    Why don't you use Cura slicer?
    173
    32.7k
    • burtoogleundefined
      burtoogle
      BTW, looking at your small sample of gcode I can see that the extrusion rate is the same for all of the segments. So although some don't extrude as much, they are correspondingly shorter and so the rate remains the same.
        deckingman
        @burtoogle:
        Many thanks for that. I note that your E values are all lower than mine but that is easily explained by the fact that my default nozzle size is 0.5mm while I believe yours is 0.4mm.
        It seems that Cura is doing a better job of keeping the segment sizes all the same. Ref the issues with Slic3R, yes I agree that the extrusion rate is proportional to the segment size but that the segment size itself varies. It seems to do a few segments all one size but then chuck in the odd small one. That's probably what is triggering pressure advance part way round an arc which in turn leads to the problems I've been having, especially with high pressure advance as is needed when trying to print at high speed with multiple extruders running.
        It looks like it's time I took another look at Cura. If it handles multi part objects or has some means whereby I can assign different tools (colours) to different sections of an object then it'll be ideal.
        Thanks again.
          burtoogle
          Hi folks, the Cura thread has popped up again with some interesting news that's actually related to the original intent of this thread.
          Just letting you know that Cura 3.3 beta has been released today with a whole bunch of new features (and new bugs, of course). A couple of items you may be interested in are:
          1 - experimental bridge settings that let you frig speeds/flows/fans etc. when printing bridges and overhangs. This is one of my efforts.
          2 - experimental support eraser - this gui feature let's you position blobs where you don't want support to be created so it's a step towards having full-blown manual editing of support. This isn't my work.
          If you try 3.3 beta out and have any feedback, please post on the Cura forum (https://community.ultimaker.com/forum/108-cura-plugins/) or github (https://github.com/Ultimaker/Cura) rather than here.
          I have written a few notes about the bridging here https://community.ultimaker.com/topic/22195-introducing-the-experimental-bridging-settings/
          • ShadowXundefined
            ShadowX
            Is there a way to change the size of the support blocker or to have it applied to an entire surface? The default setting is very large and leaves an odd rectangular area that is well beyond where I want the support to be blocked. S3D had an option to change the size of the supports or removal of supports. Cura has definitely gone a long way once you turn on all the options.
            It would be nice to have options for speed based on a percentage from the max speed, but I can set profiles. The only issue I see with the profile is that it does not define all the speeds. If I set a bridge wall speed, there is no option to change it in the "global settings" tab. I only see an option to "Enable Bridge Settings". Its not a show stopper, but it would be nice to have all the speed settings for every option in the profile settings so the user don't have to dig through the config to set them for each profile.
            In the layer view, I don't see an option to show the retraction locations. Maybe I just didn't pick the right options. It would be nice to see the rectraction locations to adjust the settings to optimize if needed. S3D shows the location as a big blob so it makes it easier to see. I really like Cura's option to show the travel path. There is a slider to change layer and to show the motion within the same layer with a separate slider. That is a nice feature.
            Its definitely looks like it can compete with S3D.
              burtoogle
              Well, it's an experimental feature right now and that's why the settings are all in the experimental section rather than being in the sections that they could ultimately end up in.
              • ShadowXundefined
                ShadowX
                @burtoogle:
                That was just an example. There are lots of other speeds in the custom or advance settings that is not populated in the profile section.
                ie:
                Wall Speed
                • outer wall
                • inner wall
                  Support Speed
                  -support infill
                  -support interface
                  -initial layer speeds
                  Skirt/Brim Speed
                If there was an option to set the speed are based on a percent from a max print speed, it would be easy to change one parameter and have all the other speeds relative to that print speed.
                  burtoogle
                  Ah, I see what you're saying. I guess that the Cura devs don't think that way. Actually, I don't either but that's irrelevant.
                    T3P3Tony administrators
                    @burtoogle:
                    Thanks for this! I use a slightly older version of cura often so i will try the update.
