    It's out! RepRapFirmware 2.0 and 1.21.1 released
    Firmware installation
    25
    81
    15.6k
      I have once seen the web interface think it is connected when the printer was not turned on. I think this was after I woke up the PC from sleep mode, but I am not sure. I was using FireFox browser.
      • wilrikerundefined
        wilriker @dc42
        @dc42 said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
        I can see this more often then not when waking up my PC from sleep and not having manually disconnected DWC before sending the PC to sleep. I am using Vivaldi which basically is the same as Chrome.
        Manuel
        My Tool Collection
        • zerspaner_gerdundefined
          zerspaner_gerd @otaku521
          @bmmal said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
          To expand further on my issue of not getting responses, it seems that DWC is somehow getting out of sync but not disconnecting ie ..........
          @otaku521 @SM3D
          I am glad that I am no longer the only one.
          I have the same problem.
          The debugging mode shows a difference:
          DWC 1.21.1 stops after error:
          DWC 1.21 continues to run after error:
          https://forum.duet3d.com/topic/5470/firmware-2-0rc6-and-1-21-1rc6-released/13
          Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
          • kraegarundefined
            kraegar
            Using it on the Railcore since released, non stop printing while I'm awake, and zero issues.
            • whosrdaddyundefined
              whosrdaddy
              I confirm the issue @zerspaner_gerd is seeing, have sometimes the same problem.
              Reloading the page resolves the problem.
              I suspect this is a DWC bug...
              whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                whosrdaddy @whosrdaddy
                @zerspaner_gerd : what is the value of the Ajax retries in your DWC settings?
                zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
                  zerspaner_gerd @whosrdaddy
                  @whosrdaddy
                  I tested at times until 4.
                  For a long time I stayed at 2, without change.
                  Am current back to 3 high, and this seems to show an improvement currently.
                  Did you observe the same?
                  • Adamfilipundefined
                    Adamfilip
                    confused which files i need to use to upgrade to V2.0 for my duetwifi
                    lots of files listed
                    Duet2CombinedFirmware.bin
                    5.6 KB DuetDriverFiles.zip
                    356 KB DuetMaestroFirmware.bin
                    552 KB DuetWebControl-1.21.1.zip
                    290 KB DuetWiFiServer.bin
                    57.9 KB iap.bin
                    57.8 KB iap4e.bin
                    58 KB iap4s.bin
                    370 KB RepRapFirmware-Alligator.bin
                    292 KB RepRapFirmware-RADDS.bin
                    373 KB RepRapFirmware.bin
                    335 KB Symbols-CoreNG-SAM3X8E.zip
                    322 KB Symbols-CoreNG-SAM4E8E_RTOS.zip
                    305 KB Symbols-CoreNG-SAM4S_RTOS.zip
                    110 KB Symbols-FreeRTOS-SAM4E.zip
                    81.7 KB Symbols-FreeRTOS-SAM4S.zip
                    1.67 MB Symbols-RepRapFirmware-Duet085.zip
                    1.5 MB Symbols-RepRapFirmware-Duet2_RTOS.zip
                    1.48 MB Symbols-RepRapFirmware-DuetM_RTOS.zip
                    Source code (zip)
                    Source code (tar.gz)
                    Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @Adamfilip
                      @adamfilip What firmware version are you upgrading from?
                      Duet2CombinedFirmware.bin should work. If you haven't upgraded in a while you may need to rename it. Check the firmware release notes for the interceding firmware.
                        dc42 administrators @Adamfilip
                        @adamfilip said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                        Which firmware version are you using at present?
                          Adamfilip
                          I tried the current Duet2CombinedFirmware.bin file and installed it. but this is what it says currently
                          Firmware Electronics: Duet WiFi 1.0 or 1.01
                          Firmware Version: 1.21RC3 (2018-02-28 build 4)
                          WiFi Server Version: 1.21
                          Web Interface Version: 1.21.1
                            @adamfilip Perhaps this will help? https://forum.duet3d.com/topic/5646/duet-wifi-not-updating-firmware-when-installing-2-0/2
                            Adamfilipundefined 1 Reply Last reply Reply Quote 0
                            • FrankNPrinterundefined
                              FrankNPrinter
                              Hi Dave been a while.. I see things have really progressed since i pestered you last. LOL I am getting ready to upgrade so i can get wifi working again. Great to see the evolution and addition of ssid and pw btw! I see i have some firmware updates to do as well but it is all a little confusing. i was wondering if someone can give me a cliff notes version of what to do 1st.
                              Duet wifi running ver 1.18.1 with panel due v 1.15c PC and printer are in opposite ends of house so ideally do this via sd card? What do i do 1st? Also confused about which are the latest versions and where to get them. I am hoping to get my ducks in a row for this weekend . BTW, loved the tidbit from E3D on how great the duet is. I have another printer now, running mks 1.4 board and wow, it is a real dinosaur by comparison. I had no idea how lucky i was with my 1st system. I am currently building a system with 1540 mm X, and 1500 mm Y \ Z so looking forward to the Duet2 as well 🙂
                                Phaedrux Moderator @FrankNPrinter
                                @franknprinter Take a good look through this document.
                                https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                                You'll need to follow the special steps for updating to 1.19 as things changed slightly at that point.
                                  Adamfilip @Phaedrux
                                  @phaedrux
                                  Thank you, yes this was my issue.
                                  • GizmotronX5000undefined
                                    GizmotronX5000
                                    I have downloaded the Duet2CombinedFirmware.bin, iap4e.bin, and DuetWebControl.zip files. I uploaded all of these to my DuetEthernet and it looked like it installed correctly, but it reports back saying that the firmware version is still 1.21. I'm running DWC 1.21.1, but I tried it with DWC 1.21 as well. Any idea what I'm doing wrong? The firmware updated date is listed as (2018-03-21), which is probably when I updated things last. Unfortunately the link above didn't solve my problem like I had hoped.
                                    Edit: It works now. Tried it again after the 4th or 5th time and it just worked. I honestly cannot think of anything that changed.
                                      FrankNPrinter
                                      thanks much @Phaedrux , i will give that a try this weekend!
                                        Adamfilip
                                        So far so good, havent run into any issues with 2.0 so far 🙂
                                          FrankNPrinter
                                          THanks @Phaedrux ! I couldn't wait so finished upgrade about 130 this AM LOL that worked like a charm even if it read like mudd. someone might want to update the install for 1.21 vs 1.19 as that was the instruction i used. Still have panel due to go but everything else is 1.21 now. dont suppose there is a way to flash duo from duet wifi? Else wise i will have to pull apart my case un mount and disconnect it so i can carry it to the computer room and plug in usb. Shocked and amazed i have not heard from @dc42 yet. I seem to recall Dave sending me answers before i could finish the question back in the day. LOL Bet you are even more insanely busy but keep up the outstanding work! I can see so many improvements and advances since i went down this road before, it really is awesome the way you take everyone's crazy ideas and turn it into a new release.. epic stuff there that every company on the planet should be doing as a business model!
                                          ☺ Now to tackle the bltouch issue again... later... much appreciated!
                                            I've been busy with EMC compatibility testing for CE certification for the last 2 days, so I've had very little time to respond to forum questions. In answer to your question, we hope to support updating PanelDue version 3.0 controllers through the Duet in the future, however we need to write some firmware to make that possible. So at present you have to update them through USB.
