    Disable stepper motors in Duet ethernet board
    5.1k
      deckingman
      M18 disables stepper motors - either all or individually. M84 turns off idle hold and this can also be applied to specific motors e.g. M84 E0:1:2
      wilrikerundefined 1 Reply Last reply Reply Quote 1
      • wilrikerundefined
        wilriker @deckingman
        @deckingman said in Disable stepper motors in Duet ethernet board:
        [...] this can also be applied to specific motors e.g. M84 E0:1:2
        Interestingly the Gcode reference page does not list this possibility but you are right, I just tested (with latest 2.0 firmware as I know you are currently stuck with an older version) and can confirm that this works as well.
        Manuel
        My Tool Collection
          T3P3Tony administrators @wilriker
          @wilriker said in Disable stepper motors in Duet ethernet board:
          Which reference page? I will update it.
          deckingmanundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
            deckingman @T3P3Tony
            @t3p3tony said in Disable stepper motors in Duet ethernet board:
            Hi Tony,
            It's the M84 command in the Wiki https://duet3d.dozuki.com/Wiki/GCode#Section_M84_Stop_idle_hold
            It makes no mention of the fact that you can stop idle hold for individual motors e.g. M84 E0:1:2:3:4.
            I don't know at which software version that came into being but I've been using it for ages.
            Cheers
            Edit. I use the above command in a macro to turn off the E motors - I think that macro has been in DWC for a very long time but got removed a couple of versions ago. It's useful to be able to turn off the E motors for manually changing filament, whilst leaving the other motors powered, so that homing is not affected.
            • wilrikerundefined
              wilriker @T3P3Tony
              If you wouldn't have done that I would have on the weekend or Monday latest (I am regularly extending the Gcode wiki 😉 ).
              Manuel
              My Tool Collection
                T3P3Tony administrators @deckingman
                @wilriker @deckingman said in Disable stepper motors in Duet ethernet board:
                M84 E0:1:2:3:4.
                Done, thanks for pointing it out.
                  Cheers - how are you finding working with Dozuki?
                  • wilrikerundefined
                    wilriker @T3P3Tony
                    @t3p3tony It's ok.
                    I miss some features namely
                    • preview of changes without saving yet
                    • either a larger editor area (I know I can simply resize the text area in the browser instead) or even better would be section based editing as on Wikipedia. Especially on very long pages as the GCODE reference I usually use the browser text search to find the place to edit. 😁
                    • Also - but that may be me as a software developer - I would like to have a comment field to give a few words about what or why I changed
                    But whenever I post a question here that might/should have been answered by the GCODE reference page in the first place I usually amend the wiki page so hopefully people having a similar question in the future find it already there.
                    Manuel
                    My Tool Collection
                      dc42 administrators @wilriker
                      @allankisaiswaroop Either use M84 or M18 to disable all motors together or use M18 <motor>... to disable specific motors, e.g. M18 X Z to disable only X and Z motor(s).
                      If the purpose of disabling stepper motors is because they will be disconnected or switched e.g. using a relay, then put a short delay (G4) after the M18 or M84 command, to allow the current in the motor coils to decay.
                        @wilriker Yeah I share those frustrations. I think Dozuki is really focused around guides rather than wiki pages... but it takes a long time to write a guide and its not appropriate for everything. Reference material is still better as a wiki.
