    Ran two good prints now Z axis grinds while trying to go down.
    1.9k
    • JoergS5undefined
      JoergS5
      If you disconnect the stepper, can you move the axis easily (axis may be decalibrated)? And if you disconnect the stepper, you can test whether the stepper is working without the axis (test only a few turns).
      • dvella212undefined
        dvella212
        the stepper is moving like butter both of them when i move them myself.
        • JoergS5undefined
          JoergS5
          and the axis, does it run freely?
            dvella212
            yea when i move it myself it runs ok.. like up and down but when its plugged in it shakes when it starts.
            • JoergS5undefined
              JoergS5
              I bit more effort: change stepper controller assignment between z and X or Y *). But in most cases it will be mechanical, I think. All pulleys are fixed? (especially the silver one between stepper and trapezoid)
              *) edit to check whether the stepper controller on the board is ok
              • JoergS5undefined
                JoergS5
                The trapezoid at the top could hang, also.
                • JoergS5undefined
                  JoergS5
                  Are the steppers stuttering if they are disconnected from the mechanics?
                    dvella212
                    So its got to be the board . I ran two seperate motors from the same ports on z axis and they did the same thing. Stutter. I changed the wires and still stutter..
                    • JoergS5undefined
                      JoergS5
                      I have only two ideas left: motor controller too high current setting (or too low), and cabling somehow wrong. Sorry, then I cannot help further.
                      • JoergS5undefined
                        JoergS5
                        A last idea:
                        https://www.reddit.com/r/CR10/comments/6v8jxl/my_creality_cr10_wont_move_up_on_the_zaxis_the/
                          dvella212
                          I tested the with a multi meter for 1a 2a coils and 2a 2b coils are all good. I ran a print that was successful already so thats out of the question.. hmmmm.. the current is at 800MA
                          • JoergS5undefined
                            JoergS5
                            In Video
                            https://www.youtube.com/watch?v=wQBItwXSK3g
                            in comments sections, the solution was to replace the board.
                              dvella212
                              Yea its with the board. all axis work fine but anything plugged into the z axis is just not getting the right current which is making both motors stutter. Im going to run down to my shop and show them the problem .
                                dvella212
                                I had already to replace my paneduet 7i as well 😞
                                • JoergS5undefined
                                  JoergS5
                                  Good luck with fixing this!
                                    What is the specification of the Z stepper motors on the CR10? If they are low current high inductance motors, they may need to be connected in parallel instead of in series (the Za and Zb motor connectors are wired in series).
