Calibrating steps/mm
What type of mechanism? What distance is "wrong" when homing?
Steps per mm is normally a simple function of the pulley teeth, belt pitch, and steps/rev of the motor.
If you are using external drivers then you will need to use a T parameter on the M569 commands for those drivers, because the default width of the step pulses generated is fine for the built-in TMC2660 drivers but too short for almost all external drivers. See https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers#Section_Configuring_the_Enable_polarity_and_step_timing.
Settings I am using now. Can the T setting influence the accuracy of my steps?
M569 P5 S1 R1 T2.5:2.5:5:2.5
M569 P6 S1 R1 T2.5:2.5:5:2.5
M569 P7 S0 R1 T2.5:2.5:5:2.5
M569 P8 S0 R1 T2.5:2.5:5:2.5
M584 X5 Y6 Z7 E8 -
If the T values are too small then you can miss steps.
What is the external drive micro step set at? you have 10,000 miro-steps per revolution listed in you post, so micro step setting is 50?
Have you tried using 1/16 micro-stepping instead of 1/50th? if that works that may tell you there is an issue with the signal frequency / pulse width.
@nz_andy said in Calibrating steps/mm:
Good spot. That could well be the OP's problem as 50x micro stepping isn't a supported mode - see documentation here https://duet3d.dozuki.com/Wiki/GCode#Section_M350_Set_microstepping_mode.
Thanks for noticing the error in my calculation. I am using external drivers and are not using the M350 command.
@jddt Changed to 128 Micro Steps
What is the max T values you suggest to be safe?
@jddt said in Calibrating steps/mm:
High T values will limit the maximum step pulse frequency. I doubt that any stepper drivers need greater than T10.
The motors started to work properly with a value of T5
According to the datasheet, T2.5:2.5:5:0 should work.
