    It's out! RepRapFirmware 2.0 and 1.21.1 released
    Firmware installation
    25
    81
    15.6k
      dc42 administrators @Adamfilip
      @adamfilip said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
      confused which files i need to use to upgrade to V2.0 for my duetwifi
      Which firmware version are you using at present?
      • Adamfilipundefined
        Adamfilip
        I tried the current Duet2CombinedFirmware.bin file and installed it. but this is what it says currently
        Firmware Electronics: Duet WiFi 1.0 or 1.01
        Firmware Version: 1.21RC3 (2018-02-28 build 4)
        WiFi Server Version: 1.21
        Web Interface Version: 1.21.1
          Phaedrux Moderator @Adamfilip
          @adamfilip Perhaps this will help? https://forum.duet3d.com/topic/5646/duet-wifi-not-updating-firmware-when-installing-2-0/2
          Adamfilipundefined 1 Reply Last reply Reply Quote 0
          • FrankNPrinterundefined
            FrankNPrinter
            Hi Dave been a while.. I see things have really progressed since i pestered you last. LOL I am getting ready to upgrade so i can get wifi working again. Great to see the evolution and addition of ssid and pw btw! I see i have some firmware updates to do as well but it is all a little confusing. i was wondering if someone can give me a cliff notes version of what to do 1st.
            Duet wifi running ver 1.18.1 with panel due v 1.15c PC and printer are in opposite ends of house so ideally do this via sd card? What do i do 1st? Also confused about which are the latest versions and where to get them. I am hoping to get my ducks in a row for this weekend . BTW, loved the tidbit from E3D on how great the duet is. I have another printer now, running mks 1.4 board and wow, it is a real dinosaur by comparison. I had no idea how lucky i was with my 1st system. I am currently building a system with 1540 mm X, and 1500 mm Y \ Z so looking forward to the Duet2 as well 🙂
              Phaedrux Moderator @FrankNPrinter
              @franknprinter Take a good look through this document.
              https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
              You'll need to follow the special steps for updating to 1.19 as things changed slightly at that point.
                Adamfilip @Phaedrux
                @phaedrux
                Thank you, yes this was my issue.
                • GizmotronX5000undefined
                  GizmotronX5000
                  I have downloaded the Duet2CombinedFirmware.bin, iap4e.bin, and DuetWebControl.zip files. I uploaded all of these to my DuetEthernet and it looked like it installed correctly, but it reports back saying that the firmware version is still 1.21. I'm running DWC 1.21.1, but I tried it with DWC 1.21 as well. Any idea what I'm doing wrong? The firmware updated date is listed as (2018-03-21), which is probably when I updated things last. Unfortunately the link above didn't solve my problem like I had hoped.
                  Edit: It works now. Tried it again after the 4th or 5th time and it just worked. I honestly cannot think of anything that changed.
                    FrankNPrinter
                    thanks much @Phaedrux , i will give that a try this weekend!
                      Adamfilip
                      So far so good, havent run into any issues with 2.0 so far 🙂
                        FrankNPrinter
                        THanks @Phaedrux ! I couldn't wait so finished upgrade about 130 this AM LOL that worked like a charm even if it read like mudd. someone might want to update the install for 1.21 vs 1.19 as that was the instruction i used. Still have panel due to go but everything else is 1.21 now. dont suppose there is a way to flash duo from duet wifi? Else wise i will have to pull apart my case un mount and disconnect it so i can carry it to the computer room and plug in usb. Shocked and amazed i have not heard from @dc42 yet. I seem to recall Dave sending me answers before i could finish the question back in the day. LOL Bet you are even more insanely busy but keep up the outstanding work! I can see so many improvements and advances since i went down this road before, it really is awesome the way you take everyone's crazy ideas and turn it into a new release.. epic stuff there that every company on the planet should be doing as a business model!
                        ☺ Now to tackle the bltouch issue again... later... much appreciated!
                          I've been busy with EMC compatibility testing for CE certification for the last 2 days, so I've had very little time to respond to forum questions. In answer to your question, we hope to support updating PanelDue version 3.0 controllers through the Duet in the future, however we need to write some firmware to make that possible. So at present you have to update them through USB.
                          • 3DOesteundefined
                            3DOeste
                            Hi, I just have a serious layer shift on some pieces. The printer was running for many days non stop without a single issue.
                            Mechanically everything moves smoothly.
                            Here's my M122. After that, I restart the print, and so far everithing is going well.
