 3.3V supply which would have blown all the 3.3V ICs if applied for long enough. You may find the processor, stepper drivers and other assorted ICs are also damaged. I guess the 3.3V LED comes on becasue it was protected from overcurrent by the current limiting resistor.
                On the second board you will need to do more investigation to see if it is just that IC that is blown. with 5V only applied to the second board does the 3.3V LED light up and can you connect to the Duet?
                • DjDemonDundefined
                  DjDemonD
                  I am going to try as an alternative to network cable 13 core towing-electrics cable. It has the following wire sizes within it
                  7 x 0.65mm2 1 x 1.5mm2 and 4 x 2.5mm2
                  Which should provide 7x 2 amps, 1x 10amps and 4x 20 amps of current handling, with I am sure much tougher insulation. £5/meter.
                  The only drawback is I suspect it will be rather heavy compared to 2x cat 5 network cables.
                  • Dougal1957undefined
                    Dougal1957 @DjDemonD
                    @djdemond said in Might have finally killed a DuetWifi:
                    Simon
                    Why not look to using silicon covered wire and make your own bundle and then just encase it all in braid 13 core trailer wire is heavy Thick and very Stiff.
                    Got all mine from Hobbyking
                    Silicon Wire
                    I would suggest 20awg for hot end power (at 24 Volts or 18 at 12) and 26 for all signal cables
                    Braid
                    HTH Doug
                    • DjDemonDundefined
                      DjDemonD
                      Hi Doug,
                      That sounds like a good solution. I will have a look at both options. My effector has a fair amount of inertia these days as I run water cooling so I am running much lower XY acceleration (1500) than I used to eliminate artefacts. But the silicone cabling look nice.
                      At this point I am inclined to over-engineer it, this incident has been quite an expensive one, for the sake of a bit of wire.
                      I also wonder whether to remove the possibility of this happening again whether it might be worthwhile to have a fuse box between the hot end and controller, where every connection is suitably fused. Sounds like overkill but an automotive fusebox and fuses are a lot cheaper than blown controllers and displays.
                        Dougal1957
                        Yep know what you mean and I am soon to fir a water cooled hotend to mine and will re-wire my effector at the same time have been meaning to do it for some time, (doing so I will be able to eliminate 4 cores of the wiring as well as won't need any Fan wires at all).
                          deckingman
                          I once looked into using these https://www.igus.co.uk/chainflex/unharnessed-cable?tab=1
                          Bit expensive though...............
                            Dougal1957 @deckingman
                            @deckingman said in Might have finally killed a DuetWifi:
                            I looked at them as well until I checked the prices lol
                              dc42 administrators @DjDemonD
                              You were using a 5V hot end fan - confirm?
                              On the Smart Effector we put the fan/heaters wires on one connector and the low voltage wires on another to try to minimise the risk of this type of short - but of course that doesn't allow for using a 5V fan. Perhaps we shouldn't support 5V fans?
                              The reason the SD card died is that if the 5V rail is raised to 12V or 24V, that is above the voltage rating of both the 3.3V regulator and the 74HCT02. This results in the voltage on the 3.3v rail also becoming much too high - which blows most of the chips on the board, the WiFi module, and the SD card. There was one user who posted on this forum about replacing all the blown chips in this situation, but he had to replace almost all the chips on the board, including the stepper drivers AFAIR.
                              • raykholoundefined
                                raykholo
                                @dc42 said in Might have finally killed a DuetWifi:
                                I might enjoy that rework job, if you want to donate such a dead board for "science" 🙂
                                @DjDemonD
                                • DjDemonDundefined
                                  DjDemonD
                                  @dc42 - yes 5V fan running from the 5v/Vin fan jumper block. - When I rebuild the machine I think I'll go for a Vin/24v fan through a buck converter down to 5v, this seems to be safer in the event of a short. Thank you for the explanation, it does all make sense now. What is your opinion of making a fuse block and fusing everything (fans/sensors/heaters rather than motors etc..) it's not expensive and could save a lot of head scratching and expensive dead PCBs? If you think it isn't a stupid idea what sort of current level would make sense for things like thermistors Pt100's etc...
                                  @raykholo - you are quite welcome to one/both of the boards if you would like to experiment, I am not going to attempt to repair them. PM me.
                                    Fuses wouldn't protect against this kind of short unless you also had crowbar protection on the 5V rail.
                                    Why not use 12V or 24V fans?
                                    • DjDemonDundefined
                                      DjDemonD
                                      I'm happy to use 12v/24v fans, I'm also happy even to PWM my 5v fans down from 12v to avoid using the 5v rail on the duet (or use buck converters running off the PSU) etc.. it's not such a risky move as it is with heaters at the wrong voltage. I had 5v fans and it was convenient to attach them to the 5v rail (these are the 30mm blowers we sell, which offer a lot of bang for very little mass) however it does seem to be somewhat of a risk. Having said that if the wiring had been either better quality, or possibly better protected by me against fatigue - it's hard to conclude that having a 5V fan option is too risky, but I think it might be worth stating that there is a risk when using 5v fans that a short to the heater cartridge can kill your board and all its attached peripherals.
                                      Is it possible in some future product perhaps with bus architecture that the fan controller module is a separate unit, powered direct from the PSU with no possibility of a failure damaging anything except the fan module itself? Fans do seem to be a common cause of problems.
                                        @djdemond regarding having the fan controller as a separate unit. hats definitely achievable however it adds significantly to the overall cost. ove all a completely modular board with everything on different CBs would be the easiest to swap stuff out but he most expensive.
                                        • DjDemonDundefined
                                          DjDemonD
                                          Okay so finally got around to starting to get this fixed.
                                          I bought some towing electrics 13 core wire, very thick and heavy as Doug pointed out, but quite flexible and quite cheap too £5/meter.
                                          However I also bought some 7 core signal wire hoping it would be a little less massive, it was but less flexible £4/meter.
                                          So I stripped the insulation off both, quite a lot of the mass resides in the insulation, especially on the 13 core cable, and set about working out what I would need in order to cover all bases, current and, as best as I can determine, projected requirements.
                                          In the end I have made a 17 core wiring loom.
                                          Wiring Table
                                          I have used the larger 2.5mm sq wire for the hotend heater, 7 amps is more than I will need at 24v (2A suffices) but then if in future heater cartridges get much more powerful, or for some unfathomable reason I go back to 12v, or I possibly consider the positive wire common, and run two negatives for dual hotends then I'm covered).
                                          I have used larger than necessary (0.65, 0.75 mm sq wire) for some of the connections as, firstly I have it in hand, but mainly as it is well insulated, strong and flexible.
                                          I am not currently using a filament monitor, but I have done in the past, and still have one so I have that covered. The hotend fan is not currently used, as this machine has water cooling, but I might go back to an air-cooled system later, so I have that covered too. Also I have a second thermistor which is attached to the water block, so I can directly see how effective the watercooling is. But it is a lot of cable. Here's what it looks like:
                                          Bundled Wiring Loom
                                          I might not need all 2 meters, but it weighs around 400g, which is not as much as I expected, and it will have keychain retractors to hold much of the weight off the effector, but it is going to contribute to lateral inertia on XY moves.
                                          Now to get it installed. All I will say is that I can see why Canbus is quite popular these days, the idea of replacing all of this with 2 decent sized power wires, and two data cables potentially, is very appealing.
                                          • DjDemonDundefined
                                            DjDemonD
                                            So all back up and running. 🙂
                                            Just to mention that despite the widespread damage the PT100 daughterboard survived. 🙂
