Disable stepper motors in Duet ethernet board
5.1k
    allankisaiswaroop
    Hi to all,
    How to disable stepper motors in duet ethernet board and i am using 1.21 firmware? please help in this.
    undefined 1 Reply Last reply 8 Jun 2018, 13:44 Reply Quote 0
      wilriker @allankisaiswaroop
      @allankisaiswaroop Either use M84 or M18 to disable all motors together or use M18 <motor>... to disable specific motors, e.g. M18 X Z to disable only X and Z motor(s).
      Manuel
      My Tool Collection
      undefined 1 Reply Last reply 9 Jun 2018, 08:17 Reply Quote 0
        deckingman
        M18 disables stepper motors - either all or individually. M84 turns off idle hold and this can also be applied to specific motors e.g. M84 E0:1:2
        undefined 1 Reply Last reply 8 Jun 2018, 19:12 Reply Quote 1
          wilriker @deckingman
          @deckingman said in Disable stepper motors in Duet ethernet board:
          [...] this can also be applied to specific motors e.g. M84 E0:1:2
          Interestingly the Gcode reference page does not list this possibility but you are right, I just tested (with latest 2.0 firmware as I know you are currently stuck with an older version) and can confirm that this works as well.
          Manuel
          My Tool Collection
          undefined 1 Reply Last reply 8 Jun 2018, 19:48 Reply Quote 0
            T3P3Tony administrators @wilriker
            @wilriker said in Disable stepper motors in Duet ethernet board:
            Which reference page? I will update it.
            undefined undefined 2 Replies Last reply 8 Jun 2018, 19:57 Reply Quote 0
              deckingman @T3P3Tony
              @t3p3tony said in Disable stepper motors in Duet ethernet board:
              Hi Tony,
              It's the M84 command in the Wiki https://duet3d.dozuki.com/Wiki/GCode#Section_M84_Stop_idle_hold
              It makes no mention of the fact that you can stop idle hold for individual motors e.g. M84 E0:1:2:3:4.
              I don't know at which software version that came into being but I've been using it for ages.
              Cheers
              Edit. I use the above command in a macro to turn off the E motors - I think that macro has been in DWC for a very long time but got removed a couple of versions ago. It's useful to be able to turn off the E motors for manually changing filament, whilst leaving the other motors powered, so that homing is not affected.
              undefined 1 Reply Last reply 8 Jun 2018, 21:19 Reply Quote 0
                wilriker @T3P3Tony
                If you wouldn't have done that I would have on the weekend or Monday latest (I am regularly extending the Gcode wiki 😉 ).
                Manuel
                My Tool Collection
                undefined 1 Reply Last reply 8 Jun 2018, 21:20 Reply Quote 0
                  T3P3Tony administrators @deckingman
                  @wilriker @deckingman said in Disable stepper motors in Duet ethernet board:
                  M84 E0:1:2:3:4.
                  Done, thanks for pointing it out.
                    Cheers - how are you finding working with Dozuki?
                    undefined 1 Reply Last reply 9 Jun 2018, 05:05 Reply Quote 0
                      wilriker @T3P3Tony
                      @t3p3tony It's ok.
                      I miss some features namely
                      • preview of changes without saving yet
                      • either a larger editor area (I know I can simply resize the text area in the browser instead) or even better would be section based editing as on Wikipedia. Especially on very long pages as the GCODE reference I usually use the browser text search to find the place to edit. 😁
                      • Also - but that may be me as a software developer - I would like to have a comment field to give a few words about what or why I changed
                      But whenever I post a question here that might/should have been answered by the GCODE reference page in the first place I usually amend the wiki page so hopefully people having a similar question in the future find it already there.
                      Manuel
                      My Tool Collection
                      undefined 1 Reply Last reply 9 Jun 2018, 18:01 Reply Quote 1
                        dc42 administrators @wilriker
                        If the purpose of disabling stepper motors is because they will be disconnected or switched e.g. using a relay, then put a short delay (G4) after the M18 or M84 command, to allow the current in the motor coils to decay.
                          @wilriker Yeah I share those frustrations. I think Dozuki is really focused around guides rather than wiki pages... but it takes a long time to write a guide and its not appropriate for everything. Reference material is still better as a wiki.
                          3 out of 12
