    Simplify3D Configuration Question
    2.1k
    • mperdueundefined
      mperdue
      Does anyone know how to get Simplify3D to use G10 and M116 in place of M104 and M109?
      mperdueundefined 1 Reply Last reply Reply Quote 0
      • mperdueundefined
        mperdue @mperdue
        As a workaround, can you change M104 and M109 so they only set the active temperature and leave the standby temperature alone?
        • brunofportoundefined
          brunofporto
          I am using this start sequence, on both Slic3r and S3D (the [this_depends_on_slicer_software] code changes!), regarding the temperature:
          This is for Slic3r:
          T0 ; Duet documentation asks for tool selection at your start gcode
          M140 S[first_layer_bed_temperature] ; Slic3r [] code!
          M116 H0 This forces the printer to wait for the bed FIRST instead of turning o both heaters at the same time.
          M104 S[first_layer_temperature_0] ; Also Slic3r [] code!only after the bead is heated it starts to heat the hotend while homing and measuring leveling
          G32
          G1 X17 Y0 F10000; This is my ooze corner to wait the hotend to reach temperature.
          M116 ; Now it waits for the hotend to achieve temperature.
          M98 P/macros/SubMacros/beep.g ; this beeps me to clean the ooze
          G4 P30000 ; and waits 30seconds so I can jump from the chair 😄
          For S3d:
          T0
          M140 S[bed0_temperature]
          M116 H0
          M104 S[extruder0_temperature]
          G32
          G1 X2 Y0 F10000; Vai para X2Y0
          M116 P1;
          G4 P30000
          • mperdueundefined
            mperdue
            After reading more about the script handling in Simplify3D I see that it will not output the initial temperatures if the associated commands are in the startup script. The problem is that it doesn't seem to recognize bed0_temperature as a variable and passes it, unchanged, into the code output. I also tried just bed_temperature but that didn't work either.
            T3P3Tonyundefined Pilotltdundefined 2 Replies Last reply Reply Quote 0
              T3P3Tony administrators @mperdue
              @mperdue apparently it should be bed0_temperature. At least according to this:
              https://community.ultimaker.com/topic/11328-simplify3d-hidden-undocumented-placeholders-for-post-processing-scripts/
              But s3d are particularly terrible at documenting this sort of thing.
              • Pilotltdundefined
                Pilotltd @mperdue
                @mperdue
                M140 S[bed1_temperature] ;Start heating bed
                M190 S[bed1_temperature] ;Wait for bed to reach temp before proceeding
                and
                M104 S[extruder0_temperature] ;Start heating extruder
                M109 S[extruder0_temperature] ;Wait for extruder to reach temp before proceeding
                Work fine for me
                Steve
                • Alex.crundefined
                  Alex.cr
                  @mperdue under "FFF" tab in the firmware configuration tab will allow you to edit these.
                  Build a new .frm file and edit the appropriate values.
                  Also my start up script if you're still having issues:
                  G28 ; home all axes
                  G90;
                  G29 S1; load bed leveling
                  M106 S0; Turn fan off
                  M140 S[bed0_temperature] ; set bed heat
                  M141 S48; Set chamber heat
                  G0 X20 Y10 F9000 ;
                  M204 P700 T2000 ; set acceleration
                  M207 S5.0 R-.25 F1800 T1500 Z1.0 ;set retraction settings(f1500)
                  M190 S[bed0_temperature]; wait for bed heat
                  M191 S48; wait for chamber heat
                  G10 P1 S0 R190
                  G10 P0 S[extruder0_temperature] R190;
                  T1;
                  T0;
                  G10 P1 S[extruder1_temperature] R190;
                  ;G12 P0; Clean Nozzle
                  ;M109 S[extruder0_temperature] T0; wait for temp
                  ;M109 S[extruder1_temperature] T1; wait for temp
                  M116 ;used instead of M109
                  M572 D0 S0.25 ;pressure advance for tool 0
                  M572 D1 S0.25 ;pressure advance for tool 1
                  M106 P6 S255; turn tool light on
                  Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
