    24v Heatbed with 12v everything else
    30
    4.8k
    • Vaeiundefined
      Vaei @DjDemonD
      @djdemond 200W / 8.33A 24V heat bed, 350W / 14.6A 24V PSU
      ..Just realized, the mosfet is 12V. Or at least that's what the Amazon page says. But if I google for 24V mosfet I'm not getting any useful results.. Amazon page also claims it can handle 25A.
        T3P3Tony administrators @Vaei
        @vaei 12V sounds Odd for a mosfet rated to handle 25A and in that package. A little bit of investigation:
        DG210N06 is the model number - you can buy them off aliexpress etc. I cannot find a datasheet for them anywhere!
        Vaeiundefined 1 Reply Last reply Reply Quote 0
        • Vaeiundefined
          Vaei @T3P3Tony
          @t3p3tony If I don't have it on hand I'll just do it the previous way. Aliexpress takes at least 2 weeks to ship to me and I have everything else ready to go.
          Edit: Sorry I completely misunderstood what you were saying. I googled around and couldn't find much either.
            @vaei said in 24v Heatbed with 12v everything else:
            yeah basically i think its fine to use this as you plan, switching 24V as long as you get no where near the 24A maximum. but that is based on a guess... no data sheet available.
            • Vaeiundefined
              Vaei @T3P3Tony
              @t3p3tony Hm so what would I do about the incredibly slow heating?
              Phaedruxundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @Vaei
                @vaei Insulation?
                • Vaeiundefined
                  Vaei @Phaedrux
                  @phaedrux I don't get what you're asking 🙂
                  • AndreSundefined
                    AndreS
                    Put a thermal insulation to the underside of your bed.
                      @vaei Something like this
                      http://www.instructables.com/id/Insulate-Your-3D-Printers-Heated-Bed/
                        deckingman
                        If you are using PID rather than bang bang mode, then tuning the heater might help to speed things up - depends on what the default PID values are. Another thing that can help is re-positioning the bed thermistor - especially if you have a thickish heat spreader. Often bed heaters have a thermistor built in but what happens is that it senses the temperature close to the heater element which rises quickly, so the heater shuts off early.
                          Best to confirm that it is the bed that is the issue. As @Phaedrux has suggested earlier you can temporarily connect the bed directly to the power supply and time how long it takes to heat up.
                          • Vaeiundefined
                            Vaei
                            The bed I bought didn't have a thermistor, so I bought a separate one and I think the issue could also be the values being entered incorrectly. I'll have to measure the coefficients. But.. right now I have no time whatsoever (and sorry for the delayed response), I'll have to get back in a week or so.