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet Ethernet 1.02 or later
                            Board ID: 08DGM-95BNL-MGPSJ-6J1FJ-3S86T-12ZMW
                            Used output buffers: 4 of 20 (12 max)
                            Static ram: 28380
                            Dynamic ram: 95468 of which 16 recycled
                            Exception stack ram used: 572
                            Never used ram: 6636
                            Task NETWORK ready, free stack 324
                            Task HEAT blocked, free stack 800
                            Task MAIN running, free stack 3588
                            Last reset 100:27:48 ago, cause: power up
                            Last software reset at 2018-06-13 12:33, reason: User, spinning module GCodes, available RAM 6924 bytes (slot 2)
                            Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                            Error status: 16
                            Free file entries: 9
                            SD card longest block write time: 328.9ms
                            MCU temperature: min 14.0, current 35.3, max 37.4
                            Supply voltage: min 12.1, current 12.3, max 12.6, under voltage events: 0, over voltage events: 0
                            Driver 0: ok, SG min/max 0/1023
                            Driver 1: ok, SG min/max 0/1023
                            Driver 2: standstill, SG min/max 0/1023
                            Driver 3: ok, SG min/max 0/1023
                            Date/time: 2018-06-19 13:36:20
                            Slowest loop: 634.02ms; fastest: 0.07ms
                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 150, MinFreeDm 144, MaxWait: 2564388349ms, Underruns: 2227, 11
                            Scheduled moves: 12471, completed moves: 12441
                            Bed compensation in use: none
                            Heater 0 is on, I-accum = 0.0
                            Heater 1 is on, I-accum = 0.4
                            Segments left: 1
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is doing "G1 X75.697 Y152.036 E0.0121" in state(s) 0
                            serial is idle in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 634.09ms; fastest: 0.01ms
                            HTTP sessions: 1 of 8
                            Interface state: 5
                            === Expansion ===
                            The error status 16 is what caught my attention but I couldn't find any info of it.
                              Is this a problem that has only occurred since you upgraded to firmware 2.0?
                              Layer shifts are typically caused by the nozzle catching on a blob or curl-up. Increasing motor current or reducing travel speed may help. What is the rated current of the motors, and what currents have you set in M906?
                              The error code bits are defined as follows:
                              // Enumeration of error condition bits
                              enum class ErrorCode : uint32_t
                              BadTemp = 1u << 0,
                              BadMove = 1u << 1,
                              OutputStarvation = 1u << 2,
                              OutputStackOverflow = 1u << 3,
                              HsmciTimeout = 1u << 4
                              So 16 means that there was a timeout on the SD card interface, which is unusual.
                              • 3DOesteundefined
                                3DOeste
                                I finally found the problem. It was a belt about to get cut. I didn't notice on first sight, but after a careful look I saw a dent on one of the belts (it's a coreXY), so although it did move smoothly, occasionally it got caught on one of the pulleys...
                                It last a year, I need to try with an original Gates.
                                Please, delete the posts since it wasn't firmware related.
                                All this time (many days) I've been working with firmware 2.0. Not a single problem. The only thing that noted is that file upload to SD now reach a maximun of 750kb/s and with 1.21 it reaches 1000kb/s-
                                • SputnikOC3dundefined
                                  SputnikOC3d
                                  OK so now a new wrinkle in the Acronym soup ... Sam3 / Sam4 ????
                                  I really dont understand many of the notes put on these github docs and find them to be a bit challenging to follow.
                                  Id like to use FW ver 2.0 here ... for my Duet Wifi [ Duet 2 ver Board ???? ]
                                  My DWC Page tells me - I have this stuff:
                                  Firmware Electronics: Duet WiFi 1.02 or later [ so is that a Duet 2 or a Duet 1.02 ? ]
                                  Firmware Version: 1.21 (2018-03-21)
                                  So am I needing files for a Duet 2 Board even though the DWC interface indicates a cryptic indicator of my Electronics version of 1.02 or later vs. Duet 2 ???
                                  Apparently i need Duet2Combined [ why its combined and with what who knows ] yes / no ?
                                  What wifi server version files do I need to upgrade to ? [ if any ]
                                  Do I also need a New browser interface update aka DWC / a.k.a. Web Interface Version / a.k.a. DuetWebControl.1.???
                                  Also if any of those other files in any combination are needed - how does one know ? As well if so, what order should they be installed.
                                    I agree it is fairly obtuse and complicated. An automated update system would be a boon.
                                    You'll want the combined firmware, but if it won't take it might need to be renamed to match what you have installed already. ( I know... Complicated) this is due to the recent change which merged the duet ethernet and wifi firmwares. Hence combined.
                                    You'll also want to grab the DWC file and the webserver file and the IAP files just in case.
                                    Hope that helps. And hopefully the pain points of updates can be improved in the future.
                                    SnowCrashundefined 1 Reply Last reply Reply Quote 1
                                    • SnowCrashundefined
                                      SnowCrash @Phaedrux
                                      @phaedrux said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                                      I agree it is fairly obtuse and complicated. An automated update system would be a boon...
                                      Well said, @Phaedrux, couldn't agree more.
                                      In my view, the firmware update structure/mechanism of the Duet and its peripherals (DWC, PanelDue, etc) is way behind the product itself.
                                      Especially given all the firmware updates that frequently come up (great job, @dc42!), I think significantly upgrading and consolidating this aspect ought to move way up high in the priority list (if that's not the case already).
                                        SputnikOC3d
                                        Thanks guys ... yeah I just punted and dl'd 3 main files [ as I dont use PanelDue ] and - installed ...
                                        Guessed on the order... just did the main baords fw 1st then, wifiserver then DWC file.
                                          They can go all at once usually. Sometimes the main firmware takes a couple attempts.
                                          Glad it worked out
                                          • daprigooundefined
                                            daprigoo
                                            I'm upgrading a Fisher delta with a 0.6 Duet from 1.09k to 1.21.1 and have a problem with the web interface. On the G-Code Files listing the green, blue and red icons are not being displayed next to the files, I only get a simple selection box.
                                            This is the same on Firefox and Chrome browsers
                                            I have used the DuetWebControl-1.21.1.zip from https://github.com/dc42/RepRapFirmware/releases/tag/2.0