                    • ShadowXundefined
                      ShadowX
                      That is how S3D sets the speed parameters in relation to the print speed. It would definitely be a feature that would make the transition from S3D to Cura a lot smoother. I really like Cura and the option for ironing the surfaces. I'll play around with it and hopefully switch over once I am happy with the print quality. I really like S3D 4.0's new feature with variable infill for thin walls. It makes filling in small gaps a lot smoother and the machine does not have to make quick jerk movements to fill small gaps in the previous revisions. I haven't played with Cura enough to see if there is a similar function.
                        Just coming back to say that I've been making an effort to use Cura more with the latest releases and I'm happy to report that some of my prior complaints have been resolved.
                        The new bridging parameters especially have been a big help. It's not as plug and play as Slic3r, there are a lot of settings to tweak and tune, which is both good and bad. The defaults worked good for me on short spans, but poorly on longer ones. Somehow Slic3r always seems to automatically do well, but with some more testing I think I will have a good handle on it. With the Tweak at Z plugin, you could vary the bridging settings as dictated by sections of the model. It's not automatic, but I appreciate the configurability.
                        My next favourite aspect of Cura is the per move type jerk and acceleration settings. It's helped shave quite a bit of time off prints while still maintaining quality where it matters. And the time estimates are more accurate.
                        Firmware retraction support can be added with a plugin now, but it would be nice to have that in the main release.
                        The variable layer height functionality is there now and works well, though it is more automated than I'd like.
                        There is still no small perimeter speed setting to help with holes, but I've found using lower acceleration values works well enough to allow for good small hole performance and still allow for higher speeds on straight perimeters.
                        My biggest complaint right now is GUI performance and slicing speed. Even using the menu tree can be a frustrating experience at times, and certain models with certain combinations of settings can result in very long slice times. Over 30 minutes at times! My laptop is a top of the line MacBook Pro from 2013. A little dated now, but Slic3r chews through the same model in less than a minute. As I said this is likely due to certain settings causing slicing to slow down so much. Optimizing perimeter order, try different line thicknesses, etc which slic3r lacks. So I am getting what I ask for, but even with default settings slicing is slow enough that enabling auto slicing is just asking for frustration.
                        All and all it's come a long way since my last list of complaints and I look forward to seeing where it goes from here. This is in no small part thanks to @burtoogle Good work!
                          burtoogle
                          Hi @Phaedrux , thanks for the feedback. With regard to the bridging capabilities, it's really a work in progress and looks to stay that way for some time yet. I still have several PRs (Pull Requests) waiting to be incorporated into Cura related to bridging and a bunch more that provide various other tweaks and bug fixes. The Cura "guardians" seem to be so busy these days that it takes months for any PRs to even get looked at let alone merged so it's a slow old business.
                            deckingman
                            I've just uploaded the latest version (3.3.1) and am really struggling to get this set up for multiple extruders. I've managed to create a printer with 4 extruders (actually it's a 3 colour but a mixing one so I use 3 tools which are primarily a single colour and a 4th tool which can be any combination). Anyway, that's by to by - as far as Cura is concerned, it's got 4 extruders and I'll sort out the mixing ratios.
                            I've created a material under "preferences - materials" which is my default PLA for which I use slightly different settings to the "bundled" filaments. That's no problem but under "profiles - material", there is an initial print temperature and a final print temperature which are lower. I want these to be the same. i.e if I print at 195 deg C , I don't want it to start at 185 deg C. I can't see anywhere else to change this other than for each individual profile which uses that filament, rather than in the materials section itself. Not only that, I can't see how to change it globally. That is to say, using the same filament in all 4 extruders, I have to go into each extruder tab and change the initial, and final print temperatures 4 times. Am I missing something?
