    Laser filament monitor
    Filament Monitor
    73
    179
    41.6k
    • hedeonundefined
      hedeon
      Just woke up to another failed large print due to a jam. Please add me to your list. I am UK based, tinkerer, with some experience in programming Arduino and ESP microcontrollers.
      • bazhipundefined
        bazhip
        Please throw me on there too @dc42
          You've probably got more than enough, but I'd test it too.
          • Qdeathstarundefined
            Qdeathstar
            looking forward to an eta
            • timcurtis67undefined
              timcurtis67
              Any kind of ETA on these new filament monitors?
              • Biggsisundefined
                Biggsis
                I would be interested in testing one of those too, since I have several printers (CoreXY and Deltas, all with DUETs), use OpenSCAD myself and do Arduino Programming, I think I meet the conditions (Except living in Germany and not in the UK 🙂 )
                Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
                Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
                • 3dmntbighkerundefined
                  3dmntbighker
                  No word in a month? Hoping to hear something soon dc42 🙂
                  I'm putting in an end stop sensor based filament out sensor now in my CoreXY. Can anyone tell me if there is any point in a mechanical end stop board with a few support components and an LED, as opposed to just as simple switch? I find versions of both on Thingiverse. Does it matter with a Duet board?
                  Scratch built CoreXY with Maestro
                  Heavily modified Ender 3 with Maestro
                  MPCNC work in progress with Duet WiFi
                    Phaedrux Moderator @3dmntbighker
                    @3dmntbighker The only thing that will matter between a simple switch and a switch with the LED is likely the high or low switching. For instance, I just installed a simple switch filament out sensor using a makerbot style endstop and it switches low. So you'll just need to set the relevant flag when you setup the command.
                    3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
                      3dmntbighker @Phaedrux
                      @phaedrux Thanks for the info. I wondered if a plain switch with no resisters anywhere could damage the Duet. Perhaps the inputs on the Duet are well protected and debounced?
                        dc42 administrators @3dmntbighker
                        @3dmntbighker said in Laser filament monitor:
                        Yes, the endstop inputs are.
                          T3P3Tony administrators
                          sorry for the delays. An update on testing is here:
                          https://forum.duet3d.com/topic/6092/laser-filament-monitor-test-results
                          • Hutch118undefined
                            Hutch118
                            This post is deleted!
                            • punamenonundefined
                              punamenon
                              Hi to everyone who is beta testing this sensor. I built upon the geometry for the housing, and modified it so that the PTFE tube can't be pulled out , and also it is split-able so that you can remove the remnant filament after the tail end has been fed past the hob gear.
                              Video explaining it here: https://youtu.be/RmZ7aJYvWLc?t=7m40s
                              .stl file here: https://www.myminifactory.com/object/3d-print-splitable-duet-laser-filament-bracket-for-bowden-tube-printers-73781
                              Phaedruxundefined 3dmntbighkerundefined 2 Replies Last reply Reply Quote 2
                                Phaedrux Moderator @punamenon
                                @punamenon That's a clever design. Nice work. Love the videos too.
                                  3dmntbighker @punamenon
                                  @punamenon said in Laser filament monitor:
                                  I'm a bit confused about having the sensor after the extruder. So you are relying solely on filament movement detection for both jams and out of filament conditions? Obviously once the hob stops pushing you will always still have filament present in the sensor. Just no movement. Mine is direct drive so this is purely my curiosity. I want a QuadFusion CMYK head eventually, so my filament detection will be a whole different worm can.
                                  brunofportoundefined 1 Reply Last reply Reply Quote 0
                                  • brunofportoundefined
                                    brunofporto @3dmntbighker
                                    I would install it after the extruder too so it can read the texture made by the hob gear even with difficult to read materials.
                                      One disadvantage of installing the filament monitor after the extruder drive is that there is an increased risk of filament dust contaminating the image sensor, especially after there has been a jam and some filament had been ground up.
                                      brunofportoundefined 1 Reply Last reply Reply Quote 1
                                        punamenon
                                        @dc42 said in Laser filament monitor:
                                        A good point! What about a redesign so that when you split it apart, you can access the sensor with a cotton swab? Would repeated wiping damage the sensor?
                                          brunofporto @dc42
                                          @dc42 That is is true.....
                                          • celulariundefined
                                            celulari @dc42
                                            Today I've been trying out a laser optical sensor to see if it is accurate enough to use instead of the rotating magnet sensor we use in the beta test filament monitors. The good new is that in tests with several different filaments including black and transparent, first indications are that it works adequately, provided that the filament position is sufficiently well constrained. So we will go ahead with making prototypes. We may have a very small number (between 2 and 4) available for beta testers
                                            This does however mean that production of filament monitors to the existing design is on hold until the prototypes are ready and tested, so that we can make an informed decision on which design to use.
                                            The laser filament monitor would have a much simpler housing design. Basically it just needs to clamp PTFE tubes on the inlet and the outlet, to ensure that the filament is constrained to be in the centre of the field of view of the sensor.
                                            Is the filament monitor available for purchase?