                            The real big pain is setting up a profile. I made a duplicate then started changing settings and doing "manage profile - update with current settings" but here is where I run into problems. I've set layer height to 0.3mm and that's what it says under the "global" tab. However, when I click through the tabs for the 4 extruders, the layer height is set to 0.15mm and I can't find any way to change that. When I edit the profile and click through all the extruders, they are all set to 0.3mm but when I update the profile then go into "manage profile" they are all set to 0.15mm. Why doesn't the global setting of layer height get applied to individual extruders ?
                            Then there are all the other settings. In print set up. For example, under "Shell" I counted about 30 settings. I can't see any way to change these globally for all 4 extruders. I can't believe I have to set say, wall thickness, 4 times. The same for infill - 24 settings but if I'm in "Custom" and change say the infill percentage, it only affects one extruder and I have to click through all 4 tabs and change it 4 times.
                            Similarly with speeds. I've gone through all 4 extruder tabs and changed all the speeds to either 60 or 50. Then I update the profile using these settings but when I go into manage profile, it shows me the global speeds are 100, 40, 80, 30 and I can't find anywhere to change them.
                            Has anyone here used Cura with multiple extruders? If so, can you help?
                            • Daltonundefined
                              Dalton
                              1. No slowdown when printing bridges.
                              2. Too much options.
                              The difference between theory and practice is less in theory than
                              the difference between theory and practice in practice.
                              Expensive tools cannot compensate for lack of experience.
                              My stepper motor website: skysmotor.com
                              burtoogleundefined 1 Reply Last reply Reply Quote 0
                                burtoogle @Dalton
                                @dalton said in Why don't you use Cura slicer?:
                                1 - the options are there to slow down the walls and/or skin when printing bridges.
                                2 - there's lots of options right now because they are experimental! When we know what is useful and what isn't perhaps the number of options can be reduced or set to good default values. However, as what is a good value for speed/flow/fan, etc. differs from material to material so it's unlikely that all of these options can have defaults that work for all materials/printers/models.
                                • wilrikerundefined
                                  wilriker
                                  So, actually I am using Cura from the start (which is not so long ago anyway and I started with 3.2.1). I like it more than any other slicer I tried so far (ideaMaker, Slic3r PE, KISSlicer - I wanted to try IceSL but never got it to work due my ancient graphics card 😁).
                                  The only thing I am missing right now is a feature that I found in ideaMaker and liked a lot: change any setting at a given Z-height. Cura allows to change a few settings through built-in post-processing but I would like to have at least the option to change arbitrary settings. One use-case I had in the past was that I wanted to print a model with low infill at the bottom and 100% infill at a specific area that needed maximum rigidity - possibly but not necessarily going back to a lower infill further up.
                                  I know I had other use-cases but I cannot remember them right now.
                                  Manuel
                                  My Tool Collection
                                    burtoogle @wilriker
                                    @wilriker said in Why don't you use Cura slicer?:
                                    This is possible via the use of infill meshes. You can change all infill parameters for an arbitrary region within a model, I use that for reinforcing areas around holes like this example:
                                    wilrikerundefined 1 Reply Last reply Reply Quote 1
                                    • wilrikerundefined
                                      wilriker @burtoogle
                                      @burtoogle Narf! Would I have known this earlier I could have used this for the print that is going on right now 🤦
                                      EDIT: At least I know this for the future, thanks. 👍
                                      EDIT2: Good or bad: my print failed so I can now slice it anew with my new knowledge. 😁
                                      Manuel
                                      My Tool Collection
                                        Modifier meshes are the best kept secret of Cura unfortunately. Very useful but a little obtuse. Easier to use than the slic3r modifier meshes at least.
                                        • pabomanundefined
                                          paboman
                                          In cura I don't like the auto gcode calculating, it should be like S3D, once I have my settings dialed in then I can proceed to rendering the Gcode.
                                            burtoogle @paboman
                                            @paboman said in Why don't you use Cura slicer?:
                                            It's an option, you can turn off the auto-slicing. RTFM, perhaps?
                                            pabomanundefined 1 Reply Last reply Reply Quote 0
